X-ray Flux density and a differential equation for photon scattering
In summary, the loss of intensity (through a slice of material) decreases as the thickness of the slice decreases.
razidan
75
Consider interactions of a X-ray beam at a depth, x, within a material. The flux density is:
density flux = $$\frac{I}{A}$$
where I is the intensity of the beam that cross a unit area A at right angles to the beam. Let dx be a small slice at the depth x and let dI(x) be the decrease in the intensity of the X-ray beam due to the interaction or scattering of the photons by the atoms of the material contained in the slice between x and (x + dx).
Determine the ability of a beam of X-ray photons to form a sharp image by calculating the loss of photons scattered out of the beam by the slice of material of thickness dx at a depth x in the material.
(Hint: Find the expression for the flux density rate)
so i can almost "read" off the question that I need to derive $$\frac{dI}{dx}=-I$$ but I'm not sure how to set it up.
I tried to say there is "conservation of flux" and write $$\phi (x+dx) - \phi (x) = d\phi (x)$$ but that's always true. it doesn't lead me anywhere...
I am also unsure what "the ability to form a sharp image" means.
Thanks.
R.
I think the intensity is the flux/area. The higher the intensity, the sharper the image. I would guess that the intensity falls off as a negative exponential of the depth of penetration.
What will be the relationship between the intensity reaching depth x, the thickness dx, and the loss through that thickness? You will need to create a constant.
I wrote that the incoming flux (at x) will br equal to the outgoing (at x+dx) plus the loss.
From there I got my equation (missing a minus on the RHS).
But that's not saying much. How can I construct the differential equation based on what I'm given?
Also, I inderatund there should be some attenuation factor, but do I "artificially" set it in my equation?
Consider a slice of thickness dx. Let the intensity reaching it be I and the loss through it ΔI.
What if we were to double the intensity reaching it to 2I? What loss would you expect then?
Twice the photons will have twice the probability to scatter. So twice the loss.
I think...
I think...
Right, so can you write that as a proportionality?
Next, how about doubling dx (but for very small dx)?
The lossvwill be squared...?
No, not squared. I think you meant multiplied by four if both intensity and dx are doubled.
I meant, keeping the incoming intensity constant but doubling dx, but no matter.
So as an algebraic equation, how does the loss of intensity depend on I and dx?
Why is the loss bot squared (without doubling the flux).
For each dx , there is some loss, so wouldn't for 2dx the loss would be proportional to dx²?
So if dx<1, there is less loss through 2dx than through dx?
Suppose the loss through the first dx is 1%. What would you expect the loss to be through the next dx?
Hmm...
Ok, I hear you.
razidan said:
Hmm...
Ok, I hear you.
Do you mind sharing your method as I am stuck on this exact same question. Thanks
It is not evident that razidan has solved it. Anyway, you should show your own attempt, so maybe best if you create a new thread.
Related to X-ray Flux density and a differential equation for photon scattering
1. What is X-ray flux density?
X-ray flux density, also known as X-ray luminosity, is the amount of X-ray radiation emitted per unit time from a particular source. It is typically measured in units of erg/s/cm2/Hz.
2. How is X-ray flux density calculated?
X-ray flux density is calculated by measuring the number of X-ray photons emitted per unit time and dividing it by the surface area of the source. This can be done using specialized equipment such as an X-ray telescope or by analyzing data from X-ray detectors.
3. What is a differential equation for photon scattering?
A differential equation for photon scattering is a mathematical representation of the behavior of photons as they interact with matter. It takes into account the properties of the material (such as density and composition) and the energy of the photons to determine the probability of scattering events occurring.
4. How is the differential equation for photon scattering used in X-ray flux density calculations?
The differential equation for photon scattering is used to model the interactions between X-ray photons and the material they pass through. By solving this equation, scientists can predict the amount of X-ray flux density that will be observed at a particular distance from the source.
5. What factors can affect X-ray flux density and the results of the differential equation for photon scattering?
There are several factors that can affect X-ray flux density and the results of the differential equation for photon scattering. These include the properties of the source, such as its size and temperature, as well as the properties of the material the photons are passing through, such as its density and composition. Other factors, such as the distance between the source and the observer, can also play a role in the calculations.
  • Quantum Physics
  • Atomic and Condensed Matter
