X*t, what is position multiplied by time?
In summary: It was explored because it led to a more accurate description of physical reality.Do you know why and how it was applied?I do not know.
JLT
52
TL;DR Summary
Area and slopes
So the pattern goes:
x(t)
v(t)
a(t)
jerk(t)
You can keep taking slopes of lines, and slopes of slopes - my questions is, what happens in the other direction- areas under curves and more areas under curves.
What is the area under the x(t) curve?
x*t, what is position multiplied by time?
JLT said:
TL;DR Summary: Area and slopes
Nothing of interest afaik.
Likes vanhees71
Why are some physical quantities multiplied or divided by other quantities interesting, and other combinations not explored?
I don't think it's a case of "not explored". It's "nobody has found a use for it, so it doesn't get taught". Distance travelled per unit time is a useful quantity for stuff like predicting how long a whole journey will take given data on part of it. What would you use distance times time for?
Likes vanhees71, Vanadium 50 and malawi_glenn
Why does no one try holding a golf club by the head and hitting the ball with the handle?
Physics has an objective to explain natural phenomena. One important objective was to explan why planets move in ellipses. Newton developed the concepts and mathematics to achieve that objective. He wasn't just messing around aimlessly shuffling symbols on a bit of paper. Pure mathematicians do that!
  • Haha
Likes vanhees71, Vanadium 50, phinds and 2 others
Voltage times heat capacity, why has not anyone explored that?
Likes vanhees71
The interesting ones are the ones that are found to be useful in formulating the laws of physics or describing the properties of things. The others aren’t “unexplored”, they just haven’t been found to be useful.
We need ##mv## and ##mv^2/2## to predict the motion of a body so they’re interesting - so much so that we’ve given them names, “momentum” and “kinetic energy”. ##mv^3##? We can calculate it, but why bother?
Likes vanhees71 and vela
For some people it might help! At least it couldn't hurt.
Rutherford said "All science is either physics or stamp collecting." Attempting to name every possible derivative and antiderivative of positiion (especially since we know there is an infinite e number of such) sounds more like the latter.
  • Haha
Likes malawi_glenn, nasu, vanhees71 and 1 other person
non-Euclidean mathematics was explored prior to applying the ideas to quantum mechanics.
If math is the language of the universe, something interesting should fall out of all of it.
time
position
mass
The above 3 are the building blocks if it all, and it just seems like all combinations of the above 3 should be explored - even if just for fun, even if it's just a purely mathematical exercise.
  • Sad
  • Skeptical
Likes weirdoguy and PeroK
There's nothing stopping you!
Likes vanhees71, Vanadium 50, Ibix and 2 others
There are seven independent units defined in the SI. Time, length, mass, temperature, current, amount of substance, and luminous intensity.
Knock yourself out. Random walks are a very inefficient way of getting to anything meaningful, though.
Likes vanhees71, berkeman and topsquark
You can not draw that conclusion from that premise.
There are infiniteley many combinations.
And that is not how science is done.
This is starting to derail into a "personal theory" thread.
Likes topsquark
Since the basic premise of this thread -- position times time -- is either nonsensical or of no use, take your pick, I'm closing this thread.
Likes topsquark and malawi_glenn
FAQ: X*t, what is position multiplied by time?
What is the significance of multiplying position by time?
The product of position and time represents the distance traveled by an object in a given amount of time. It is a fundamental concept in physics and is used to calculate the speed and acceleration of objects.
How is position multiplied by time calculated?
To calculate the product of position and time, simply multiply the numerical values of the two variables. For example, if an object travels 10 meters in 2 seconds, the product would be 20 meters per second.
Can position and time be multiplied if they have different units?
Yes, position and time can be multiplied even if they have different units. However, the resulting unit will be a combination of the two original units. For example, if position is measured in meters and time is measured in seconds, the product would be meters per second (m/s).
What does a larger product of position and time indicate?
A larger product of position and time indicates that the object has traveled a greater distance in a given amount of time. This could mean that the object is moving at a higher speed or that it has been traveling for a longer period of time.
How is the product of position and time used in real-life scenarios?
The product of position and time is used in a variety of real-life scenarios, such as calculating the distance traveled by a car in a certain amount of time or determining the speed of a runner in a race. It is also used in more complex equations to analyze the motion of objects in physics and engineering.
