Y''+xy'-y=0 differential equation
In summary: Where are you getting the ##\frac{x^3}{3}## term from?You seem to have forgotten the factor of ##x## multiplying ##P' = A''##.
TheFerruccio
220
Given [itex]y_1=x[/itex] is a solution, solve the differential equation
y''+xy'-y=0
Since I am given [itex]y_1=x[/itex] (is there a hotkey for adding TeX tags so I don't have to manually type these tags over and over? So tedious.) then I wish to vary a parameter A that y is multiplied by, A(x)...
[itex]y_2=Ax[/itex]
[itex]y_2'=A'x+A[/itex]
[itex]y_2''=A''x+2A'[/itex]
Plugging into the original equation, I end up with
[itex]A''x+(x^2+2)A'=0[/itex]
This is another differential equation, and I do not know where to go from here.
You could reduce the order of your new DE with a simple substitution.
Code:
 Use ##tex here## instead of [itex] tags for inline and
$$tex here$$ instead of [tex] tags.
Regarding the # # tags, I was using those for a while, but, a few posts ago, they completely stopped working for me. Maybe it was a script error in the browser. I've noticed that I have to refresh quite a few times to get the equations to show, no matter which browser or computer I'm using.
Anyway, I reduced the order of the equation, by substituting P = A', then I get a separable DE.
I get a solution of the form:##\text{Ce}^{-\frac{x^3}{3}-2 x}##
I do not think this is right. I simply replaced every instance of A' with P. I do not know how to integrate from this point, because I have a nasty integral that evades substitution methods. This just feels wrong.
(can't delete this)
TheFerruccio said:
Regarding the # tags, I was using those for a while, but, a few posts ago, they completely stopped working for me. Maybe it was a script error in the browser. I've noticed that I have to refresh quite a few times to get the equations to show, no matter which browser or computer I'm using.
Using Mathematica, I find the solution is ##P = Ce^{-x^2/2}/x^2##. Not sure that makes it any easier for you though.
I've been using Mathematica, as well, which is why I figured that my answer was wrong.
FAQ: Y''+xy'-y=0 differential equation
What is a differential equation?
A differential equation is a mathematical equation that describes the relationship between a function and its derivatives. It is used to model many real-world phenomena in fields such as physics, engineering, and economics.
What is the order of the given differential equation?
The given differential equation, "Y''+xy'-y=0", is a second-order differential equation. This means that it contains second derivatives of the dependent variable, Y.
What are the initial conditions for this differential equation?
To solve a differential equation, initial conditions are needed. These are the values of the dependent variable, Y, and its first derivative, Y', at a specific point. Without these initial conditions, there are an infinite number of solutions to the equation.
How can this differential equation be solved?
There are various methods for solving differential equations, such as separation of variables, integrating factors, and substitution. The specific method used to solve this equation will depend on its form and complexity.
What applications does this differential equation have?
Differential equations are used in many fields to describe and predict the behavior of systems and processes. This specific equation, "Y''+xy'-y=0", has applications in mechanics, electronics, and population dynamics, among others.
