Year1 Mechanics (angular momentum)
In summary, the circular plate with radius 0.5 m and mass 5 kg can rotate with an angle of up to 60.4 degrees away from the equilibrium position after a short-duration impulse of 5 N sec is applied.
AlanWWW
A circular plate with radius 0.5 m and mass 5 kg is hung on the wall, fixed at a point that is 0.3 m above its center. The plate can freely rotate about the fixed point with no friction. A very short-duration impulse of 5 N sec, along a direction that is tangential to the circumference of the circular plate, is applied at the bottom point of the plate. From energy conservation, what is the maximum angle of rotation (away from the equilibrium position) attained by the plate?
r = 0.5 m
m = 5 kg
Impulse = 5 Ns
w is omega
r is the radius
Moment of Inertia = I_cm + MR^2
Rotational energy = 0.5*I*w^2
angular momentum = linear momentum*r
angular momentum = I*w (if symmetry)
[/B]
First, find the moment of inertia by I = I_cm + MR^2
I = 0.5*m*r^2 + m*r^2
= (0.5)(5)(0.5^2)+(5)(0.3^2)
= 1.075Then, find the initial angular velocity
By impulse = Δangular momentum
(I stuck here because the equation" angular momentum = I*w " cannot be used
as it only works when the rotation axis is symmetry)Then the question said from conservation of energy, so it should relate to:
Initial Energy = Final Energy
Initial Energy = E_rotational + E_transitional
(Energy of transitional should not be zero as the center of mass is moving,
I am not sure it is correct or not.)
Final Energy = m*g*h
(However I don't how this equation apply to a rigid body but not a point mass)
Yes it can. Angular momentum needs an axis for its definition and so does the moment of inertia. As long as both are defined with respect to the same axis, the equation is valid.
What is h? The plate has many points. Hint: At what point does the external force of gravity act?
The duration of the impulse is irrelevant if you are not given the force that acts during the 5 ns interval. If you hit the plate with all your might as opposed to lightly tapping it for 5 ns, the results will be different, no?
Likes AlanWWW
h is the vertical displacement of center of mass
The question gave impulse only, so I think the impulse-momentum theorem should be used
Sorry, I misinterpreted 5 N sec as 5 nanoseconds. I see now that it's 5 Newtons⋅seconds. Yes, use the impulse-momentum theorem. Can you solve the problem now?
Likes AlanWWW
No... there is problem about the value of h
I calculate with following steps:
I = 0.5*m*(r^2) + m*(r^2) <---first r is 0.5 and second r is 0.3
I = 1.075
I*w = impulse
w = 4.651
KE_initial = KE_final
0.5*I*(w^2) + 0.5*m*(v^2) = mgh
0.5*I*(w^2) + 0.5*m*(r^2)*(w^2) = mgh <--r is 0.3
h = 0.34
which is larger than 0.3 , that's means the center of mass raise above the axis of rotation
so the angle of rotation is larger than 90 degree
However, the solution of this question is C(60.4 degree)
AlanWWW said:
I*w = impulse
w = 4.651
There is a problem here. Iω has unit of angular momentum while impulse has units of momentum. You cannot set them equal. For linear motion you have linear impulse = change in linear momentum. For angular motion you have angular impulse = change in angular momentum. Any ideas how to find the angular impulse from the linear impulse? Hint: How do you find angular momentum from linear momentum?
Likes AlanWWW
The angular impulse = radius of rotation *linear impulse
After the adjustment , i got h
Then I calculate the angle:
arcosθ=(0.3-h)/0.3
And I got θ = 73.6 degree, which is wrong
However
If I do not calculate the transitional kinetic energy:
KE_rotational = mgh
I got the exact correct answer
Is there any conceptual mistake I made?
There is no mention that kinetic energy is conserved during the collision, so you cannot assume that it is. However, you may assume that angular momentum is conserved because the impulse is of very short duration, so short that the external torque due to gravity does not affect the angular velocity as it is being acquired by the plate.
Likes AlanWWW
Thx
FAQ: Year1 Mechanics (angular momentum)
What is angular momentum?
Angular momentum is a physical quantity that describes the rotational motion of an object. It is a vector quantity, meaning it has both magnitude and direction. It is defined as the product of an object's moment of inertia and its angular velocity.
How is angular momentum different from linear momentum?
Linear momentum refers to the motion of an object in a straight line, while angular momentum refers to the motion of an object in a circular or rotational path. Linear momentum is a product of an object's mass and linear velocity, while angular momentum is a product of moment of inertia and angular velocity.
What is the conservation of angular momentum?
The conservation of angular momentum states that in a closed system, the total angular momentum remains constant. This means that if no external torque is applied, the angular momentum of the system will remain the same, even if the objects in the system are moving or rotating.
How is angular momentum related to torque?
Torque is the force that causes an object to rotate around an axis. The greater the torque, the faster the object will rotate. Angular momentum is directly proportional to torque, meaning that a larger torque will result in a greater change in angular momentum.
What is the role of moment of inertia in angular momentum?
Moment of inertia is a measure of an object's resistance to changes in its rotational motion. It plays a crucial role in determining the angular momentum of an object, as it is directly proportional to the angular velocity. Objects with a higher moment of inertia require more torque to achieve the same angular acceleration as objects with a lower moment of inertia.
