Yes, this is a reasonable answer.
  • Thread starter Tiberious
In summary: If you want to provide a basic understanding and definition of the Grashof and Reynolds numbers and their relation to natural and forced convection, then this is a reasonable answer. However, if you want to provide a more in-depth and detailed explanation, then you could add more information and examples as suggested in the conversation.
Tiberious
73
(a) The Grashof number and the Reynolds number appear in most correlations of experimental data for convective heat transfer. Explain, in a maximum of 150 words, the mechanisms of natural and forced convection with particular reference to the above non- dimensional groups.
SOLUTION
Heat transfer when referring to the forced or free movement of fluids is called convection. In natural (Free) convection, the fluid moves by difference in fluid densities owing due to changes in temperature gradient’s and can be represented by the Grashof number.
The Grashof number (Gr), approximates the ratio of buoyancy to viscous forces acting on a fluid.
In forced convection, the fluid is moved via influence of a pump; fan or external force. This is represented by the Reynolds number.
The Reynolds number (Re), is a nondimensional number that provides an indication whether fluid flow will be laminar or turbulent. The below image, Figure 1a, taken from Gary Settles PhD, ‘Laminar-turbulent transition’, unknown, 2ndApril 2018. Shows the change of flow from a candle from laminar too turbulent flow.
Is this a reasonable answer ?
I wonder why you put "combustion" in the title...
Anyway this is a very big argument and you can't explain it in less than 150 words. What you said is true but you can add a lot of more stuff. Just to mention a few:
- Reynolds number represents the ration of inertial and viscous force
- How do you get Reynolds and Grashof numbers? From which equations ?
- What relation exist between dimensional number and the heat transfer coefficient ? What they look like?
- In natural convection we usually observe "circular" (closed) motions (i.e hot air goes up, it cools down and falls back). Why ?
exc...
Yes, but it depends on what level you want to answer the question.
Related to Yes, this is a reasonable answer.
1. What makes an answer reasonable?
An answer is considered reasonable if it is based on evidence and logical reasoning. It should also be supported by relevant data and follow the scientific method.
2. Can an answer be considered reasonable if it goes against popular belief?
Yes, as scientists, we are trained to question and challenge existing beliefs and theories. A reasonable answer may challenge popular beliefs if it is supported by solid evidence and logical reasoning.
3. How do you determine the credibility of an answer?
The credibility of an answer can be determined by evaluating the source of the information, the quality of the evidence and data used, and the expertise and credentials of the person providing the answer.
4. Is it possible to have multiple reasonable answers to one question?
Yes, in science, there is often more than one reasonable answer to a question. This is because different researchers may approach a problem in different ways, and their methods and interpretations may lead to different but equally valid conclusions.
5. Can a reasonable answer change over time?
Yes, as new evidence and data become available, a previously considered reasonable answer may need to be revised or updated. This is a normal part of the scientific process as our understanding of the world evolves.
