Yes, this is correct. The answer is 1.3 x 10-8, or 0.000000013%.
  • MHB
  • Thread starter bergausstein
In summary, atmospheric concentrations are usually measured in parts per billion, by volume (ppbv). A concentration of carbon dioxide equal to 13 ppbv means that for every billion volume units of the atmosphere, there are 13 units of carbon dioxide. To convert this to a percentage, we use the fact that 1\% = \frac{1}{100}. Therefore, we can write 13 ppbv as \frac{13}{10^9} and multiply by 100 to get \frac{13\cdot10^2}{10^9}\%, which simplifies to 1.3\times10^{-8}\%.
bergausstein
191
Atmospheric concentrations are usually measured
in parts per billion, by volume (ppbv). So, a concentration of carbon dioxide equal to 13 ppbv means that, for every billion volume units (say,milliliters) of the atmosphere, there are 13 units of carbon dioxide.
Convert an atmospheric concentration of carbon
dioxide of 13 ppbv to a percent (that is, what per-cent of this atmosphere would be carbon dioxide?)
my solution
$\frac{13}{10^9}=1.3\times 10^{-8}$
is this correct. if not please help me arrive at the correct answer. thanks!
Mathematics news on Phys.org
We know that \(\displaystyle \frac{1}{2}=50\%\) or:
\(\displaystyle \frac{1}{2}=\left(\frac{1}{2}\cdot100 \right)\%=50\%\)
We see that when converting a fraction to a percentage, we must treat the percent sign as division by 100, because per cent literally means "for each 100." So if we attach a percent sign, we must multiply the fraction by 100 so that we are in effect multiplying by:
\(\displaystyle 1=\frac{100}{100}=100\cdot\frac{1}{100}=100\%\)
Hence:
\(\displaystyle \frac{a}{b}=\frac{100a}{b}\%\)
Can you proceed?
I still don't get it.
it's because of parts per billion thing. I'm confused. how am I suppose to convert 13ppbv to a percent? please bear please bear with me.
What you need to do is:
\(\displaystyle \frac{13}{10^9}=\frac{13\cdot10^2}{10^9}\%\)
Now simplify. :D
Yes, your solution is correct. To convert from parts per billion (ppbv) to a percent, you need to divide the ppbv value by 10^9 and then multiply by 100 to get the percentage. In this case, 13 ppbv divided by 10^9 gives you 1.3 x 10^-8, and when multiplied by 100, it becomes 0.000000013%. This means that 0.000000013% of the atmosphere is made up of carbon dioxide.
FAQ: Yes, this is correct. The answer is 1.3 x 10-8, or 0.000000013%.
What does the number 1.3 x 10-8 mean?
The number 1.3 x 10-8 is a scientific notation for a very small decimal number. It means 1.3 multiplied by 10 to the power of -8, which is equivalent to 0.000000013.
How do you calculate 1.3 x 10-8?
To calculate 1.3 x 10-8, you simply multiply 1.3 by 10 to the power of -8. In this case, it would be 1.3 x 0.0000000001, which equals 0.000000013.
What unit is used for the answer 1.3 x 10-8?
The unit used for 1.3 x 10-8 depends on the context of the question. Since it is a scientific notation, the unit can be anything that is being measured, such as meters, grams, or seconds.
Why is the answer written in scientific notation?
Scientific notation is used to represent very large or very small numbers in a more compact and easily readable format. It is commonly used in scientific calculations and measurements.
Is 1.3 x 10-8 the same as 0.000000013?
Yes, 1.3 x 10-8 and 0.000000013 are equivalent. They both represent the same decimal number, just written in different formats. 1.3 x 10-8 is written in scientific notation, while 0.000000013 is written in standard decimal notation.
