Yet another limit question in this forum (No.2 :P)
Just for future reference, you can write √ as \sqrt{ } in LaTeX to make it look nicer: f'(PI/4) = 3\sqrt2 )In summary, the equation f(x)= lim t-> x [csc(t)-csc(x)]/(t-x) can be solved using the first principle definition of the derivative of csc(x) at x= \pi/4 to find the value of f'(PI/4), which is 3√2.
Ballox
f(x)= lim t-> x [csc(t)-csc(x)]/(t-x). Find the value of f'(PI/4)
I can see that this equation somewhat resembles one of the first principle def'ns
lim z->x [f(z)-f(x)]/(z-x)
Not really sure how to begin.
I converted the csc(t) and the csc(x) to 1/sin(t) and 1/sin(x) and did a common denominator there, but I'm not sure if that's the correct approach to solving this problem.
I'm open to any suggestions and thank you for your time
Ballox
Hi Ballox! :smile:
(have a pi: π :wink:)
Hint: one of the standard trigonometric identities is sin(t) - sin(x) = 2cos((t+x)/2)sin((t-x)/2) :wink:
I don't recognize that as a standard trigonometric identity :(
Since it's of the indeterminate form 0/0, applying L'Hospital's rule should help :wink:
Haven't learned L'hopital's rule yet.
I believe we're supposed to use other methods
(just got up :zzz: …)
Then you will next time! :smile:
You can check for yourself that it's correct
(and familiarise yourself with the similar ones in the PF Library on trigonometric identities :wink:)
Quite correct- that is the "first principle" definition of the derivative of csc(x). So your problem is really "evaluate the second derivative of csc(x) at [itex]x= \pi/4[/itex]".
Ballox
Hmmm. So I read through all your responses and would like to thank you all for your help.
I looked back at the question and this is my solution:
limt->x [csc(t)-csc(x)]/(t-x) = d/dx csc(x) (not sure if this is represented correctly, but I see some sort of relationship here)
=> f(x)= -csc(x)cot(x)
f'(x)= -csc(x)*-csc^2(x) + cot(x)(csc(x)cot(x))
f'(x)= csc^3(x) + cot^2(x)(csc(x))
f'(PI/4)= 1/(sin^3(PI/4)) + [1/(tan^2(PI/4)) * 1/(sin(PI/4))]
f'(PI/4)= 2SQRT2 + (1*SQRT2)
f'(PI/4)= 2SQRT2 + SQRT2
f'(PI/4) = 3SQRT 2
Would this be correct?
Ballox said:
f'(PI/4) = 3SQRT 2
Yes. :smile:
FAQ: Yet another limit question in this forum (No.2 :P)
What is a limit question?
A limit question is a mathematical question that involves finding the value that a function approaches as the input approaches a specific value, usually denoted by the symbol "x". It is a fundamental concept in calculus and is used to analyze the behavior of functions.
How do you solve a limit question?
To solve a limit question, you can use various methods such as direct substitution, factoring, and algebraic manipulation. You can also use graphs or tables to estimate the limit. In more complex cases, you may need to use L'Hopital's rule or other advanced techniques.
What is the importance of limit questions?
Limit questions are important because they allow us to understand the behavior of functions and make predictions about their values at specific points. They are also crucial in many real-world applications, such as in physics, engineering, and economics.
Can limit questions have different types of answers?
Yes, limit questions can have different types of answers depending on the behavior of the function. The answer can be a specific numerical value, infinity, or it may not exist. It is also possible to have a different answer from the right and left side of the limit.
Are there any common mistakes when solving limit questions?
Yes, some common mistakes when solving limit questions include forgetting to check for removable discontinuities, using incorrect algebraic manipulations, and not considering the behavior of the function as x approaches the given value. It is important to be thorough and careful when solving limit questions to avoid making these mistakes.
11K
