What is the difference between the yield point and the elastic limit?
So, in summary, the elastic limit and yield point are essentially the same point on a force by length graph, but the yield point is a more practical and measurable value.
Abu
I don't understand the difference between the elastic limit and the yield point. I understand that if you stretch a material within the elastic limit, then the material should return to its normal shape. However, the yield point is described as the point at which a permanent increase in length is obtained. So shouldn't the elastic limit and the yield point be the same point on a force by length graph? In the graph the yield point is further past the elastic limit.
Thank you.
You are right.
Generally, elastic limit is an alternative name for yield point (or yield stress). The distinction of the two points seems weird.
Since the elastic limit is difficult to find exactly, the yield point is usually defined as 0.2% yield. That's a lot easier to measure, and thus more reproducible.
FAQ: What is the difference between the yield point and the elastic limit?
What is the difference between Yield Point and Elastic Limit?
The yield point is the stress level at which a material begins to deform permanently, while the elastic limit is the maximum stress that a material can withstand without permanent deformation.
How are Yield Point and Elastic Limit determined?
Yield Point and Elastic Limit are determined through stress-strain testing, where a material is subjected to increasing levels of stress until it reaches its yield point or elastic limit.
What happens to a material after it reaches its Yield Point?
After a material reaches its yield point, it will continue to deform significantly even when the stress is reduced. This is known as plastic deformation and the material will not return to its original shape.
Is Yield Point always higher than Elastic Limit?
No, there can be cases where the elastic limit is higher than the yield point. This can occur in materials with a high ductility, where they can withstand higher levels of stress without permanent deformation.
Why are Yield Point and Elastic Limit important to understand?
Yield Point and Elastic Limit are important to understand because they determine the strength and durability of a material. They also help engineers and scientists in selecting the appropriate materials for specific applications and designing structures that can withstand different levels of stress.
