Yo-Yo on a table contradiction
In summary, the conversation discusses the problem of finding the maximum value of force for which a yo-yo can roll without slipping on a table. Equations for Newton's second law and torque are given and used to determine the relation between the pulling force and the force of static friction. The conversation also includes a suggestion to perform an experiment using a cotton reel and discusses the possibility of the yo-yo oscillating around zero angular momentum when sliding.
Order
97
A Yo-Yo of mass M has an axle of radius b and a spool of radius R. Its moment of inertia can be taken to be MR2/2. The Yo-Yo is placed upright on a table and the string is pulled with a horizontal force F as shown. The coefficient of friction between the Yo-Yo and the table is mu.
What is the maximum value of F for which the Yo-Yo will roll without slipping? (See thumbnail below)
[tex]F=Ma[/tex]
[tex]\tau=I\alpha[/tex]
I have no idea. Neverhteless I can show the equations. Firstly I have the Newtons second law [tex]F-\mu Mg=Ma,[/tex] where [tex]F\ge \mu Mg,[/tex] so that it does not move backwards with a forward force. Secondly I have the equation [tex]\mu MgR-Fb=I\alpha,[/tex] where [tex]Fb\ge \mu MgR,[/tex] so that it does not roll forward with a backward pull.
Now using the moment of inertia and [tex]a=\alpha R,[/tex] I have [tex]\mu Mgr-Fb=I\alpha=\frac{RMa}{2}[/tex] and putting the equations together [tex]F-\mu Mg=2 \mu Mg-\frac{2Fb}{R}.[/tex]
But this is a contradiction because in the constraint that i used the right hand side of this equation is never negative whereas the right hand side is never positive. The only solution is that both are zero. So the condition that the Yo-Yo should not slide is [tex]F=\mu Mg.[/tex] But this contradicts my second constraint that [tex]Fb\ge \mu MgR,[/tex] because b<R. The solution must then be that the pull should not exceed the friction force, which is variable. But this is not correct. So where does my thinking go bananas?
When the yo-yo rolls there is static friction between it and the ground: Fs<=μmg. So the first equation should be
F-Fs=Ma,
where a is the acceleration of the CM.
Considering the torques with respect the CM, that of F causes rolling backwards, and the torque of static friction causes the yo-yo rolling forward. So
Fs*R-b*F=I*a/R.
Cancel Fs, find a, and replacing back into the first equation, you get the relation between Fs and F. Use that Fs<μmg to get an upper limit for F.
F-Fs=Ma,
Fs*R-b*F=I*a/R.
Ok, thanks for reply! I use [tex]F-F_{s}=Ma[/tex] and [tex]Fb-F_{s}R=I\alpha=-\frac{RMa}{2}[/tex] and put these two equations together: [tex]F-F_{s}=2F_{s}-\frac{2Fb}{R}[/tex] which leads to the relation [tex]F=\frac{3F_{s}R}{R+2b}[/tex] where [tex]F_{s}\le \mu Mg[/tex] That is the right order to solve the problem, so thanks for help. But there is still an important problem. I don't have a real Yo-Yo to perform an experiment with, but is it true that it then will accelerate to the right without slipping. According to the equations this should be so because [tex]Ma=F-F_{s}=\frac{3F_{s}R}{R+2b}-F_{s}=F_{s}\frac{2R-2b}{R+2b}[/tex] which is obviously greater than zero. This is really confusing to me and the reason I have been thinking about this problem for over a week. Could someone please tell me what really happens?
It will roll in the direction of the pull unless the pulling force is too strong. You do no need a yo-yo for the experiment: a cotton reel will do. It is even better than the yo-yo. The yo-yo is too thin and unstable. I think you can find a reel. Your mother, grandmother, aunt, wife, sister, daughter must have such thing.:wink:
You got the condition for F assuming that the yo-yo accelerated on the right without slipping. No wonder, that you get such acceleration at the end. It means that your solution was correct.
ehild
ehild
Thanks again! I tried the experiment and was amazed at how quickly the reel responds to the force. Of course it is very light (and I am very heavy I must confess). Then when the force is too strong the angular momentum becomes zero or oscillates around zero. I guess when it slides there is no static friction by which the torque can develop, but why it oscillates is something i need to think about.
That oscillation is interesting, I never experienced it! How does the reel move then?
I have got only cotton-reels, what about trying with a heavy thing, cable-reel, for example?
When sliding, the force of friction is kinetic, Fk=μmg. You get two separate equation for the acceleration of the CM and for the angular acceleration around the CM, but you need to know the direction of friction. If it is backwards, the angular acceleration can have both signs, according to the magnitude of F. You can find both the
velocity of CM and the angular velocity. From these, get the velocity of the lowest point of the yo-yo. The force of friction opposes this velocity, it can act forward and backward, accordingly.
Let me know if you have new experimental results!
ehild
ehild
I found it difficult to keep the reel straight and even more difficult to repeat the experiement, but what I saw was an oscillation around the horizontal axis, not the vertical axis and without any sign of decreasing. So your thought that it is due to changing signs might be it. I find it difficult to apply it mathematically though.
I will try it on a heavier reel as soon as I find one.
Related to Yo-Yo on a table contradiction
What is the "Yo-Yo on a table contradiction"?
The "Yo-Yo on a table contradiction" is a thought experiment that explores the concept of perpetual motion. It involves placing a yo-yo on a table and letting it unwind and wind back up continuously, seemingly defying the laws of physics.
Is the "Yo-Yo on a table contradiction" possible in real life?
No, the "Yo-Yo on a table contradiction" is not possible in real life. It violates the laws of thermodynamics, specifically the law of conservation of energy, which states that energy cannot be created or destroyed, only transferred or converted.
What is the explanation for why the "Yo-Yo on a table contradiction" cannot exist?
The yo-yo will eventually come to a stop due to friction. As it unwinds and winds back up, some of its energy is lost to heat and sound. This energy loss will eventually cause the yo-yo to stop moving, thus ending the "contradiction".
Can the "Yo-Yo on a table contradiction" be achieved with a perfect yo-yo and table?
Even with a perfect yo-yo and table with no friction, the "Yo-Yo on a table contradiction" still cannot exist. This is because of the law of conservation of angular momentum, which states that the total angular momentum of a system remains constant unless acted upon by an external force. The yo-yo's angular momentum would eventually become too small for it to continue moving perpetually.
What can we learn from the "Yo-Yo on a table contradiction" thought experiment?
The "Yo-Yo on a table contradiction" highlights the importance of understanding and applying scientific principles, such as the laws of thermodynamics and conservation of energy, in our daily lives. It also serves as a reminder that even seemingly impossible scenarios can be explained and understood through scientific reasoning and evidence.
9K
