Yonglie's question via email about ratio test
In summary, we use the ratio test to test the convergence of the given series, which is positive term so we don't need to worry about absolute values. We find the limit of the ratio of consecutive terms and determine that it is inconclusive, meaning we cannot determine the convergence or divergence of the series. Other tests, such as the comparison test or the root test, may need to be used to make a conclusion.
Prove It
MHB
1,465
24
Use the ratio test to test the convergence of the positive term series $\displaystyle \begin{align*} \sum_{n = 1}^{\infty}{\frac{2n+3}{4n^3 + n}} \end{align*}$
First, because the series is positive term, we don't have to worry about absolute values. Now $\displaystyle \begin{align*} a_n = \frac{2n + 3}{4n^3 + n} \end{align*}$ and
$\displaystyle \begin{align*} a_{n + 1} &= \frac{2\left( n + 1 \right) + 3}{4 \left( n + 1 \right) ^3 + n + 1} \\ &= \frac{2n + 2 + 3}{4 \left( n^3 + 3n^2 + 3n + 1 \right) + n + 1} \\ &= \frac{ 2n + 5}{4n^3 + 12n^2 + 12n + 4 + n + 1} \\ &= \frac{2n + 5}{4n^3 + 12n^2 + 13n + 5} \end{align*}$
so the ratio is
$\displaystyle \begin{align*} \frac{a_{n + 1}}{a_n} &= \left( \frac{2n + 5}{4n^3 + 12n^2 + 13n + 5} \right) \left( \frac{4n^3 + n}{2n + 3} \right) \\ &= \frac{8n^4 + 2n^2 + 20n^3 + 5n}{8n^4 + 12n^3 + 24n^3 + 36n^2 + 26n^2 + 39n + 10n + 15} \\ &= \frac{8n^4 + 20n^3 + 2n^2 + 5n}{8n^4 + 36n^3 + 62n^2 + 49n + 15} \end{align*}$
and the limit of the ratio is
$\displaystyle \begin{align*} \lim_{n \to \infty} \frac{a_{n + 1}}{a_n} &= \lim_{n \to \infty} \frac{8n^4 + 20n^3 + 2n^2 + 5n}{8n^4 + 36n^3 + 62n^2 + 49n + 15} \\ &= \lim_{n \to \infty} \frac{n^4 \left( 8 + \frac{20}{n} + \frac{2}{n^2} + \frac{5}{n^3} \right) }{n^4 \left( 8 + \frac{36}{n} + \frac{62}{n^2} + \frac{49}{n^3} + \frac{15}{n^4} \right) } \\ &= \lim_{n \to \infty} \frac{8 + \frac{20}{n} + \frac{2}{n^2} + \frac{5}{n^3}}{8 + \frac{36}{n} + \frac{62}{n^2} + \frac{49}{n^3} + \frac{15}{n^4} } \\ &= \frac{8 + 0 + 0 + 0}{8 + 0 + 0+0+0} \\ &= \frac{8}{8} \\ &= 1 \end{align*}$
Since the limit of the ratio is 1, the ratio test is INCONCLUSIVE and we are unable to make a statement about the convergence or divergence of the series.
But a simple comparison:
$\displaystyle \begin{align*} \sum_{n = 1}^{\infty} \frac{2n + 3}{4n^3 + n} &= \sum_{n = 1}^{\infty} \frac{n \left( 2 + \frac{3}{n} \right) }{ n \left( 4n^2+ 1 \right) } \\ &= \sum_{n = 1}^{\infty} \frac{2 + \frac{3}{n}}{4n^2 + 1} \end{align*}$
has the same behaviour as $\displaystyle \begin{align*} \sum_{n = 1}^{\infty} \frac{2}{4n^2} = \frac{1}{2} \sum_{n = 1}^{\infty} \frac{1}{n^2} \end{align*}$ which is a convergent p-series.
So by limit comparison, $\displaystyle \begin{align*} \sum_{n = 1}^{\infty} \frac{2n + 3}{4n^3 + n} \end{align*}$ is convergent.
Mathematics news on Phys.org
We may need to use a different test, such as the comparison test or the root test, to determine the convergence of this series.
FAQ: Yonglie's question via email about ratio test
What is the ratio test method used for?
The ratio test is a mathematical test used to determine the convergence or divergence of a series. It is commonly used in calculus and can be applied to infinite series, power series, and other types of series.
How does the ratio test work?
The ratio test compares the ratio of consecutive terms in a series to a limiting ratio. If the limiting ratio is less than 1, the series is convergent. If the limiting ratio is greater than 1, the series is divergent. If the limiting ratio is equal to 1, the test is inconclusive and another method must be used to determine convergence or divergence.
What is the formula for the ratio test?
The formula for the ratio test is limn→∞ |an+1/an|. This is the ratio of the absolute value of the (n+1)th term to the nth term in the series.
What are the limitations of the ratio test?
The ratio test can only be used on series with positive terms. It is also not useful for determining the exact value of a convergent series, as it only determines convergence or divergence. In some cases, the test may give an inconclusive result and another method must be used.
Can the ratio test be used on all types of series?
The ratio test can be used on many types of series, including infinite series, power series, and series with factorial terms. However, it may not be applicable to all types of series, such as alternating series or series with complex terms. In these cases, other convergence tests must be used.
9K
10K
10K
10K
10K
10K
9K
9K
