You are looking up from underwater in a swimming pool radius of circle?
In summary, the conversation discusses using Snell's Law and the critical angle to determine the radius of the hole at the water surface when looking up from under a swimming pool. The equation n.sin(theta)1 = n.sin(theta)2 is mentioned, as well as the values for n air and n water. The conversation also explores the concept of total internal reflection and how it relates to the radius of the hole. Finally, finding the corresponding horizontal distance from an initial position of looking straight up is mentioned as a potential solution.
ReMa
You are looking up from under the water in a swimming pool. If you are 2m below the surface, what is the radius of the "hole" at the water surface through which you can see out of the pool?
Could it be assumed that looking straight up through the water? So, sin(theta)1 = sin theta(90) = 1 ?
I'm assuming a hole would have an area of pi.r2, but don't know how to include that in the former equation (Snell's Law).
I also know n = c/v
c = 3x10^8 m/s (speed of light in a vacuum)
v = velocity
These values weren't given, but if applicable:
n air = 1.00
n water = 1.33
I suspect they are looking for what angle from straight up will the ray from your eye hit the surface and be reflected back into the water (total internal reflection)
So that deals with critical angle then?
sin(theta)c = n1/n2
where n1 = lesser indice
n2 = greater indice
Hows does that relate to radius of a circle??
sin(theta)c = n1/n2
n2 = greater indice
You can only move your head so far until the only light reaching your eye is light TIRing from the swimming pool's bottom.
Find what angle you can tilt your head until this happens and find the corresponding horizontal distance moved from a initial position of looking straight up.
Related to You are looking up from underwater in a swimming pool radius of circle?
1. What is the radius of the circle when looking up from underwater in a swimming pool?
The radius of the circle when looking up from underwater in a swimming pool is the distance from the center of the circle (which is the same as the center of the pool) to the edge of the pool. It is represented by the letter "r" in mathematical equations.
2. How does the radius of the circle affect the view when looking up from underwater in a swimming pool?
The radius of the circle affects the view when looking up from underwater in a swimming pool because it determines the size of the circle and therefore the area that is visible from underwater. A larger radius means a larger circle and a wider view, while a smaller radius means a smaller circle and a more narrow view.
3. What is the relationship between the radius of the circle and the depth of the pool when looking up from underwater?
The relationship between the radius of the circle and the depth of the pool when looking up from underwater is that the radius is directly proportional to the depth. This means that as the radius increases, the depth of the pool also increases, and vice versa.
4. How does the shape of the pool affect the view when looking up from underwater?
The shape of the pool can affect the view when looking up from underwater because it can change the shape of the circle that is visible. For example, a rectangular pool will create an elliptical shape when looking up from underwater, while a circular pool will create a perfect circle.
5. Is the radius of the circle the only factor that affects the view when looking up from underwater in a swimming pool?
No, the radius of the circle is not the only factor that affects the view when looking up from underwater in a swimming pool. Other factors include the depth of the pool, the shape of the pool, the clarity of the water, and the position of the viewer in the pool. These all contribute to the overall view when looking up from underwater.
  • Classical Physics
9K
