xswtxoj
- 87
what the advantage of decreasing the distance between slits in a Young double slit experiment? i think to have the laser move closer to the screen
Decreasing the distance between the two slits increases the distance between the interference fringes in the interference pattern. This means that the fringes become wider and more spread out. It also results in a decrease in the distance between the central maximum and the first order maximum.
This change occurs because decreasing the distance between the slits increases the diffraction angle, which in turn affects the spacing between the interference fringes. The change in diffraction angle is due to the fact that at a smaller distance, the light waves passing through the slits are more spread out, resulting in a larger angle of diffraction.
Yes, decreasing the distance between the slits causes a decrease in the intensity of the interference pattern. This is due to the fact that at a smaller distance, the light waves are more spread out, resulting in a decrease in the amplitude of the waves and thus a decrease in the overall intensity of the pattern.
Decreasing the distance between the slits has no effect on the wavelength of light used in the experiment. The wavelength of light remains constant, but the interference pattern changes due to the change in diffraction angle and spacing between the slits.
There is no specific limit to how close the slits can be, but as the distance between the slits decreases, the intensity of the interference pattern decreases and the fringes become wider and more spread out. In addition, at extremely small distances, the diffraction effects become more dominant and the interference pattern may become distorted.
