Young's double-slit experiment, fringe separation
In summary, the problem involves finding the wavelength of light based on the distance between the 1st and 21st bright fringes in a Young's double-slit experiment. By using the formula y = λD / a and substituting the given values for slit separation and distance from slits to the screen, the value of y is calculated. Using the equation mλ = d sin(θ), where m is the number of slits and d is the distance between them, the required angle can be found to determine the wavelength of light. It is important to note that monochromatic light must be used to obtain an interference pattern in this experiment.
moenste
711
The distance between the 1st bright fringe and the 21st bright fringe in a Young's double-slit arrangement was found to be 2.7 mm. The slit separation was 1.0 mm and the distance from the slits to the plane of the fringes was 25 cm. What was the wavelength of the light?
Answer: 5.4 * 10-7 m
y = λD / a
a = 1 mm = 10-3 m
D = 25 cm = 0.25 m
y (distance between 1st and 21st fringe) = 2.7 mm = 2.7 * 10-3 m
m (number of slits) = 21
λ = ?
First of all I am not sure whether y and m are correct terms for the given data.
y = (2.7 * 10-3) / (21-1) = 1.35 * 10-4 m
Second of all I do not understand why we need to divide y by m and not even by 21 but by 20.
λ = ya / D = 1.35 * 10-4 * 10-3 / 0.25 = 5.4 * 10-7 m
The answer is correct, but I completely lack an understanding of what is being done and what is being found.
Taking this image as an example: d is a = the separation of slits, through which the light from the source comes. This part I understand. Through the slits the light falls on the screen, which is L = D meters from the slits. This thing I also understand. As I suppose, y on the image is what I derive by dividing 2.7 mm by 20 slits. And this is where I am completely lost. What is 2.7 mm then? What are 21 or 20 slits? Why do we consider the y region at all?
I see the whole experiment as on this http://h2physics.org/wp-content/uploads/2009/08/fringeseparation1.gif . There are two slits through which light comes to a screen 4 m apart from the slits. Light from both slits comes in a form of a "triangle", both of triangles overlap and create a smaller triangle. Now what does the θ angle and that semi-triangle drawn in the image has anything to do with the experiment? The hypotenuse doesn't fit anywhere -- it's too far away at the beginning and too low at the end of the gif to the light-"triangles". But as I understand for some reason the opposite side of the θ angle is y, which we need to find, which looks like it doesn't represent anything at all.
Honestly, I am very very lost in this topic and this looks like the basic idea without understanding of which I cannot continue. If anybody could explain these things in a simple or logical manner I would appreciate it very much. At this point I do not quite understand what is y, why we need to consider it and so on.
The formula you need is ## m \lambda=d \sin(\theta) ## where d is distance between the slits, and ## m ## is an integer. The formula gives the location (angle ## \theta ## of maximum (bright spot) number ## m ##, where ## m ## is an integer. ( ## \lambda ## is the wavelength. ) Try working it with this equation. You can use the approximation ## \sin(\theta)=\tan(\theta) ## for small angles in finding the angles where the maxima are located. Just a bit of background info on Young's experiment: You normally would expect to get a shadow pattern (of two bright lines) for the light passing through two slits, but instead it produces an interference pattern consisting of a series of many bright fringes that are nearly equally spaced. The wavelength of the light determines the spacing of the bright spots of the interference pattern. (Note: monochromatic light, i.e. one color and not a mixture of colors, needs to be used to get an interference pattern.) ## \\ ## And just a little additional info: The brightest spot occurs at the center of the pattern and is labelled m=0. The pattern is symmetric about ## m=0 ## and also has bright spots at (negative) angles ## \theta ## for each negative integer.
Likes moenste
Thank you for some hints. Did read more about the experiment in last the couple of days (that is why replying so late, sorry for that). I think if I'll use your given formula I'll need to have the required angle, right?
If we take the original info which I have in the problem I see the situation as this:
y is the distance between n / m = 0 (the adjacent line of the triangle) and the n / m = 1 which is the brightest slit aside from the center. And because we have n / m = 1 and n / m = 21 and we need the distance between m = 0 and m = 20, so we subtract 1 from 21. And in order to find the distance between 0 and 1 we just divide 2.7 mm by 20 and we find y. I think this should be correct.
As said, y is the distance between m = 0 and m = 1, where m = 1 is the brightest slit after the center. And the hypothenuse points to m = 1.
The approximation that can be used is ## \sin(\theta)=\tan(\theta)=\theta ## provided ## \theta ## is measured in radians. With this approximation (which works for small angles, i.e. it works very well when the ##| \sin(\theta)|=1/10 ## or less and even somewhat good for ## | \sin(\theta)|<.25 ##), the bright spots are equally spaced for the interference pattern.
Likes moenste
FAQ: Young's double-slit experiment, fringe separation
1. What is Young's double-slit experiment?
The Young's double-slit experiment is a famous physics experiment that demonstrates the wave nature of light. It involves a single light source being shone through two parallel slits, creating a pattern of light and dark fringes on a screen behind the slits.
2. How is the fringe separation measured in Young's double-slit experiment?
The fringe separation, also known as the fringe spacing, is the distance between two consecutive bright or dark fringes on the screen. It can be measured by using a ruler or caliper to measure the distance between the centers of two adjacent fringes.
3. What factors affect the fringe separation in Young's double-slit experiment?
The fringe separation is affected by several factors, including the wavelength of the light source, the distance between the slits, and the distance between the slits and the screen. It also depends on whether the light source is coherent or incoherent.
4. How does the fringe separation change when the distance between the slits is increased in Young's double-slit experiment?
If the distance between the slits is increased, the fringe separation will decrease. This is because the light from each slit will have to travel a longer distance to reach the screen, causing the fringes to spread out more.
5. What is the significance of the fringe separation in Young's double-slit experiment?
The fringe separation is an important factor in determining the interference pattern created by the double slit. It can be used to calculate the wavelength of the light source and is a key aspect of understanding the wave nature of light.
