Young's Double Slit Experiment
In summary: You can then investigate the effects of narrower and wider slits on the intensity of the diffraction pattern and the number of fringes that are produced.In summary, when the slits are made narrower, but with the same separation, more fringes are produced. The reason is that the central lobe of the diffraction pattern becomes wider.
Priyadarshini
191
When the slits are made narrower (but with same separation) why are more fringes produced? If the slits are narrower, less light enters, so less light interferes with each other, so lesser number of fringes should be produced, isn't it?
That's not how the logic goes for this problem. It's true that as the slit width decreases, the diffraction pattern becomes dimmer, but that's not the reason why there are more fringes observed within the central lobe of the diffraction pattern. In order to understand the reason, let's take a look at the equation of the diffraction pattern
I(x) \propto \cos^2\left(\frac{\pi d x}{\lambda L}\right) \textrm{sinc}^2 \left(\frac{\pi b x}{\lambda L}\right)
where ##d## the slit separation, ##b## slit width, and ##L## the distance between slit plane and the screen. In that equation, the fringes are described by the cosine term enveloped by a wider ##\textrm{sinc}## function. The width of the central lobe is proportional to ##\frac{\lambda L}{\pi b}##. Therefore if the slit width ##b## decreases, the central lobe in the diffraction pattern becomes wider and more fringes are covered .
If the central lobe becomes wider, how are more fringes formed?
Is there a simpler logic? We haven't studied that formula yet.
The first part of the intensity formula is the interference of two slits. The second part of the formula, which determines how wide the observed interference pattern is, is the diffraction pattern of a single slit. Ideally the slits are very narrow, making the diffraction pattern of a single slit, and thereby the entire pattern, very wide, but the slits need to be wide enough to let enough light through to see the pattern. As the slits are widened, the observed interference pattern narrows. (The single slit diffraction pattern has zero intensity at m*lambda=b*sin(theta) where m=non-zero integer. The central lobe (brightest area) is the region around m=0. Notice as the slit width b is made larger, the spread of angle theta between the m=1 and m=-1 zero's of the single slit diffraction pattern decreases. )
Likes blue_leaf77
The diffraction pattern is the product of two effects: the single slit diffraction pattern and the idealized (zero width) double slit pattern. With an idealized double slit, all your fringes are the same brightness and you have unlimited number of them. If you've studied the single slit pattern, you should know that a smaller slit gives you a wider pattern.
Likes Charles Link
I believe the previous two posts have elaborated the answer in a simpler way. The quickest way, however, to get a grasp of how that equation behaves is to use a function plotter program to plot it and play around with the parameter ##b## (slit width).
Likes Charles Link
Related to Young's Double Slit Experiment
What is Young's Double Slit Experiment?
Young's Double Slit Experiment is an experiment that demonstrates the wave-like nature of light. It involves shining a beam of light through two narrow slits and observing the resulting interference pattern on a screen.
Who was Thomas Young and why is this experiment named after him?
Thomas Young was a British scientist who first proposed and conducted this experiment in 1801. He is known for his contributions to the fields of optics, vision, and physiology. This experiment was named after him to honor his pioneering work in the study of light.
What is the purpose of Young's Double Slit Experiment?
The purpose of Young's Double Slit Experiment is to demonstrate the wave-like behavior of light, specifically its ability to diffract and interfere with itself. This experiment helped to solidify the understanding that light is a wave, rather than a particle.
What is the setup of Young's Double Slit Experiment?
The setup of Young's Double Slit Experiment involves a light source, two narrow slits, and a screen. The light source is placed in front of the slits and shines a beam of light through them. The screen is placed behind the slits to capture the resulting interference pattern.
What is the significance of the interference pattern observed in Young's Double Slit Experiment?
The interference pattern observed in Young's Double Slit Experiment is significant because it proves that light behaves as a wave, as opposed to a particle. This experiment also helped to further our understanding of the wave-particle duality of light and other subatomic particles.
  • Other Physics Topics
20K
14K
