ppy
- 64
In a young's double slit experiment the slits have the same width and are separated by a distance a. an observation screen is placed at a distance L=1m from the slits at a point on the screen a distance y from the optical axis the optical path difference between the 2 waves from the slits is
r1-r2=(ay/L)
the double slits are illuminated with light with longitudinal coherence l=10x10^-6m if the interference pattern is observed on the screen around the position y=1cm what is the max value for a for which interference fringes are observed?
I am confused how can interference fringes be observed. For interference coherent light is needed but the longitudinal coherence is less than the distance from the slits to the screen so surely by the time the waves are at the screen the waves aren't coherent anymore so no interference pattern is observed?
Much help needed. Do I use that the path length difference must be greater than zero for interference ?
Thanks
