Young's experiment - lowering the light intensity of one slit
In summary: Consider a point on the screen where the phase difference between the two waves is ##\phi##. Let the wave from slit 1 at that point be ##A_1\sin( \omega t)## and the wave from slit 2 be ##A_2 \sin (\omega t +\phi)##. Using trig identities or using phasors, you can show that when these are added together, the result is ##A_{\rm net} \sin(\omega t +\phi_{\rm net})##, where##A_{\rm net} = \sqrt {A_1^2+A_2^2+2A_1A_2
Eitan Levy
259
We change the usual experiment by filtering one of the two slits, so that the intensity of the light that comes out of it becomes half than the intensity of the other slit.
Find the new Imax/Imin in the experiment
I is correlated to A^2
I think that what happens is that the amplitude becomes sqrt(2)/2A in the slit filtered, as opposed to A in the other slit.
I suppose we will still get constructive interference from the slits, so the value (1+sqrt(2)/2)A will be reached as opposed to 2A in the usual experiment.
However, the question seems to imply that there will be no dark spots at all. I can't understand why, and how to get the answer.
The final answer is: 33.97
Yes
When two waves are a half wavelength out of phase, what must be the relationship between their amplitudes in order for them to give complete destructive interference (i.e., to produce zero intensity)?
TSny said:
Yes
I understand that in the spots that are dark before we will get (1-sqrt(2)/2)A and that also gives the correct answer. I can't understand why there won't be other points were the intensity will be lower.
Won't there be points where the filtered slit will reach "stronger" than the unfiltered one? There were some points like that before I believe, what happens to them now?
Maybe the question is discussing only the spots where constructive and destructive interference were received?
Yes. There are points where at certain instants of time the filtered wave has a greater value than the unfiltered wave. (Just about all points on the screen have this property.) But there are no points where the intensity I is such that Imax/I is greater than 33.97.
Can you see that Imin occurs when the waves are ##\pi## radians out of phase? A nice way to see this is with the use of phasors (if you are familiar with this concept).
No, I can't see why this is the case if the waves do not have the same amplitude.
##A_{\rm net} = \sqrt {A_1^2+A_2^2+2A_1A_2 \cos\phi}##
##\tan \phi_{\rm net} = \large \frac{A_2 \sin \phi}{A_1 + A_2 \cos \phi}##
The resultant intensity is proportional to ##A_{\rm net}^2##. For what value of ##\phi## do you get ##I_{\rm min}##?
[Added note: For any point on the screen, there will be instants of time when the sum of the two waves is zero. But, the intensity ##I## at a point on the screen is defined in terms of the time average of the resultant wave.]
Related to Young's experiment - lowering the light intensity of one slit
1. What is Young's experiment?
Young's experiment, also known as the double-slit experiment, is a classic experiment in optics that demonstrates the wave nature of light. It involves shining a beam of light through two narrow slits and observing the interference pattern that is created on a screen behind the slits.
2. How does lowering the light intensity of one slit affect the interference pattern?
Lowering the light intensity of one slit in Young's experiment results in a decrease in the brightness of the interference pattern. This is because the intensity of the light passing through that slit is reduced, which affects the overall intensity of the interference pattern.
3. Why is it important to lower the light intensity of only one slit in Young's experiment?
In order to observe the interference pattern in Young's experiment, it is important to have a coherent source of light, meaning that the light waves must have a constant phase relationship. If the intensity of both slits is reduced, the phase relationship between the light waves will also be affected, making it difficult to observe the interference pattern.
4. How does the distance between the slits affect the interference pattern in Young's experiment?
The distance between the slits in Young's experiment determines the spacing of the interference pattern on the screen. As the distance between the slits increases, the spacing of the pattern also increases. This is because the light waves from each slit have to travel a greater distance to reach the screen, resulting in a longer path difference and wider interference fringes.
5. What other factors can affect the interference pattern in Young's experiment?
The interference pattern in Young's experiment can also be affected by the wavelength of the light, the distance between the slits and the screen, and the size of the slits. Changing any of these factors can alter the spacing and visibility of the interference pattern.
