Young's Modulus and Interatomic Bond Length PLEASE HELP
In summary, the alloy of titanium with a diameter of 0.14 cm stretches by 1.49 cm when a mass of 97 kg is hung from it.
luckyg14
A hanging wire made of an alloy of titanium with diameter 0.14 cm is initially 2.9 m long. When a 97 kg mass is hung from it, the wire stretches an amount 1.49 cm. A mole of titanium has a mass of 48 grams, and its density is 4.54 g/cm3.
Based on these experimental measurements, what is Young's modulus for this alloy of titanium?
Y = CANNOT FIGURE OUT
As you've done before, from the mass of one mole and the density you can find the length of the interatomic bond (diameter of one atom). This is 2.60 10-10 m for titanium. As shown in the textbook, the micro quantity ks,i (the stiffness of one interatomic bond) can be related to the macro property Y:
ks,i = CANNOT FIGURE OUT
Pls quote the equations you are aware of that relate to the definition of Young's modulus and (from your textbook) the relationship between interatomic bond stiffness and the modulus.
young's modulus is stress/ strain which is (F*Lo)/(Ao*delta_L) I do not know how to get the numbers and I don't understand how they relate to interatomic stiffness
okay so i know that Lo= 2.9m and delta_L= 0.0149m but I'm not sure how to get F and Ao
You're given the wire diameter, so what do you think the cross-sectional area will be?
What force will be exerted by a suspended 97kg mass?
Ao= 0.9079
I know force= m*a and I know that m is 97 but i don't know a
luckyg14 said:
Ao= 0.9079
What units? But I don't think that's right whatever units you chose. Pls show how you calculated it.
What does it mean to say something is hanging? What is the nature of the force that makes the wire stretch?
To find Ao i converted cm to m and then divided it by 2 to get the radius then used the area of a circle formula
and the force would be gravity
Correct procedure, but the answer was way off. Please post all that working.
Yes, so what force will the 97kg mass exert?
So i redid it and got Ao= .01539
and the force should be -950.6
it didn't work with those numbers idk what to do anymore but thank you
That's in sq cm, right?
Newtons. Always state the units.
So, plug those numbers in, be careful with the units, and post your working.
no its in meters because its supposed to be in meters.
i got 12021839.34 N/m and it was wrong
N/m^2
Then you calculated it wrongly. The diameter is 0.14cm, not 0.14m.
i converted it to meters because everything we do is always in meters
ok i redid my calculations again and got -264308724.8 N/m^2
would -264308724.8 be correct or should it be positive
It should be positive. If you are consistent, ΔL has the same sign as the force, which you've taken to be negative.
But I don't think that number is right yet. Radius = 0.07 cm, so area ≈ 0.015 sq cm = 1.5E-6 sq m. L = 2.9 m.; F = 97g ≈ 950N; ΔL ≈ 1.5 cm = 1.5E-2m.
950*2.9/(1.5E-6 * 1.5E-2) ≈ 1.2E11. That's roughly 500 times your number.
Related to Young's Modulus and Interatomic Bond Length PLEASE HELP
1. What is Young's Modulus?
Young's Modulus is a measure of the stiffness or elasticity of a material. It is defined as the ratio of stress (force per unit area) to strain (change in length per unit length) in a material when it is subjected to tension or compression.
2. How is Young's Modulus determined?
Young's Modulus is determined through experiments where a material is subjected to a known amount of stress and the corresponding strain is measured. The ratio of stress to strain gives the value of Young's Modulus for that material.
3. What factors affect Young's Modulus?
The factors that affect Young's Modulus include the type of material, its density, its atomic structure, and the temperature at which it is tested. Generally, materials with a higher density and stronger interatomic bonds have a higher Young's Modulus.
4. What is the relationship between Young's Modulus and interatomic bond length?
There is an inverse relationship between Young's Modulus and interatomic bond length. This means that as the bond length decreases, the stiffness of the material increases, resulting in a higher Young's Modulus. This is because a shorter bond length indicates a stronger interatomic bond, which requires more force to stretch or compress the material.
5. How is Young's Modulus used in material design and engineering?
Young's Modulus is an important property in material design and engineering as it helps in selecting the right materials for specific applications. For example, materials with a high Young's Modulus are suitable for load-bearing structures, while those with a low Young's Modulus are suitable for shock-absorbing applications.
19K
