Young's modulus and uncertainty
In summary, The homework statement asks for the Young's modulus corresponding to a change in length by a given step size. Although the units are missing, it is clear that ∆L is equal to the least count of length measurements. This makes the option that the smallest change will give the maximum value of Y the correct choice.
Jahnavi
848
102
Y = (F/A)/(∆L/L) = FL/A∆L
Putting values of F , L , A and simplifying
Y = 2×109/∆L
I don't know how to proceed . I also don't understand what is uncertainty in length and uncertainty in strain .
Is uncertainty the same thing as error in the measurement of a quantity ?
Please help me with the problem .
Jahnavi said:
Y = 2×109/∆L
This is missing units.
Error is (usually) the colloquial name for uncertainty.
You are given the step size of length measurements. What is the Young's modulus that corresponds to a change by this step size under the given load?
Sorry !
Y = 2×109/∆L N/m2
But why should ∆L be equal to least count of measurement of length i.e why should ∆L = .01mm ?
That is the smallest length change you can measure. It is interesting to see at which point the actual length change is equal to this smallest measurable change.
Likes Jahnavi
∆L depends on the force applied and the properties of the material .
Least count is the smallest length measured by the instrument .
These are two separate things .
I still do not understand why should ∆L be equal to the least count ?
It does not have to be.
The question is "what happens if that is the case?" What can we say about a material that has this specific case?
Is it right that since the least possible value of ∆L that can be measured will be equal to the least count , that smallest change will give the maximum possible value of Y that can be measured ?
In that case Y = 2 × 1014 N/m2 which makes 3) false .
Right.
Good, that is one part done.
Likes Jahnavi
Thanks .
Now I would like to check options 1) and 4) .
I will write Young's modulus as Y = FL/(πr2l)
L = length of the rod
l = Increase in the length of the rod
r = radius of cross section of the rod
∆Y/Y = ∆L/L + 2∆r/r + ∆l/l
Doubt 1) : Since least count is same for measuring lengths , does this mean ∆L = ∆l = ∆r ?
Doubt 2) : Minimum contribution in ∆Y/Y would be from ∆L/L which makes 1) option correct .
Is that correct ?
Doubt 3) :Contribution from error in strain would be the sum of 1st and 3rd terms i.e ∆L/L + ∆l/l .
But why would this contribution be maximum ?
Why wouldn't contribution of "error in radius " 2∆r/r i.e the 2nd term in ∆Y/Y be maximum ?
I would expect that the old and new length have 0.01 mm uncertainty each, not the strain itself.
I agree.
How large is 2∆r/r? How does this compare to typical ∆l/l (if you don't happen to measure a rubber band)?
Likes Jahnavi
OK . Since r > l and ∆r = ∆l =.01mm , ∆r/r would be much smaller than ∆l/l .
Right ?
Is ∆l (change in increase in length ) comparable to l ( increase in length ) i.e ∆l/l close to being 1 ?
Right ?
Right.
That will depend on your material.
Likes Jahnavi
OK.
That leaves us with option 2) . What is a figure of merit ? What does it specify ?
That depends on the specific field, here I guess it is the inverse of the relative uncertainty.
Likes Jahnavi
Is the figure of merit comparing L/∆L , r/∆r , l/∆l ?
Of the three ratios , L/∆L is the largest , making option 2) correct .
Right ?
Why is figure of merit defined in the way you have stated ( i.e inverse of relative uncertainty ) ?
Right ?
That's how I would interpret it.
That would be a typical definition, but in general such a figure of merit should be defined explicitly somewhere.
Likes Jahnavi
Thanks !
Related to Young's modulus and uncertainty
1. What is Young's modulus and why is it important?
Young's modulus is a measure of the stiffness or elasticity of a material. It is important because it allows us to predict how a material will behave under stress or strain, which is crucial in engineering and material design.
2. How is Young's modulus calculated?
Young's modulus is calculated by dividing the stress applied to a material by the strain it undergoes. This is known as Hooke's Law and is typically represented as E = σ/ε, where E is Young's modulus, σ is stress, and ε is strain.
3. What are the units for Young's modulus?
The SI unit for Young's modulus is pascals (Pa), which is equivalent to newtons per square meter (N/m²). In the imperial system, it is typically measured in pounds per square inch (psi) or megapounds per square inch (MPa).
4. What factors can affect the uncertainty of Young's modulus?
The uncertainty of Young's modulus can be affected by various factors, including the accuracy of the measuring instruments used, the uniformity and purity of the material being tested, and the method and conditions of the test itself.
5. How can we minimize uncertainty in Young's modulus measurements?
To minimize uncertainty in Young's modulus measurements, it is important to use high-quality measuring instruments and ensure that the material being tested is as uniform and pure as possible. Standardized testing methods and controlled testing conditions can also help reduce uncertainty.
