Yukawa force versus scattering amplitude
In summary, the Yukawa potential can be used to explain the strong nuclear force in the nucleus, but it is not applicable to the weak force, which is better described by the scattering matrix.
RedX
970
When does the Yukawa potential apply and when does the scattering matrix apply?
Take QED for example. When calculating a scattering amplitude, you have an expansion in powers of the fine structure constant, 1/137. Where does Coulomb's law F=e^2/r^2 come in? As far as I can tell, all calculations in QED are done with plane wave initial and final states, so where does the distance they come towards each other even come in, since we're dealing with momentum eigenstates? Even if you create wave-packets and send the particles towards a head-on collision, ensuring that the two particles will get close to each other, the most likely scenario is that no interaction takes place at all and they just pass through each other! But according to Coulomb's law, there will always be an effect!
The Yukawa potential for nucleons is used to show that the nucleus is bound. If leptons are really close together, can they be bound by a Yukawa potential that involves the exchange of W and Z? But the exchange of spin 1 particles results in a repulsive force, so wouldn't the weak force cause a ball of neutrinos to explode rather than to glue together?
So say you try to slam two protons together to get them to interact strongly. If you try to aim it so good that it's head on, then does that mean r=0, and so by Yukawa's law then there will be a big force?What validity is there to Yukawa's potential to explain the weak force?
The Yukawa potential is a mathematical model used to describe the interactions between particles, and it is valid for both strong and weak nuclear forces. The Yukawa potential takes the form of an exponential decay, and is expressed as a function of the distance between two particles. In the case of the weak force, the Yukawa potential is modified by the exchange of W and Z bosons, which gives rise to the repulsive force that keeps neutrinos from binding together. The scattering matrix is a way of expressing the probability of a particle interaction, and is typically used to calculate cross sections in particle physics.
Related to Yukawa force versus scattering amplitude
1. What is the Yukawa force?
The Yukawa force, also known as the nuclear force, is a type of force that acts between particles with non-zero rest mass. It is responsible for holding together the nucleons (protons and neutrons) in an atomic nucleus, and is mediated by particles called mesons.
2. How does the Yukawa force compare to other fundamental forces?
The Yukawa force is one of the four fundamental forces in nature, along with gravity, electromagnetism, and the strong force. It is the strongest force at short distances, but becomes negligible at distances greater than a few femtometers.
3. What is the relationship between the Yukawa force and the scattering amplitude?
The scattering amplitude is a measure of how particles interact with each other during a scattering event. In the case of the Yukawa force, the scattering amplitude is related to the strength of the force between the particles, and is described by the Yukawa potential.
4. How is the Yukawa force calculated?
The Yukawa force is calculated using the Yukawa potential, which takes into account the distance between particles, their masses, and the strength of the force. This potential is used in mathematical models and equations to describe the behavior of particles under the influence of the Yukawa force.
5. What is the significance of the Yukawa force in particle physics?
The Yukawa force is a crucial component in our understanding of the structure of matter at the subatomic level. It plays a key role in the stability of atomic nuclei and is essential for explaining the behavior of particles in high-energy collisions. Its study has also led to the development of important theories and models in particle physics.
