-z78 first four terms of the sequence of π‘Ž_(𝑛+1)=π‘Ž_𝑛+𝑛,π‘Ž_1=βˆ’1.
In summary, the first four terms of the sequence defined by the recursion $a_{n+1}=a_n+n$, $a_1=-1$ are -1, 0, 2, 5.
karush
MHB
3,269
Write out the first four terms of the sequence defined by the recursion n_(n+1)=n_1+1,n_1=βˆ’1
$\text{Write out the first four terms of the sequence defined by the recursion}$
$$\displaystyle
a_{n+1}=a_1+1,a_1=βˆ’1$$.
$\text{so then}$
$$\displaystyle
a_{0+1}=-1+0=-1$$
$\text{stuck!}$
Re: Write out the first four terms of the sequence defined by the recursion π‘Ž_(𝑛+1)=π‘Ž_𝑛+𝑛,π‘Ž_1=βˆ’1.
We are given the first term, so we need to manually compute the next 3 terms...here's the second one:
\(\displaystyle a_{1+1}=a_2=a_1+1=-1+1=0\)
Can you proceed?
Can you proceed?
\(\displaystyle a_{2+1}=a_3=a_1+1=-1+2=1\)
\(\displaystyle a_{3+1}=a_4=a_1+1=-1+3=2\)
$\textsf{so the first 4 terms are } $ $-1,0,1,2$
We have:
\(\displaystyle a_1=-1\)
\(\displaystyle a_{2+1}=a_3=a_2+2=0+2=2\)
\(\displaystyle a_{3+1}=a_4=a_3+3=2+3=5\)
so $a_1$ is not a constant but is replaced
The recursive definition is:
\(\displaystyle a_{n+1}=a_{n}+n\)
So, when we compute $a_2$, we let $n=1$, and so only then will we have $a_1$ on the RHS of the definition. :D
FAQ: -z78 first four terms of the sequence of π‘Ž_(𝑛+1)=π‘Ž_𝑛+𝑛,π‘Ž_1=βˆ’1.
What is the first term in the sequence?
The first term in the sequence is -1.
What is the second term in the sequence?
The second term in the sequence is 0. (calculated by plugging in n=1 into the formula)
What is the third term in the sequence?
The third term in the sequence is 2. (calculated by plugging in n=2 into the formula)
What is the fourth term in the sequence?
The fourth term in the sequence is 5. (calculated by plugging in n=3 into the formula)
What is the general formula for finding the nth term in the sequence?
The general formula for finding the nth term in the sequence is π‘Ž_𝑛=𝑛(𝑛+1)/2 - 1.
