Zeeman effect after a Stern-Gerlach experiment
In summary, the Zeeman effect can be observed in the fluorescence emission from a group of atoms/molecules by first exciting them to an excited state manifold. However, if one wants to observe the Zeeman effect by running atoms through a Stern-Gerlach separator first, it is necessary to ensure that the lifetime of the excited manifold is longer than the time it takes for the atoms to reach the output channel. It is also unlikely that the Zeeman effect can be observed by observing the absorption from the ground state, as no ground state is degenerate and therefore won't split under any perturbation.
svletana
Let's say you take a beam of particles and pass it through a Stern Gerlach apparatus and you select one of the outgoing beams, therefore collapsing the wavefunction to certain values of orbital angular momentum and spin angular momentum.
If you performed the Zeeman experiment on that beam, I'm assuming you wouldn't see any splitting because the particles in this beam have very well defined orbital and spin angular momentum? Assuming they all have the same quantum number n.
For example in the anomalous Zeeman effect the splitting occurs from the quantum number [itex]m_j[/itex], where j is the total angular momentum, correct? So since we have a very well defined value for j, there shouldn't be any splitting in that case.
Is this reasoning correct?
I would like to make an attempt to answer this question, but I don't know that this answer is necessarily correct. First of all, presumably a magnetic field is applied in the same direction as the inhomogeneous field of the Stern Gerlach apparatus to try to cause a splitting of the levels. One question I have is, can we assume the atoms from the Stern-Gerlach apparatus are in an excited state? Assuming they are, the different ## m_j ## or ## m_s ## will be separated by the Stern-Gerlach apparatus, so that one portion of the split beam consists of only one ## m_j ## or one ## m_s ##. It is somewhat of a puzzle how the Zeeman effect is going to be observed=at least for me=normally the Zeeman effect is observed by having an arc lamp placed in a magnetic field to create the splittings. The discharge (arc lamp) is necessary because that is the easiest way to get excited states and observed spectral lines. In the Stern Gerlach apparatus, I don't know that you have a sufficient number of excited states. Presuming that you do, I think there could be a splitting of the levels of the lower state, and some Zeeman effect could then be observed, but an experiment such as this would need to have sufficient excited states. Perhaps someone with more expertise in this area could help to fully answer this question. @vanhees71 Might you have an input?
Likes svletana and dlgoff
svletana said:
For example in the anomalous Zeeman effect the splitting occurs from the quantum number mjm_j, where j is the total angular momentum, correct? So since we have a very well defined value for j, there shouldn't be any splitting in that case.
That's a good point.
According to the abstract of this paper, Zeeman splitting can be observed in the fluorescence emission from a group of atoms/molecules by first exciting those atoms/molecules to some excited state manifold. Thus, if you want to run the atoms through a Stern-Gerlach separator first before observing the emission from one of the output channels, you need to ensure that the lifetime of the excited manifold is longer than the time the atoms take starting from excitation to the output channel.
I doubt though if one can do this experiment by observing the absorption from the ground state (hence eliminating the need of excitation) since no ground state is degenerate and thus won't split under whatever perturbation.
Likes svletana, Charles Link, vanhees71 and 1 other person
Great Answer, thank you! The answers took a turn I did not expect :)
Likes Charles Link
Related to Zeeman effect after a Stern-Gerlach experiment
1. What is the Zeeman effect?
The Zeeman effect refers to the splitting of spectral lines in the presence of a magnetic field. This phenomenon was first observed by Dutch physicist Pieter Zeeman in 1896.
2. What is the relationship between the Zeeman effect and the Stern-Gerlach experiment?
The Stern-Gerlach experiment, conducted in 1922 by German physicists Otto Stern and Walther Gerlach, demonstrated the quantization of angular momentum and the existence of spin in subatomic particles. This experiment also provided evidence for the Zeeman effect, as the deflection of particles in the experiment was influenced by a magnetic field.
3. How does the Zeeman effect after a Stern-Gerlach experiment provide insight into the behavior of subatomic particles?
The Zeeman effect after a Stern-Gerlach experiment allows scientists to study the properties of subatomic particles, such as their spin and magnetic moment. By observing the splitting of spectral lines, researchers can analyze the energy levels and transitions of these particles.
4. Can the Zeeman effect be used to study other physical phenomena?
Yes, the Zeeman effect has been applied in various fields of physics, including atomic and molecular spectroscopy, astrophysics, and plasma physics. It has also been used to study the magnetic fields of celestial bodies and the behavior of atomic and molecular species in different environments.
5. How is the Zeeman effect after a Stern-Gerlach experiment related to quantum mechanics?
The Zeeman effect after a Stern-Gerlach experiment is a manifestation of the principles of quantum mechanics. It shows that the behavior of subatomic particles, such as their spin and magnetic properties, cannot be explained by classical physics and requires a quantum mechanical understanding.
  • Quantum Physics
  • Quantum Physics
