Zeeman Effect - average shift is zero?
In summary, the conversation discussed finding the first order shift in energy and determining the degeneracy after perturbation. The perturbation lifted the degeneracy, resulting in a degeneracy of 0. The average shift in energy was found to be zero due to the different weights contributed by the two different values of j in the perturbation. This is a two-angular momentum problem, not a simple one with only spin.
unscientific
1,734
Part (a):Find the first order shift in energy
Part(b): What is the degeneracy after perturbation? Find Show average shift in energy is zero.
I've shown part (a), the troubling part is part (b).
Part (b)
With the perturbation, the degeneracy is lifted. Hence degeneracy = 0.
For ##j=l+\frac{1}{2}##, shift is ##\Delta E_+ = \frac{1}{4}mc^2 \alpha^4\frac{(l+\frac{1}{2})(l+\frac{3}{2}) - l(l+1) - \frac{3}{4}}{n^3 l(l+\frac{1}{2})(l+1)}##
For ##j=l-\frac{1}{2}##, shift is ##\Delta E_- = \frac{1}{4}mc^2 \alpha^4\frac{(l-\frac{1}{2})(l+\frac{1}{2}) - l(l+1) - \frac{3}{4}}{n^3 l(l+\frac{1}{2})(l+1)}##.
The total perturbation is given by the sum of positive perturbation and negative perturbation:
[tex]\delta E= \Delta E_+ + \Delta E_-[/tex]
[tex]\delta E = \frac{mc^2 \alpha^4}{2n^3 l}[/tex]
Clearly, the average perturbation for a given n and l is not zero. How does it even become zero then?
j = l + 1/2 and j = l - 1/2 have different degeneracies. They contribute different weights to the average.
dauto said:
j = l + 1/2 and j = i - 1/2 have different degeneracies. They contribute different weights to the average.
Each has a weight of ##2l-1##?
No, they have weights 2j+1 for two different values of j
Likes 1 person
Oh yeah, because when two angular momenta ##j_1## and ##j_2## are combined, each state in ##J = j_1 + j_2## ranges from -J to +J in steps of 1.
I keep forgetting that this is a two-angular momentum problem, not a simple one with only spin.
[tex]\delta E = (2j_+ +1)\Delta E_+ + (2j_- +1)\Delta E_-[/tex]
I worked it out, and it appears to be zero.
Related to Zeeman Effect - average shift is zero?
1. What is the Zeeman Effect and what is the average shift?
The Zeeman Effect refers to the splitting of spectral lines in an atom's emission spectrum when placed in a magnetic field. The average shift refers to the average displacement of these spectral lines from their original position.
2. Why is the average shift zero in the Zeeman Effect?
The average shift is zero because for every spectral line that is shifted to a higher energy level, there is another spectral line that is shifted to a lower energy level, resulting in a canceling out of the shifts and an overall average of zero.
3. How does the strength of the magnetic field affect the average shift in the Zeeman Effect?
The strength of the magnetic field directly affects the magnitude of the average shift. A stronger magnetic field will result in a larger split between the spectral lines and a larger average shift.
4. What other factors can influence the average shift in the Zeeman Effect?
The average shift can also be influenced by the energy levels of the electrons in the atom, the orientation of the magnetic field in relation to the atom, and the type of atom being studied.
5. How is the Zeeman Effect used in scientific research?
The Zeeman Effect is used to study the magnetic properties of atoms and molecules, and is often used in spectroscopy to identify and characterize different elements. It has also been used in astrophysics to study the magnetic fields of stars and other celestial bodies.
