Zeeman effect - spin orbit coupling
In summary: Therefore, in summary, the Zeeman effect is the splitting of energy levels, or states, in an atom due to the interaction of the magnetic field with the orbital and spin angular momentum. Initially, only the orbital angular momentum was considered in the calculations, but the discovery of spin was necessary to fully explain the observed splitting in experiments.
Chemist20
86
As far as I know: the possible orientations that the total angular momentum can take (given my Mj) are degenerate. if we apply a magnetic field, degeneracy will be lost and different states arise. this is the zeeman effect
but when looking up on google for zeeman effect, a webpage used as an example the splitting of the ml values por p orbitals. hence it said that in a magnetic field, the three different orientations of the orbital angular momentum would not be degenerate and hence px py pz would have different energies.
What I don't get is why are they talking about orbital angular momentum without including the spin angular momentum and hence talking about L instead of J ?
Many books and courses introduce the Zeeman effect using only orbital angular momentum because it's easier. It also follows the historical development because physicists started to study the Zeeman effect before they knew anything about spin.
Of course, if you don't include spin, you can't explain many actual examples of Zeeman splitting. People talked about the "normal Zeeman effect" (which did fit the orbital-only calculations) and the "anomalous Zeeman effect" (which didn't).
Then Uhlenbeck and Goudsmit "invented" spin, and it turned out to be what was needed to explain the "anomalous Zeeman effect."
great thanks!
so... when technically the 2p level splits into 3 different ones due to the interaction of the orbital angular momentum with the magnetic field, are these three different levels called "states"? because this is the term they use when they talking about splitting of the J levels.
You also have to take in mind what you actually observe in experiment. In an optical transition, e.g. in hydrogen atom from 1s to 2p there is a selection rule Delta S=0. So you will not observe the splitting of the spin but only the splitting of the orbital momentum. Only in heavier elements where spin orbit interaction is important, you will see the splitting due to spin.
I would say that 2p consists of three different states to begin with, with different values of m (-1, 0, +1), and with different wave functions that contain different spherical harmonics. With no external magnetic field, these states are degenerate, that is, they have the same energy. An external magnetic field gives them different energies and removes the degeneracy.
Related to Zeeman effect - spin orbit coupling
1. What is the Zeeman effect?
The Zeeman effect is the splitting of spectral lines in an atom's emission spectrum when it is placed in a magnetic field. This effect was discovered by Dutch physicist Pieter Zeeman in 1896.
2. How does the Zeeman effect occur?
The Zeeman effect is caused by the interaction between the magnetic field and the orbital and spin angular momentum of the electrons in an atom. This leads to the splitting of energy levels and the resulting spectral lines.
3. What is spin-orbit coupling?
Spin-orbit coupling is a quantum mechanical phenomenon where the spin of an electron is coupled with its orbital motion around the nucleus. This coupling is responsible for the fine structure of spectral lines and also plays a role in the Zeeman effect.
4. How does spin-orbit coupling affect the Zeeman effect?
Spin-orbit coupling causes the energy levels of an atom to split further in the presence of a magnetic field. This results in a more complex pattern of spectral lines in the Zeeman effect, with some lines splitting into multiple components.
5. What are the practical applications of the Zeeman effect and spin-orbit coupling?
The Zeeman effect and spin-orbit coupling have several applications in modern science, such as in atomic clocks, lasers, and magnetic resonance imaging (MRI). They also provide insight into the structure and behavior of atoms and molecules, helping us better understand the building blocks of matter.
  • Quantum Physics
  • Quantum Physics
  • Chemistry
  • Quantum Physics
