Zero connection => Zero torsion tensor ?
In summary, the conversation discusses the conditions under which the torsion and curvature tensors vanish, particularly in relation to the vanishing of the connection. It is stated that the connection vanishing in a coordinate basis implies the vanishing of both tensors, but in a non-coordinate basis, the connection may vanish while the torsion remains non-zero. The conversation also mentions the need for a modified formula for the Lie bracket in a non-coordinate basis. The use of Frobenius theorem is also suggested as a possible approach for finding this modified formula.
guhan
43
I am reading a book which says that if the components of the connection vanishes then the torsion and curvature tensors vanish. Now, I understand how this happens with curvature tensor, but I don't see how torsion tensor would vanish.
Torsion tensor:
[tex]\tau (X,Y) = D_X (Y) - D_Y (X) - [X,Y] [/tex]
If connection is zero then [tex] D_X (Y) = D_Y (X) = 0 [/tex].
But this still does NOT make [tex] \tau [/tex] zero right?
This is incorrect; write out the equation in local co-ords(in which connection vanishes) then
(DXY)i = Yi,jXj
The connection is not a tensor, so you can only say it vanishes with respect to certain choices of basis. If it vanishes in a coordinate basis, then since the Lie bracket of coordinate basis vectors vanish, so does the last term in your expression for torsion. On the other hand, in a non-coordinate basis, the last term may contribute.
@ nughret
Oh yes, you are right. It was an oversight on my part.
@ StatusX
I assume you meant to show both when and when not taking the coordinate bases, the statement (torsion vanishes for zero connection) holds. Thank you.
Before closing this thread:
When connection, [tex]\Gamma[/tex], is zero, [tex]Z^i_{;j}=Z^i_{,j}[/tex] and so...
[tex](D_XY - D_YX)^i = X^j Y^i_{;j} - Y^j X^i_{;j} = X^j Y^i_{,j} - Y^j X^i_{,j} = [X,Y]^i[/tex]
And thus the torsion becomes zero.
No, it's possible to have non-zero torsion even if the connection (that is, the connection coefficients with respect to some particular basis) vanishes. In fact, I believe the connection vanishing (in some basis, coordinate or not) is precisely equivalent to the Riemann curvature tensor vanishing, but even if this tensor vanishes there may still be non-zero torsion.
@ StatusX
You are right that zero connection and zero curvature are equivalent. But, I don't understand how zero-connection in some (non-coord) basis can give a non-zero torsion in that same basis. Can you please point out how and why this happens, in the little derivation in my last post?
My interpretation of the question was this:
given any point x in our manifold, given that we can find some chart around x in which the connection vanishes show that the torsion tensor is zero everywhere.
The above posts provide an outline of the proof. If you do not believe such a proof is complete then provide a counterexample
Yes, if you define a chart, and look at the (coordinate) basis related to that chart, then zero connection implies zero torsion. But in the more general case of a non-coordinate basis (ie, one that can't be written in the form [itex]\partial/\partial x^\mu [/itex] for some coordinates [itex]x^\mu[/itex]), one can still talk about connection coefficients, and then it's possible that the connection coefficients vanish in such a basis even if the torsion does not. In fact, from your formula you can see that the torsion will be given by the Lie bracket of the various basis vectors with each other, which is zero iff the basis is coordinate. So any connection which is zero in a non-coordinate basis has torsion.
As far as the derivation in the 4th post, the mistake is at:
[tex] X^j Y^i_{,j} - Y^j X^i_{,j} = [X,Y]^i [/tex]
To be explicit, by [tex]Y^i_{,j}[/itex] you mean [itex]e_j(Y^i)[/itex], ie, the derivative of the scalar function [itex]Y^i[/itex] in the direction of the basis vector [itex]e_j[/itex]. But if we take, eg, [itex]X = e_m[/itex], [itex]Y = e_n[/itex], for some fixed basis vectors, then the functions [itex]X^i,Y^i[/itex] are constant (they are equal to 1 for i=n or m respectively, and zero otherwise), and so the above formula would suggest that [itex][e_n,e_m]=0[/itex], which is only true if this is a coordinate basis. In other words, the formula for the Lie bracket needs to be modified when you're working in a non-coordinate basis. I won't work out here exactly what the new formula is, but hopefully this argument convinces you that it must be something different.
Yes I see your point Status, and as you say the connection vanishing in some basis implies only zero curvature not zero torsion. In regards to the formula for the Lie bracket using Z = [X,Y] if Z(f) = X(Y(f)) - Y(X(f)), gives all required terms.
Using a non commutative basis we then find the extra terms relate directly to the Lie bracket of our basis vectors. If you want to find the explicit formula just write out the above in local coordinates remembering to write our vector field in terms of the non-com basis vectors.
In the case of non-commuting bases, I think there is no reason to believe that we can even find dual bases [tex]\{\omega^i\}[/tex] such that [tex]\omega^i(e_j) = \delta^i_j[/tex] and so modifying the lie bracket formula may not be as direct since we would be left with [tex][X,Y]=[X^ie_i,Y^je_j]=X^ie_iY^je_j-Y^je_jX^ie_i[/tex] and then...?
Can we use Frobenius theorem and say that for any [X,Y] to lie in the tangent space they should be spanned by the coordinate (and hence commuting) bases - [tex]\{ \frac{\partial}{\partial x^i} \}[/tex] - and thus make a transformation [tex]\frac{\partial}{\partial x^i} = A^j_i e_j[/tex]? and then, use this to find lie bracket formula?
PS: Sorry, I didnt notice this thread for long. It somehow didnt show up as updated in my subscribed thread list.
For vector fields V = Viei, W
[V,W] = (VjWi,j - Vi,jWi + VjWkCijk)ei
Where Cijk = ([ej,ek]d we can find these in some neighbourhood by expanding the non-commuting basis in terms of a coordinate basis
How do you get the [tex]V^i_{,j}[/tex] and [tex]W^i_{,j}[/tex] terms?
And, if you are using the structure constants [tex]C^i_{jk}[/tex], then why not use the bilinear property of lie brackets and directly say that [tex][V,W]=V^jW^k[e_j,e_k]=V^jW^kC^i_{jk}e_i[/tex]?
FAQ: Zero connection => Zero torsion tensor ?
What is a torsion tensor?
A torsion tensor is a mathematical representation of the twisting or rotation of an object. It is used in the study of mechanics and is often used to describe the deformation of a solid object.
What does "zero connection" mean in relation to a torsion tensor?
In the context of a torsion tensor, "zero connection" refers to the absence of any connection between the torsion and the metric or curvature of a space. This means that the torsion is not influenced by the geometry of the space it is in.
Why is zero connection important in relation to a torsion tensor?
Zero connection is important because it simplifies the mathematical equations used to describe the torsion. It allows for a more straightforward understanding and analysis of the torsion without the added complexity of considering its connection to the geometry of the space.
What is the significance of a zero torsion tensor?
A zero torsion tensor means that there is no twisting or rotation present in an object. This can have important implications in the study of mechanics, as it indicates that the object is not being subjected to any external forces or torques that would cause it to twist or rotate.
How is a zero torsion tensor related to symmetries?
A zero torsion tensor is often related to symmetries in a system. This is because symmetries often lead to the absence of external forces or torques, resulting in a zero torsion tensor. In other words, symmetries can contribute to the overall stability and lack of deformation in an object.
