Zero Crossing Point of ac cycle
In summary: The human eye is sensitive - if you have a neon lighted wall...it will look like it is on even if you flip the switch on the wall.
challarao
How can equipments work in ac current even it is oscillating from +ve to -ve and to zero?
Alternating current is alternation of positive and negative values.If we consider the sinusoidal case,the current value becomes zero,negative,positive in a cycle.In that case,how can electrical equipment can work without any interruption at zero value.For example,a tungsten bulb should blink continuously in every cycle of current.Please explain and correct if I am incorrect!
Thanks in advance!
Well it does blink. But the filament doesn't have a chance to cool off (much). That and the eye has a hard time seeing flickering above about 30Hz.
Here's some animations that might help when it comes to alternating current:
http://www.animations.physics.unsw.edu.au/jw/electricmotors.html"
I was once required to document the light dimming effects that different types of motors / loads / start up capacitors had. This is fairly important because if it becomes significant, people object when their appliances come on...
Anyway, the weird part. The sensor not only picked up the dimming of the bulbs, but also, a very discernable 120Hz sine wave (only when exposed to the light). It was a difficult argument to make with my fellows, but I do believe that there is a discernable temperature induced flicker in many incandescent lamps.
- Mike
Why is this a surprise? It makes perfect sense.
In workshops where rotating machinery is used, it is common to use low voltage / high current worklamps. These have relatively massive filaments (lots of thermal inertia), for the same wattage and the flicker is a lot less than for mains voltage lamps. Using lamps with less flicker reduces the strobe effect that can lead to people wrongly assuming things are still when they are, in fact, spinning. Fluo tubes are even worse, of course.
What is the difference between manual interruption by switching on and off,and the zero crossing point?.I think the wearing of the equipment occurs when we switch on and off.
Is there any sensitive device which cannot even bear the such a small time interruption of zero crossing point?
Any change of voltage is the same. As for the "small time of interruption", many radio receivers can detect variations in voltage as short as 1 nanosecond. Is that quick enough for you?
AC can be used to run rotating motors and resistive heaters and such, but for electronic things like TVs, computers, etc, the AC is rectified and smoothed to turn it into constant DC current, so there is no zero crossing.
Thanks for your reply...
I visited this link http://www.animations.physics.unsw.edu.au/jw/electricmotors.html"
and found a graph of DC voltage...though there is no negative cycle...graph touches the x-axis for every cycle which means that it does have zero value for every cycle...
I think it is also a zero crossing, is n't it?
That "DC" you refer to (Rectified AC, probably) is better described as 'Unidirectional'. The term DC normally refers to a constant value - as you get from a battery. 'Raw DC' is not much use for anything but battery charging.
Rectified AC will have no zero crossing (if the rectifier is any good) as it will not go actually through zero.
I referred the graph of a DC generator...
Thank you...
OK. Don't see many of those around these days because they are nothing like as good as alternators with rectifiers. That's why I didn't consider it.
But my remark still applies about it being unidirectional rather than DC. To describe the waveform accurately, you would say that the it has a DC component, a fundamental AC component and a number of harmonics of the fundamental AC frequency.
But it doesn't do to get too bogged down with semantics.
There's still some 20 hz power around Niagara Falls. You can plainly see the incandescent lights flickering. That's about the fastest an eye can resolve, and why television is thirty frames a second.
Human eye is sensitive - if you have a neon lighted wall switch or a strobed display on your electronic alarm clock you'll see a series of dots when your eye moves across it in the dark.
Same effect on these darned newfangled automobile taillights - they're a real annoyance when driving at night.
old jim
old jim
I couldn't agree more.
That's why I said it's rectified and smoothed. Though "filtered" would be the more accurate term. Those large dips are smoothed out with a capacitor and usually a regulator of some kind to reduce the ripple as much as possible.
FAQ: Zero Crossing Point of ac cycle
What is the Zero Crossing Point of an AC Cycle?
The Zero Crossing Point of an AC Cycle is the point at which the voltage or current of an alternating current (AC) waveform crosses the zero axis. This occurs twice per cycle, as the waveform moves from positive to negative and then back to positive again.
Why is the Zero Crossing Point important?
The Zero Crossing Point is important because it marks the transition from positive to negative or vice versa in an AC waveform. This point is used as a reference for measuring the frequency and period of the AC signal, as well as for triggering circuits and devices that need to operate at specific points in the waveform.
How is the Zero Crossing Point calculated?
The Zero Crossing Point can be calculated by dividing the period of the AC cycle by 2. This is because the Zero Crossing Point occurs twice per cycle, once when the waveform is at its maximum positive value and once when it is at its maximum negative value. For example, if the period of the cycle is 20 milliseconds, the Zero Crossing Point would occur at 10 milliseconds.
What is the significance of the Zero Crossing Point in power systems?
In power systems, the Zero Crossing Point is used to synchronize the operation of different devices and equipment. This allows for efficient and coordinated power distribution and helps prevent damage to equipment due to sudden changes in voltage or current. Additionally, the Zero Crossing Point is used in power factor correction to improve the efficiency of power transmission.
Can the Zero Crossing Point be adjusted?
Yes, the Zero Crossing Point can be adjusted by using devices such as phase-shifting transformers or variable frequency drives. These devices can alter the frequency and phase of the AC signal, which in turn affects the location of the Zero Crossing Point. This allows for better control and management of power systems.
