Zero Hamiltonian and its energies
In summary: After a quick look at that it seems that the reparametrisation is just a change from \tau to u, and the fact that the lagrangian is independent of the particular shape of the curve means there is a 'constraint' on the 'possible curves' (which is just a restatement of the fact that the lagrangian is independent of the path taken?).This constraint reduces the degrees of freedom and so we can't find a unique solution from the equations of motion. This is a bit like a potential well in a potential energy graph: different points have different potential energies but the same kinetic energy. This means that we can't recover the path taken from the kinetic energy because a single KE corresponds to many PE. So
  • #36
dextercioby said:
Usually, second order derivative terms in the HE action can be removed by a part integration. See Dirac (1975) for details.
Daniel.
I guess you need to demand in such cases that spacetime is asymptotically static; in either that [tex] \partial_t g_{\mu \nu} = 0 [/tex] in the infinite past and infinite future (in some a priori chosen coordinate time t).
  • #37
Of course, in fact Dirac didn't mention this assumption. He just used it to get a better looking Lagrangian and a faster way to derive the field eqns. Actually, a boundary term occurs which can be set to 0, iff your assumption is validated.
Daniel.
  • #38
Daniel.
But that would kill off asymtotically de Sitter universes. I guess you do not want that.
  • #39
And to get the Semi-classical Energies..could we make or use Bohr-Sommerfeld formula?..i mean:
[tex] \oint_{S}d^{4}x \pi _{ab}=\hbar (n+1/2) [/tex]
where S is an hyper-surface, and the "pi's" are the conjugate momenta to the metric g_ab, could we from this expression get the energies? :confused: :confused:
  • #40
Which is weird because such solutions are solutions (excuse the tautology) of the field equations one derives by making such an assumption. :rolleyes: :biggrin:
Daniel.
  • #41
Daniel.
I was merely worried about the fact that de Sitter allows for no global timelike Killing field and that therefore any such construction involves a cosmological horizon associated to one worldline I guess :-p (since the metric gets degenerate in such coordinate systems). Therefore, it seems you cannot apply this trick to get out full de Sitter, that is all I meant (working in special coordinate systems can be pretty dangerous, at least that is how I understood your comment about Dirac's trick).
