Zeros of Euler's equation, y''+(k/x^2)y=0
In summary, the given equation has two solutions for y, which can be written as a composition of sines and cosines for k>1/4. When k=1/4, the equation has two additional solutions that can be shown to be linearly independent. This leads to infinitely many positive zeros for k>1/4 and finitely many positive zeros for k\le 1/4. Alternative approaches are welcome.
Combinatus
42
Show that every nontrivial solution of [itex]y''+\frac{k}{x^2}y=0[/itex] (with [itex]k[/itex] being a constant) has an infinite number of positive zeros if [itex]k>1/4[/itex] and only finitely many positive zeros if [itex]k\le 1/4[/itex].
I set [itex]y=x^M = e^{M \log{x}}[/itex] (for some constant M), differentiated twice and put it back into the equation, which gives [itex]M=\frac{1\pm \sqrt{1-4k}}{2}[/itex]. So, [itex]y_1 = x^{\frac{1}{2} (1+\sqrt{1-4k})}[/itex] and [itex]y_2 = x^{\frac{1}{2} (1-\sqrt{1-4k})}[/itex] solves [itex]y''+\frac{k}{x^2}y=0[/itex].
The Wronskian seems to be identially nonzero, so then every solution of [itex]y''+\frac{k}{x^2}y=0[/itex] can be written as [itex]y = C_1 x^{\frac{1}{2} (1+\sqrt{1-4k})} + C_2 x^{\frac{1}{2} (1-\sqrt{1-4k})}[/itex].
The "finitely many positive zeros if [itex]k\le 1/4[/itex]" part follows, but I'm not sure about the "infinite number of positive zeros of [itex]k>1/4[/itex]" part. Obviously the exponents are complex numbers that avoid the real and imaginary axes in that case.
Any other approaches?
I solved it, I think. [itex]y = C_1 x^{\frac{1}{2} (1+\sqrt{1-4k})} + C_2 x^{\frac{1}{2} (1-\sqrt{1-4k})}[/itex] could be written as the composition of sines and cosines of (the monotonic function) [itex]\ln x[/itex] when [itex]k > 1/4[/itex] with a preceding (monotonic) factor [itex]e^{\ln \sqrt{x}}[/itex], so [itex]y[/itex] should have infinitely many solutions in that case.
It turns out that [itex]k=1/4[/itex] makes the Wronskian vanish, so with a bit of effort, [itex]y_3 = x^{1/2}[/itex] and [itex]y_4 = x^{1/2} \ln x[/itex] can be found, which can be shown to be linearly independent solutions in this case. The general solution when [itex]k=1/4[/itex], then, has finitely many zeros in [itex]x>0[/itex].
I think this was somehow a stupid and overly lengthy approach to the problem, though, so suggestions for alternatives are welcome!
Related to Zeros of Euler's equation, y''+(k/x^2)y=0
What is Euler's equation?
Euler's equation is a second-order ordinary differential equation of the form y''+(k/x^2)y=0, where k is a constant.
What are the zeros of Euler's equation?
The zeros of Euler's equation refer to the values of x for which the solution y(x) is equal to zero.
How do you solve Euler's equation?
Euler's equation can be solved using various methods such as the power series method, the Frobenius method, or by converting it into a first-order system of equations.
What is the significance of Euler's equation in mathematics?
Euler's equation is a fundamental equation in mathematics and has applications in various fields such as physics, engineering, and finance. It also serves as a basis for more complex differential equations.
Are there any real-world applications of Euler's equation?
Yes, Euler's equation has numerous real-world applications, such as in the study of oscillations, vibrations, and other physical phenomena. It is also used in the field of electrical engineering to model circuits and in finance to calculate interest rates.
