What is the Zeroth Law of Thermodynamics and why is it causing confusion?
In summary, Professor stated that "0th law of thermodynamics: If two subsystems I,II are separately in thermal contactwith a third system, III, then they are in thermal equilibrium with each other." If two systems are in physical contact with each other, then they are in thermal equilibrium.
Jansen
This is not a homework problem. I want to relay a statement made by my professor. From his online script:
He stated this in class and I protested because I have always heard that system I and II must seperately be in thermal equilibrium with system III. He basically told me it didn't matter it means the same. I don't see how though, if I have three systems, eg bricks. One is in a freezer, one is in an oven and brick III is at room temperature. I take all bricks out and put I and II in contact (here I am considering thermal contact as physical contact) with brick III but not each other. Brick I and brick II are most certainly not in thermal equilibrium.
Can you guys help me? What am I missing?
"Thermal contact" is/means "thermal contact."
They will be, in time. As long as heat can flow from brick I to brick II (or vice versa) using brick III as a medium, they are considered to be in thermal contact. It does not mean physical contact, as u/Bystander pointed out.
I think prof means equilibrium, not just contact. Perhaps if you bring it in a bit tactically (e.g. as a question) he can overcome his hesitation.
Your "Brick I and brick II are most certainly not in thermal equilibrium" I can only agree with -- until both equilibria ( I and III and III and II ) are established.
'All' our thermodynamics is equilibrium thermodynamics...
I will reply to every one with one message instead of individually.
First u/bystander, I do not like to say that thermal contact means thermal contact. This means thermal contact can mean anything which is not true, or that meaning of the word thermal contact is irrelevant which is also false. Two systems are said to be in thermal contact if they can exchange energy with each other through the process of heat. Now this does not necessarily mean that the two systems must have physical contact. For example, a cake is not in physical contact with the heating element of an oven but it is in thermal contact because the energy of the heating element is transferred into the cake by a process called heat via the medium of the air contained in the oven. I stated I am taking thermal contact here to mean physical contact because it was the method I chose to establish thermal contact in my example. Physical contact is, indeed, a meathod by which one system can exchange energy with another by the process of heat. If you don't believe me I propose an experiment. Turn on your stove and leave it for 5 minutes after 5 minutes establish physical contact with the stove with your hand. Then see if any energy is exchanged. :)
u/JeremyG Yes, I know that in time themal equilibrium will be reached. Probably as governed by Fourier's law. That is not what the law as my professor says. The quotation I posted is precicely what is in his script and precicely what he said in lecture. As I said before I chose physical contact as a method in which thermal contact could be established.
u/BvU I did ask him that. I said, "when you say system I and system II are in thermal contact with system III should they not also be in thermal equilibrium with system III?" His reply was to laugh and throw his hands up in the air and said, " this is not a precise definition, we haven't defined system, thermal contact or thermal equilibrium." My belief is that you can use words and words mean things and depending on how you string those words together it is a true statement, a false statement or a (sorta) true statement. The implication of saying that when two systems are in thermal contact (seperately) with another system then they are in thermal equilibrium means that thermal contact and thermal equilibrium are two distinct ideas. I guess, what he means is similar to what you have said which is that they are in some sort of contact and some time has passed and all systems have equal energy so energy transfer by heat no longer occurs. However, when I asked weather that was true he did not answer but instead scoffed at me. What I assume that means is I am missing something or it is stupid to believe that the clarification of equilibrium being reached is necessary for the statement to be true. I am wondering if my interpretation of the two statements:"0th law of thermodynamics: If two subsystems I,II are separately in thermal contact with a third system, III, then they are in thermal equilibrium with each other."
Reference https://www.physicsforums.com/threads/zeroth-law-of-thermodynamics.848448/#post-5319998
and
0th law of thermodynamics: If two subsystems I, II are separately in thermal equilibrium with a third system, III, then they are in thermal equilibrium with each other."
are, in fact, equivilent statements or not. If they are equivilant does that then mean thermal contact implies that there is some time associated with it? IE the time that it takes to achieve thermal equilibrium?
Edit: In the interest of completeness this is the script (p 83): http://home.uni-leipzig.de/tet/wp-content/uploads/2015/02/datei.pdf From what I can tell of the mathematical description of what follows it appears that thermal contact and thermal equilibrium are used interchangeably.
We distinguish equilibrium thermodynamics from something one could call non-equilibrium thermodynamics. You are learning equilibrium thermodynamics. There thermal contact means equilibrium.
Teacher should be able to explain this to you without having to resort to laughing and scoffing. It seems to me you two are in an all out fight. No one will be better off because of it; perhaps you can assume part of the responsiblilty for improvement of the relationship. To me you appear to be smart enough to do so.
Related to What is the Zeroth Law of Thermodynamics and why is it causing confusion?
1. What is the Zeroth law of thermodynamics?
The Zeroth law of thermodynamics states that if two systems are in thermal equilibrium with a third system, then they are also in thermal equilibrium with each other. This means that if two objects have the same temperature as a third object, they also have the same temperature as each other.
2. Why is it called the "Zeroth" law?
The Zeroth law was named as such because it was the last of the laws of thermodynamics to be formulated. The first and second laws were already established, so this law was named the "Zeroth" to maintain the numerical sequence.
3. What is the significance of the Zeroth law in thermodynamics?
The Zeroth law is significant because it allows us to define and measure temperature. Without this law, it would be impossible to compare the temperatures of different objects or determine when thermal equilibrium has been reached.
4. How does the Zeroth law relate to the other laws of thermodynamics?
The Zeroth law serves as a foundation for the other laws of thermodynamics. The first law, which states that energy cannot be created or destroyed, is based on the concept of thermal equilibrium established by the Zeroth law. The second law, which describes the direction of heat flow, also relies on the concept of thermal equilibrium.
5. Can the Zeroth law be violated?
No, the Zeroth law is a fundamental principle of thermodynamics and has been extensively tested and proven to hold true in all systems. Violating the Zeroth law would result in a violation of the first and second laws as well, which are well-established and widely accepted.
  • Thermodynamics
  • Thermodynamics
