Zinc metal is added to hydrochloric acid to generate.......
In summary, based on the information given, there are 0.0681 mol of hydrogen gas present in the sample.
AMan24
58
Please don't ignore the template.
Zinc metal is added to hydrochloric acid to generate hydrogen gas and is collected over a liquid whose vapor pressure is the same as that of pure water at 20.0°C (18 torr). The volume of the mixture is 1.7 L, and its total pressure is 0.987 atm. Determine the number of moles of hydrogen gas present in the sample.
a.
0.272 mol
b.
0.04 mol
c.
0.997 mol
d.
0.139 mol
e.
0.0681 mol
So there's some container with a volume of 1.7L and pressure of 0.987... The amount of hydrogen and the other substance in the container are unknown. We also know that the other substance has the same pressure as water does at 20C, (i don't think we use the temperature to find the solution)... And we know the pressure of the other substance is 18torr.
Note; I'm not sure if the question is saying the pressure of water/the substance at 20C is 18torr. Or if the temperature of the substance is the same as water when the substance is 20C.
Assume total pressure is the sum of partial pressure of the liquid and hydrogen.
So convert 18 torr to atm = 0.0236 atm.
P total = P1 + P2...
0.987atm = 0.0236atm + P2...
P2=0.9634.
So now i know the pressure of the hydrogen. The unknowns are the volume of the other substance and the hydrogen. Thanks for the help with this step!
Ok so now its PV=nRT and the answer is 0.0681 mol
I got it, you can get it, fairly fast thinking:
that's essentially atmospheric pressure and one of the several physical numbers it is useful to remember (was dinned into us at school) is 1 mole gas is 22.4 L (at stp). Water vapour pressure? - negligible by comparison. Thinks of inverted full test tube, you leave it for a time, get a quite small bubble at top, showing this quite small. (Right thinking? :olduhh: ) . Still don't actually remember what a torr is, look up, ah we used to call that 1 mm of mercury. But remember, also from school barometer. 1 arm = 760 mm Hg. So verified neglible for this purpose.
So 1.7 L is 1.7/22.4 mole, awkward. But it's somewhat less than a tenth. b is quite a lot less, all the others are more, e looks right.
(Wasn't such a bad school if I can hack that at this distance.).
Related to Zinc metal is added to hydrochloric acid to generate.......
1. What is the purpose of adding zinc metal to hydrochloric acid?
The purpose of adding zinc metal to hydrochloric acid is to generate a chemical reaction that produces hydrogen gas and zinc chloride.
2. What is the chemical equation for the reaction between zinc metal and hydrochloric acid?
The chemical equation for this reaction is: Zn + 2HCl → ZnCl2 + H2
3. How does the addition of zinc metal affect the pH of hydrochloric acid?
The addition of zinc metal to hydrochloric acid lowers the pH, making the solution more acidic.
4. Can any other metals be used in place of zinc for this reaction?
Yes, other metals such as magnesium or iron can also be used in place of zinc for this reaction, but the products and reaction rate may differ.
5. Is this reaction exothermic or endothermic?
This reaction is exothermic, meaning it releases heat energy as a product of the reaction.
16K
11K
12K
