Zirconium Versus Zirconium Carbide For Use With Galinstan
  • Thread starter evansste
  • Tags
    Conductor
In summary, the comparison between zirconium and zirconium carbide for use with Galinstan focuses on their properties, performance, and compatibility. Zirconium exhibits good corrosion resistance and thermal stability, making it suitable for applications involving Galinstan, a liquid metal alloy. Zirconium carbide, on the other hand, offers superior hardness and higher melting points, potentially enhancing durability in high-temperature environments. The choice between the two materials depends on specific application requirements, such as mechanical strength, thermal conductivity, and resistance to oxidation.
evansste
I'm planning on working with galinstan, for one of my projects. I need a conductor that can be immersed in the galinstan, indefinitely, without being corroded.
I've learned that zirconium carbide has excellent chemical resistance, when it comes to galinstan. However, no one seems to sell it in the form of a wire. On the contrary, it is possible to buy zirconium wire.
Does anyone know whether or not zirconium has the same, or similar, chemical resistance traits as zirconium carbide? If not, is anyone aware of any other metals, that can be bought in sheets or wires, that don't react with galinstan?
Thanks for your time. I look forward to any advice, or guidance, that anyone is willing to provide.
Chemistry news on Phys.org
How about graphite? You can use the mine of a pencil.
Thanks, DrDu.
Graphite may be an alternative. However, it seems a bit fragile. As of now, I've decided to go with 316 stainless steel.
When I first started researching galinstan, it seemed as if it reacted with nearly all metals. I stumbled accross the following document, which shows that it doesn't react with zirconium carbide:
https://www.diva-portal.org/smash/get/diva2:728422/FULLTEXT01.pdf
After having trouble finding zirconium carbide wire, I continued to do more digging. Ultimately, I found the following link, which showcases research that suggests that galinstan is non-reactive with stainless steel, as long as you stick with temperatures below 200C:
https://tspace.library.utoronto.ca/bitstream/1807/102601/1/cjc-2020-0227.pdf
Because I intend to use my galinstan at room temperature, and because stainless steel is readily available, and has excellent physical properties, I've chosen to use it.
Thanks for taking the time to respond to my question. I greatly appreciate your willingness to help.
Um, 'stainless' steel may not remain so due to electrolysis...
However, IIRC, there is 'graphite' and graphite: The higher density stuff, perhaps carbon fibre in web or tube form, may suit. Also, be readily sourced, reproducible and predictable. FWIW, a tubular strut, either for eg R/C modelling or a fishing rod would likely have the strength to hold its shape while pushing into the dense metal fluid...
Thanks for your input, Nik_2213.
I appreciate you mentioning the side effect of electrolysis. However, it still makes me wonder why stainless steel wouldn't continue to be suitable.
I've watched a few YouTube videos of experimenters choosing to use stainless steel for electrodes, when building their electrolysis machines. It tends to be their material of choice. Here's one, that I've watched:
The above is just one video. Perhaps it's the material of choice, in many YouTube videos, due to it's easy availability.
I wouldn't be surprised if a lot of these YouTube videos aren't performed by actual chemists. However, I'm also intrigued by their level of experience. They're actually building these things, and are showing the results, online.
On the other hand, your comment caused me to dig a little deeper, which resulted in me finding the following; which warns against using stainless steel:
https://antique-engines.com/stainless-steel-electrodes.htm
And then I found this; which, also, talks about graphite, and makes me wonder about titanium:
https://www.quora.com/Are-graphite-electrodes-the-best-to-use-in-electrolysis
Finally, the following link gives great support for graphite/graphene:
https://www.diva-portal.org/smash/get/diva2:736871/FULLTEXT01.pdf
So, based on all of this, your suggestion of graphite, in proper form, should be good.
Likes Nik_2213
After giving this further thought, I began to wonder if electrolysis will even take place, between galinstan and another metal; such as stainless steel. After all, I'm dealing with metal in galinstan, not water.
As it turns out, someone has already performed research, on this issue, and the result is that, with stainless steel, I need not worry about corrosion, or electrolysis.
Here's a link, for anyone who's interested:
https://pubs.acs.org/doi/abs/10.1021/acsaelm.0c00551
Likes Tom.G and Nik_2213
FAQ: Zirconium Versus Zirconium Carbide For Use With Galinstan
1. What are the main differences between zirconium and zirconium carbide?
Zirconium is a metallic element known for its corrosion resistance and high melting point, while zirconium carbide is a ceramic compound that exhibits high hardness, thermal stability, and excellent wear resistance. The primary difference lies in their physical and chemical properties, with zirconium being more ductile and malleable compared to the brittle nature of zirconium carbide.
2. Why is Galinstan used in conjunction with zirconium and zirconium carbide?
Galinstan, a liquid metal alloy composed of gallium, indium, and tin, is used for its excellent thermal conductivity and low toxicity. It is often considered for applications involving heat transfer or as a coolant. Both zirconium and zirconium carbide can provide structural support and thermal stability when used in systems utilizing Galinstan.
3. Which material has better thermal conductivity for use with Galinstan?
Zirconium generally has better thermal conductivity than zirconium carbide. While zirconium carbide has excellent thermal stability, its thermal conductivity is lower compared to metallic zirconium. Therefore, for applications requiring efficient heat transfer, zirconium may be the preferred choice when used with Galinstan.
4. How do zirconium and zirconium carbide perform in corrosive environments with Galinstan?
Zirconium exhibits outstanding resistance to corrosion, particularly in acidic environments, making it suitable for applications involving Galinstan. Zirconium carbide, while also resistant to oxidation and thermal degradation, may be more susceptible to chemical attack in certain environments. Therefore, zirconium is often favored for highly corrosive applications.
5. What are the mechanical properties of zirconium versus zirconium carbide when exposed to Galinstan?
Zirconium has good ductility and tensile strength, allowing it to withstand mechanical stress without fracturing. In contrast, zirconium carbide is extremely hard and can endure high temperatures but is brittle and may fracture under stress. The choice between the two materials will depend on the specific mechanical demands of the application involving Galinstan.
