Zwitterion and isoelectric point
  • Thread starter weng cheong
  • Tags
    Point
In summary, a zwitterion is a neutral molecule with both a positive and negative charge in different locations. The isoelectric point refers to the pH at which the molecule carries no net electrical charge. At the isoelectric point, amino acids neutralize themselves by bonding H+ ions to the amino group. Below the IEP, the molecule is positively charged due to an excess of H+ ions, and above the IEP, it is negatively charged due to a deficiency of H+ ions. In an acidic environment, the protein may become more positively charged, but this can vary depending on the specific protein and its protonation at a given pH.
weng cheong
zwitterion is defined as is a neutral molecule with a positive and a negative electrical charge (n.b. not dipoles) at different locations within that molecule.
while
isoelectric point means pH at which a particular molecule or surface carries no net electrical charge.
does it mean that amino acid exist as zwitterion at isoelectric point?
Chemistry news on Phys.org
Yep.
Yeah at the isoelectric point, amino acids neutralise themselves because H+ ion from the carboxyl group bonds to the amino group. Below the IEP there is an excess of H+ ions floating around so the carboxyl group gets its proton back leaving the molecule positively charged. Above the IEP there is a deficiency of H+ ions so the acid group loses its proton leaving the molecule negatively charged.
So if the protein is in an environment that is below its pI, it will be positive, but the more acidic the environment becomes does the protein continue to get 'more positive'? Or does it not work like that?
To some extent it works this way. Note that protein (especially a large one) can be often protonated in more than one position. Also note that while it is impossible for a single protein to have a fractional number of protons attached, at equilibrium some proteins would be protonated and some would be not, so we can say things like "because of protonation at this pH XYZ protein has on average a positive charge of 2.35".
Thaaaaanks
Related to Zwitterion and isoelectric point
1. What is a zwitterion?
A zwitterion is a molecule or ion that has both positive and negative charges, making it electrically neutral overall. This is due to the presence of both an acidic and a basic functional group in the molecule.
2. How is a zwitterion formed?
A zwitterion is formed when a molecule with both acidic and basic functional groups is dissolved in a polar solvent, such as water. The polar solvent causes the molecule to dissociate, forming both positive and negative charges.
3. What is the significance of zwitterions in biological systems?
Zwitterions are important in biological systems because they are often found in amino acids, the building blocks of proteins. The charged nature of zwitterions allows them to interact with other molecules and play a role in various biochemical processes.
4. What is the isoelectric point (pI) of a zwitterion?
The isoelectric point (pI) of a zwitterion is the pH at which the molecule has an overall neutral charge. At this point, the positive and negative charges cancel each other out, and the molecule does not migrate in an electric field.
5. How is the isoelectric point (pI) of a zwitterion determined?
The isoelectric point (pI) of a zwitterion can be determined experimentally by measuring the pH at which the molecule has no net charge. This can be done through techniques such as electrophoresis or titration. It can also be predicted using mathematical equations based on the pKa values of the acidic and basic functional groups in the molecule.
  • Classical Physics
