Automatic/standard transmission
In summary, a hybrid transmission works by using 2 clutches to launch the car, and then shifting is done via levers and no further clutching is necessary.
avemt1
93
How does a hybrid transmision work?
Both automatic and standard
When I hear "hybrid transmission", I can only think of a transmission that can transfer torque to a drivetrain from either a combustion engine, an electric motor, or both, for a hybrid gas-electric vehicle. But I think these typically are automatic transmissions for the actual gear shifting.
Perhaps this is what you're asking about?
http://auto.howstuffworks.com/sequential-gearbox.htm
I was thinking along the lines of a transmission that uses a clutch to launch the car, but once in motion shifting was done via levers and no further clutching was necessary;
http://www.lencoracing.com/racetr%7E1.htm
I also recall a piece of farm equipment manufactured by White. I don’t remember for certain but believe there was no clutching involved at all. On the dash was a shifter with five forward positions. First, the driver would select low gear, and after the vehicle sped up a tad the transmission would shift into a higher gear by itself. As your speed continued to increase the driver would have to move the shifter to the next higher gear, and again the transmission would respond with another automatic shift of its own at the appropriate time. So, in all there were 10 forward gears; 5 of which had to be selected manually and 5 that would shift automatically.
It just occurred to me that you were asking about transmissions for hybrid (both combustion and electric motors) vehicles and not a transmission that is both automatic and manual. (That concept confused me.)
Typically, the transmissions for hybrid vehicles utilize 2 clutches, so that the electric motor can work independantly or in concert with the combustion motor. There are 3 basic types of transmissions for hybrid vehicles, parallel, series, and a combination of parallel/series.
Some links:
http://www.ford.com/en/innovation/engineFuelTechnology/modularHybridTransmission.htm
http://www.autofieldguide.com/articles/129805.html (from 1998)
avemt1 needs to come back and reply.
J-Man,
Don’t they also have those hybrid cars like the Toyota Prius that only use an electric motor to power the transmission, with the gas motor being more like a battery charger?
[edit]
Oops, I should have checked your link before posting.
Originally posted by BoulderHead
J-Man,
[edit]
:wink:
For the hyper-link challenged, the answer is yes. It's the serial configuration mentioned previously. The parallel configuration uses one or both of the motors to propel the vehicle. The "composite configuration" (I just made up that term) can do both.
Sorry for the long wait. I Never recived e-mail notification until today.
As of what I ment J-Man answered that by giving me information on the Sequential Transmission. My concept was all wrong. And the hybrid transmissions were very interesting.
I than you for all your help
Related to Automatic/standard transmission
1. What is the difference between an automatic and a standard transmission?
An automatic transmission uses a torque converter to shift gears automatically, while a standard transmission uses a clutch and gear shifter to manually select gears.
2. Which type of transmission is better?
There is no clear answer to this question as it ultimately depends on personal preference and driving habits. Automatic transmissions are easier to use and more convenient, while standard transmissions offer more control and better fuel efficiency.
3. How do I know if my car has an automatic or standard transmission?
The easiest way to tell is by looking at the gear shifter. If there are only two pedals (gas and brake) and the gear shifter has options for Park, Reverse, Neutral, and Drive, then it is an automatic transmission. If there is a third pedal (clutch) and the gear shifter has numbers for each gear, then it is a standard transmission.
4. Can I switch from an automatic to a standard transmission or vice versa?
This is possible, but it would require significant modifications to the car's engine and transmission system. It is not recommended unless you have extensive knowledge and experience with car mechanics.
5. How often should I get my transmission serviced?
It is recommended to get your transmission serviced every 30,000 to 60,000 miles. However, this can vary depending on the make and model of your car, so it is best to consult your owner's manual for specific recommendations.
  • General Engineering
  • Electrical Engineering
  • Quantum Physics
