Can a car's reaction to gas pedal be said to be stable ?
In summary, a car that is driven in a stable manner will maintain a set speed, even if the power input is increased a little. If the power input is increased too much, the speed of the car will fall and the car will stall.
Gauzi
As per control theory, if a bounded input produces a bounded output then a system can be said to be stable. So assuming that I press my cars gas pedal such that it reaches a fixed position, then the reaction of my car would be to reach a corresponding velocity, and assuming the road to be even sloped and no other disturbances acting on my car, my car would maintain certain fixed velocity. So in this case can i say that my system ( car) is stable ?
Setting gas pedal to a specific position will cause car to accelerate until a desired or limiting condition of speed is reached .
Generally gas pedal is then adjusted to a position where car runs steady state at speed achieved after acceleration .
There is human feedback in the system .
Without human feedback this type of control system does not work at all .
Stability depends on skills of driver . Overall response may be stable or unstable .
With modern car controls and average driving skills system is usually reasonably stable .
Older members though will remember the antics of cars starting off from traffic lights with poorly trained drivers and cruder car controls in the 1960's and earlier !
Things are more complex than you might think. The “gas pedal” is usually an opening “throttle”. It allows air to flow through the carburettor which draws fuel in with the air to the engine. As the car runs faster, the engine also runs faster so the throttled airflow will also change.
The air to fuel ratio is set by the carburettor to be stoichiometric which gives full combustion.
On a petrol engine, cruise control is an electronic system that regulates road speed by continuously adjusting throttle opening. It has a difficult job as the road rises and falls with crests and dips.
A diesel injection pump on the other hand usually has an internal governor. It adjusts the fuel volume injected between minimum and maximum settings determined by the difference between the position set by the drivers foot and the actual engine RPM.
The diesel engine always takes in as much air as possible. The volume of fuel injected is adjusted by the injection pump. Too much fuel for the engine conditions, cold engine or blocked air filter, will produce black smoke.
Cruise control on a diesel can be a simple hand control that sets the required speed against the injection pump speed governor position at that speed.The speed of a petrol engine includes the driver in the speed control circuit feedback.
The speed of a diesel engine replaces the driver with an injection pump governor in the speed control circuit.
If the pedal is fixed, there is no feedback mechanism at work, so I think you have an open loop control system which is in a stable condition. If the power input increases a little the speed will also go up a little. But it does not run away. If it were a closed loop control system, for instance if cruise control was fitted, then the change in speed would be zero after a few seconds.
When a car "stalls", the open loop has become unstable, so that an increased load has brought the engine to a lower speed where the torque curve is falling. Then feedback is required from the driver, making a closed loop, to prevent the engine from stopping.
Related to Can a car's reaction to gas pedal be said to be stable ?
1. Can you explain what stability means in the context of a car's reaction to the gas pedal?
Stability refers to the ability of a car to maintain a consistent and predictable response to the gas pedal. This means that the car's acceleration should be proportional to the amount of pressure applied to the gas pedal, without sudden or unexpected changes.
2. How can a car's reaction to the gas pedal be measured and quantified?
A car's reaction to the gas pedal can be measured by monitoring the car's acceleration using sensors and recording the data. It can then be quantified by analyzing the data and determining the relationship between the gas pedal input and the resulting acceleration.
3. What factors can affect the stability of a car's reaction to the gas pedal?
Several factors can affect a car's reaction to the gas pedal and its stability. These include the condition of the car's engine, the type of fuel being used, the weight of the car, and external factors such as road conditions and weather.
4. Can a car's reaction to the gas pedal be improved or adjusted?
Yes, a car's reaction to the gas pedal can be improved or adjusted through regular maintenance and tune-ups, proper fuel and oil changes, and adjustments to the car's engine and transmission systems. Additionally, driving techniques such as smooth and consistent pressure on the gas pedal can also improve the stability of a car's reaction.
5. How does a stable reaction to the gas pedal contribute to overall driving safety?
A stable reaction to the gas pedal is crucial for driving safety as it allows the driver to have better control over the car's acceleration. A car with an unstable reaction to the gas pedal can be difficult to handle and may result in sudden or unexpected changes in speed, increasing the risk of accidents. A stable reaction also allows for smoother and more predictable driving, reducing the chances of losing control of the vehicle.
  • General Engineering
11K
10K
