- #106
- 3,134
- 7,807
I was actually referring to the general case of a sound wave crossing a shock wave. In fact, it is the general consensus in this thread (except maybe for @fizzy ) that no sound waves emitted by the airplane will ever reach the front shock wave.256bits said:What?
Sound from the plane eventually becomes part of the shock wave
Consider by traveling through, it would come out the other side at Mach 2 into the oncoming stream of fluid.
Surely that cannot be a possibility.
Leaving the sonic wedge is impossible.
Ma is the Mach number of the moving object, which is the object velocity divided by the local speed of sound.256bits said:
Yeah, I guess that was too strong of a statement.
I clarify it to mean that since sound moves at Mach1, and the shock is moving away at a speed of subsonic velocity M2 ( less than Mach 1) , then depending upon the angle α which is a function of velocity v of the object, the arc angle ( for the picture ) of the sound that will eventually encounter the shock will vary with the speed of the object. Sound at an angle great then that will be heard anytime by anyone within the cone, baring 1/r^2.
Make more sense now I hope.I just realized that the picture might be labeled incorrectly, Do they mean Ma is the velocity of the shock? Or something else?
Ma is always < 1. That is the normal velocity of the shock should be subsonic within the cone.
This is why I wrote post #27 where I made the distinction between pressure waves and sound waves. One is due to aerodynamics (the airplane pushing the air) and the other is from a sound source. The shock wave is caused by the pressure waves. It is possible to design an object that will NOT produce a shock wave (see post).
The Mach cone in your post is true for both pressure waves and sound waves. But it will correspond to a shock wave only in the case of pressure waves. In reality, it often look more of a bow shape than a cone shape (see bow shock), it depends on the shape of the object:
With sound waves only, there shouldn't be any shock waves.
