If a particle was at position X for zero time, was it there?
In summary, the conversation discusses the concept of a moving particle being at a certain position for zero time and whether it can still be considered to have been at that position. It brings up Zeno's paradoxes and discusses potential resolutions, including the idea that actual infinity is not physically realized and the use of calculus to understand motion. It also mentions the idea of time passing in discrete pieces and the behavior of objects at the highest point of their trajectory.
ddjj77
64
A moving particle has been at position X for zero time. Was it ever at position X?
Can zero time be considered as never, as in "I was in Rome for zero amount of time."?
It seems like it would have been at position X if time passed in pieces the size of Plank time.
You can either go very deep into Maths Analysis and get familiar with the 'real answer' to your question or you can think in terms of measuring the progress of the particle in tiny steps. (Like with crude measuring equipment). You can then allow the particle to be somewhere between X and X+0.00001 for 0.0035 seconds, between X+0001 andX+0.0002 in the next 0.035 seconds etc, etc. and then work towards smaller and smaller steps. That will always yield a value for a velocity, however short the steps are. This is the basis of (the immensely useful) Differential Calculus.
On a philosophical level, unless the particle actually disappears at point X, then it has to have been at X.
Do a search on Zeno's Paradox if you want to add interest to the question.
Of course yes. You stipulated that it was at position X so by stipulation it was at X. The fact that it was only there momentarily doesn’t change your stipulation nor is it logically self contradictory.
Likes kent davidge, Klystron and russ_watters
"was only there momentarily"
So momentarily and zero time are equivalent?
I need help with understanding this: "The current standard treatment or so-called "Standard Solution" implies Zeno was correct to conclude that a runner's path contains an actual infinity of parts at any time during the motion, but he was mistaken to assume this is too many parts." (From Internet Encyclopedia of Philosophy)
If infinity is too many, should the path contain a finite number of parts? As many Planck distances as needed?
The standard resolution from the mathematics perspective is that actual infinity is not a problem.
From the physics perspective, another resolution is to notice that the notions of an infinitely precise "position" and a continuous "path" are not physically realized in the first place.
The Plank distance is not the granularity of the universe. It is simply a distance unit.
Yes. Although it should be zero duration.
Read it more carefully. Infinity is not too many.
Likes Klystron
It was there, but didn't loiter.
Oops, thanks for noticing that.
"From the physics perspective, another resolution is to notice that the notions of an infinitely precise "position" and a continuous "path" are not physically realized in the first place."
I assume that speed would also not be physically realized? But momentum would be?
Yes. If it spent a nonzero amount of time at position X it would have had to stop there, but since it's a moving particle it doesn't stop.
Note that the same behavior is exhibited by clocks. Where I am now it will soon be 11:00 pm. But for how long will it be exactly 11:00 pm? The answer is zero. If the clock spent any nonzero amount of time at any clock-reading, then the clock would have to stop. Accurate clocks don't stop.
You are not a particle because you have a nonzero size. And Rome is not a position because it has a nonzero size. Imagine walking into and through Rome. Choose one edge of your body, say the front edge, and one edge of Rome, say the south edge. The leading edge of your body spends no time on the southern edge of Rome as you walk through it. If it spent a nonzero amount of time there you would have to stop there for that amount of time. But you don't stop, you walk.
This issue was not resolved until the calculus was invented in the 17th century.
An object can occupy a position for zero time. For example, when a ball is tossed upward and reaches its highest point, how much time does it spend there? It has a zero velocity but a nonzero acceleration at that time.
Yeah, but there is no evidence to suggest that time behaves that way. As far as we know it's continuous, not discrete.
Likes alan123hk
Don't both the velocity and acceleration go to zero at the highest point?
If the ball's acceleration is positive and decreasing while approaching the highest point, and negative and increasing while subsequently retreating from the highest point, doesn't the highest point coincide with the point in time when the acceleration is zero as it changes from positive to negative?
That nonzero acceleration is not with respect to the gravitation of the Earth, is it? Just simple coordinate acceleration with respect to the Earth's surface...?
When the acceleration is zero it means the velocity isn't changing. Therefore the velocity would continue to be zero, meaning the ball would remain at its highest point. But it doesn't. As soon as it reaches its highest point it starts to fall.
The ball's acceleration is constant if the effects of friction are negligible.
The ball's acceleration would continue to be positive and constant as it falls.
No. There is no change in the acceleration. If it's +9.8 m/s2 on the way up it's +9.8 m/s2 on the way down.
Suppose the ball's initial velocity is -19.6 m/s. One second later it's -9.8 m/s. Another second later it's zero. Another second later it's +9.8 m/s and another second after that it's +19.6 m/s. Note that the velocity increased by 9.8 m/s every second. In other words, a constant acceleration of +9.8 m/s2.
Likes Dale
Note that if you were closed in a box so that you couldn't see outside it, and the box did just what the ball did as described in the previous post, you would feel nothing different when you were at the highest point.
You are confusing acceleration with velocity.
Sorry, yes; the acceleration is constant (gravity) and acts throughout the entire passage of the ball, including the high point.
Is there a reason why you chose to assign a negative value to the ball's initial velocity (and so a positive value to the acceleration)? It does not matter to the math if consistent, but the convention for that example is the opposite, isn't it?
An infinitely precise momentum is also not physical.
The OP chose the acceleration to be positive, and therefore the velocity would have to be negative when the ball is rising.
I wouldn't call it a convention. It's probably more popular to refer to the upward direction as positive, but in a situation where something is always moving downward it might be more popular to choose the downward direction as positive because then both the acceleration and the velocity are positive.
This paradox only arises if one takes the idealistically mathematical view that gave rise to Zeno's paradoxes in the first place. In this view there are such concepts as infinity, as a point, as a line, a locus, and many others. Mathematically all such concepts are valid in suitable formal axiomatic structures, and such structures are convenient as bases for applied or empirical descriptions of aspects of reality.
There are however two (at least) aspects of empirical "reality" that conflict with idealised formal descriptions. In those terms the formal mathematical view is simplistic. (I suspect that to describe reality more realistically, we need a fuzzy-mathematical description or something related, but I am not equipped to deal with the associated concepts. Good luck anyone who is ahead of me )
One such aspect is that of our quantum view of nature, in which there is a limit to how precisely you can specify either the particle's location (it is not a "mathematical", a "Euclidean" point) or the time in which the particle might in principle be observed in that location with zero probability. Those coordinates in space/time/probability are non-zero in magnitude or measure, or whatever concept is relevant, and accordingly do not match Zeno's conceptions. The particle remains there until it is space-like and time-like separate from that region: 1e-40 sec? 1e-100 sec, who knows, but not zero!
And that was the good (bad?) news. Even if we weren't in a quantum-based universe, we still are in an information-based, information-limited universe. Information is a physical reality, small for sure (like log relationships) compared to energy but still non-zero. Now, the smaller the interval of time or space one wishes to determine, the greater the information one requires, and to specify even a single true physical point, would require infinite information, for which our physical universe has not enough scope. In other words, the Euclidean axiom that one can select any particular point on a line, is only an idealisation, not a physical fact. One cannot even pick one point anywhere, let alone find it again thereafter. Accordingly, even without QM, we can at best pick a fuzziness, not a zero-measure point of location or time.
And very, very important, this has nothing to do with you or me getting to work with a ruler or stopwatch; it applies equally strongly to the interactions between entities such as particles when a proton falls in a forest when no one is watching. In other words what we might call "reality".
Without the slightest disparagement of Zeno in his day, we have to (are in a position to) think more analytically in terms of recent changes of point of view of physical realities.
Never cared for Zeno's paradox. A point has zero dimension, and so physically does not exist (only conceptually). Also, the question of How long does it take Mary to get from point A to point B at velocity V is not one for differential calculus.
From a non-scientist's view: if the particle in question exists then it exists in time and zero time is included in time.
Let us take this as an experiment to measure the particle at position X at zero time. If the time T of the particle is zero, then the velocity of the particle should be at infinity, which in real sense is impossible. Plugging this information into the uncertainty principle, the more accurate we measure the position X, the less accurate we get the velocity. Since from the question, the position X was already certain at zero time, the velocity should be uncertain at that time.
Was it ever at position X? . To answer to this is NO because If you try to check if the particle was ever at X position at zero time, you will find out the condition required for this to be possible is if the particles velocity remains uncertain even at infinity, which in real sense is impossible unless you know how to measure infinity.
See response #4 above. This is a question about language and maybe mathematics, not experimental physics.
If you start driving at 60 mph from mile sign 0, you pass mile sign #1 at 1 minute and mile sign #2 at 2 minutes.. You are between the two for 1 minute (speed = 60 mph = delta-X/delta-T). You might notice that you were between mile #1 and the sign at mile #1.5 for 30 seconds. And you were between #1 and #1.25 for 15 seconds.
The problem you are having is when you drop the distance interval to 0, (delta-X is then zero). The time interval is also zero. You are at any position for zero time, although you go thru all the infinite points at 60 mph.
You might also consider that if one is never at any position, then a wall in the road would not matter. After all, the moment you hit is of time interval zero. And by your reasoning, that means you are never there.
take the particle sitting or moving through x, now get out your stopwatch. and as the particle gets
to, through...or stays at x, measure zero time elapsed. yes, the particle was at x.
however, the smallest measurement of time that has any meaning, and is equal to 10-43 seconds.
No smaller division of time has any meaning. according to wiki, thanks wiki.
for me, i'd say that on some infinitely small interval, too small to be an official particle,
that it at least exists as some potentiality of information, some quasi energy in the process of
being expressed in the field.
a particle, even mass-less particles disturbs the field, so it's creating a 'history' the history
isn't wiped out between intervals.
If you are in the realm where the Planck time, approximately 5 x 10-44 seconds, is relevant then you are well beyond the realm where particles have a precisely defined position at all, much less a well defined position as a continuous real-valued function of continuous real-valued time.
that's the reason i was saying, since histories aren't deleted, then something existed, though we humans may have no clear definition of what that something is.
And I am saying that the notion that something existed at a precise position at a precise time is not physical. We have (idealized) models that may assume such, but those models are wrong at that level of detail.
ok i got you're meaning. well said.
i thought of another answer more on the math side.
take matrix A, then add a zero matrix. the resulting matrix = matrix A.
  • #31
IMO, until one has a pretty thorough familiarity of the formalities of Calculus, one can’t start introducing Planck Time as an answer to questions like this one. There’s no proof that Planck units represent actual discrete steps so they just do not help.
Likes PeroK and jbriggs444
  • #32
There is no indication yet that this is correct. It may eventually turn out to be correct, but we are quite far away from being able to justify this claim.
  • #33
i was just quoting wiki. i was implying that i believe, that the particle would at least exists in some form. though it may not be observable ,
or measurable, nor its state understood. but a zero interval = no change.
matrix A + zero matrix = matrix A. but there are a lot of great responses on this thread that are more sophisticated. i think it was a fun question.
  • #34
And I was just pointing out that the wiki comment is not based on any evidence. Wiki can be a good reference, but it also can get things wrong.
  • #35
if the particle was nudging its way up to x...almost there
I've re-read the question. It seems to be saying the particle was moving in field Y for some time then passed onto field X for zero seconds. It never arrived into field X or position x. same as saying I drank zero cups of coffee this morning.
  • Mechanics
  • Mechanics
  • Mechanics
