- #71
- 5,614
- 2,935
Perhaps one scenario that illustrates the absence of a voltage in its simplest form is the single conductive open loop around the changing magnetic field, with the opening to the right. If we try to measure a voltage with contacts at top and bottom, (putting the voltmeter on either left or right side), we don''t know whether we will read ## \dot{\Phi} ## or zero, unless we know where the opening is at. If the opening is on the left, everything is reversed. Professor Lewin usually had a couple resistors around the ring. The scenario with the open conductive loop is a variation on what Professor Lewin did.
It should be noted if we make an open coil of ## N ## loops, with ## N ## large, we will read something close to ## V=N \dot{\Phi} ## regardless of how we hook up the voltmeter wires, basically with an uncertainty of ## \pm \dot{\Phi} ##. This is where a EE (electrical engineer) can say he is basically measuring a voltage, even though it arises from the changing magnetic field. I (and others) have also proposed that this ## V=N \dot{\Phi} ## from the conductive coil is mostly of an electrostatic nature, and that is one reason behind why the measurement is very nearly path independent for large ## N ##.
Edit: Very good explanation @vanhees71 in post 70.
additional edit: Since we are on a new page here, I'll reiterate a couple of comments about Feynman's discussion of the scenario: IMO Feynman could have been a little more thorough=he did start out saying the electric field was nearly zero in the conductor (the coil), but he really needed to present it as Professor Lewin did, that the integral is not path independent if you run one of the voltmeter wires on the other side of the changing magnetic field. I welcome any feedback others may have on Feynman's discussion following his equation (22.3). See https://www.feynmanlectures.caltech.edu/II_22.html
