- #211
collinsmark
- 2,651
You'll probably get the most bang for you buck by doing lucky imaging techniques on the video of Saturn. If you could find a way to convert your video to a format used by Autostakkert! (such as .avi), and then process that in Autostakkert!, I think you'll find the results quite pleasing.
Ideally, of course, your original video should be a video without compression. But that's not an option on a cell-phone, since it would take many, many gigabytes just to store a short video. But I've processed video before which started out compressed, and it does work. It doesn't work as well as having the original uncompressed, but it does work.
The stacking will average out compression artifacts, bringing back some detail in the stacked image -- detail which can then be brought out further with appropriate wavelet sharpening.
Without the stacking, using just a single, compressed image, the wavelet sharpening is really just sharpening up the compression artifacts.
Edit: My mistake, I see you're using a DSLR. But the comment remains: if your DSLR allows you to store the video in uncompressed format, use that. If not, there's still hope: Convert it to .avi and run it through AutoStakkert! and results should still be better than with no lucky imaging stacking.
Another Edit: After rereading your posts, I see you did some lucky imaging techniques after all. What program did you use for your lucky imaging stacking?
