Loop-and-allied QG bibliography
In summary, Rovelli's program for loop gravity involves coupling the standard model to quantized QG loops, allowing for interactions between eigenvalues of length and momentum. This approach allows for non-perturbative calculations without infinity problems and does not require a continuum limit. The main difference in loop gravity is that the excitations of space are represented by polymers, or ball-and-stick models, that can be labeled with numbers to determine the volume and area of any region or surface. This allows for a more intuitive understanding of the geometry of the universe.
  • #1,016
http://arxiv.org/abs/0911.1132
Polynomial 6j-Symbols and States Sums
Nathan Geer, Bertrand Patureau-Mirand
(Submitted on 6 Nov 2009)
For q a root of unity of order 2r, we give explicit formulas of a family of 3-variable Laurent polynomials J_{i,j,k} with coefficients in Z[q] that encode the 6j-symbols associated with nilpotent representations of U_qsl_2. For a given abelian group G, we use them to produce a state sum invariant tau^r(M,L,h_1,h_2) of a quadruplet (compact 3-manifold M, link L inside M, homology class h_1\in H_1(M,Z), homology class h_2\in H_2(M,G)) with values in a ring R related to G. The formulas are established by a ``skein'' calculus as an application of the theory of modified dimensions introduced in [arXiv:0711.4229]. For an oriented 3-manifold M, the invariants are related to TV(M,L,f\in H^1(M,C^*)) defined in [arXiv:0910.1624] from the category of nilpotent representations of U_qsl_2. They refine them as TV(M,L,f)= Sum_h tau^r(M,L,h,f') where f' correspond to f with the isomorphism H_2(M,C^*) ~ H^1(M,C^*).
String-nets, single and double-stranded quantum loop gases for non-Abelian anyons
Andrea Velenich, Claudio Chamon, Xiao-Gang Wen
(Submitted on 5 Nov 2009)
String-net condensation can give rise to non-Abelian anyons whereas loop condensation usually gives rise to Abelian anyons. It has been proposed that generalized quantum loop gases with non-orthogonal inner products can produce non-Abelian anyons. We detail an exact mapping between the string-net and the generalized loop models and explain how the non-orthogonal products arise. We also introduce a loop model of double-stranded nets where quantum loops with an orthogonal inner product and local interactions supports non-Abelian Fibonacci anyons. Finally we emphasize the origin of the sign problem in such systems and its consequences on the complexity of their ground state wave functions.
  • #1,017
http://arxiv.org/abs/0911.1719
Bosonic Colored Group Field Theory
Joseph Ben Geloun, Jacques Magnen, Vincent Rivasseau
ICMPA-MPA/2009/24, LPT-2009-93
(Submitted on 9 Nov 2009)
"Bosonic colored group field theory is considered. Focusing first on dimension four, namely the colored Ooguri group field model, the main properties of Feynman graphs are studied. This leads to a theorem on optimal perturbative bounds of Feynman amplitudes in the 'ultraspin' (large spin) limit. The results are generalized in any dimension. Finally integrating out two colors we write a new representation which could be useful for the constructive analysis of this type of models."
http://arxiv.org/abs/0911.1625
Loop Quantum Cosmology corrections on gravity waves produced during primordial inflation
J. Grain
To be published in the AIP Proceedings of the 'Invisible Universe International Conference', UNESCO-Paris, June 29-July 3, 2009; 9 pp., 4 Figs
"Loop Quantum Gravity (L.Q.G.) is one of the two most promising tentative theory for a quantum description of gravity. When applied to the entire universe, the so-called Loop Quantum Cosmology (L.Q.C.) framework offers microscopical models of the very early stages of the cosmological history, potentially solving the initial singularity problem via bouncing solutions or setting the universe in the appropriate initial conditions for inflation to start, via a phase of super-inflation. More interestingly, L.Q.C. could leave a footprint on cosmological observables such as the Cosmic Microwave Background (CMB) anisotropies. Focusing on the modified dispersion relation when holonomy and inverse-volume corrections arising from the L.Q.C. framework are considered, it is shown that primordial gravity waves generated during inflation are affected by quantum corrections. Depending on the type of corrections, the primordial tensor power spectrum is either suppressed or boosted at large length scales, and strongly departs from the power-law behavior expected in the standard scenario."
http://arxiv.org/abs/0911.1403
A Physical Interpretation of Gravitational Field Equations
T. Padmanabhan
Based on the Plenary talk given at the International Conference on `Invisible Universe', 29 June- 3 July, 2009 Paris; to appear in the Proceedings; 2 figures; 16 pages
(Submitted on 7 Nov 2009)
"It is possible to provide a thermodynamic interpretation for the field equations in any diffeomorphism invariant theory of gravity. This insight, in turn, leads us to the possibility of deriving the gravitational field equations from another variational principle without using the metric as a dynamical variable. I review this approach and discuss its implications."
http://arxiv.org/abs/0911.1700
Four-Dimensional Spin Foam Perturbation Theory
Joao Faria Martins, Aleksandar Mikovic
23 pages, 6 figures
"We formulate the four-dimensional spin-foam perturbation theory for a BF-theory with a [tex]B\wedge B[/tex] potential term defined for a compact semi-simple Lie group G on a compact orientable 4-manifold M. This is done by using the formal spin foam perturbative series coming from the spin-foam generating functional. We then regularize the terms in the perturbative series by passing to the category of representations of the quantum group [tex]U_q (\mathfrak{g})[/tex] where [tex]\mathfrak{g}[/tex] is the Lie algebra of G and q is a root of unity. The Chain-Mail formalism can be used to calculate the perturbative terms when the vector space of intertwiners [tex]\L\otimes \L \to A[/tex], where A is the adjoint representation of [tex]\mathfrak{g}[/tex], is 1-dimensional for each irrep L. We calculate the partition function Z in the dilute-gas limit for special classes of triangulations, which we conjecture to exist exist on any 4-manifold M. We prove that the first order perturbative contribution vanishes, so that we define a dilute-gas limit by using the second order contribution. Furthermore, we relate Z to the partition function for the [tex]F\wedge F[/tex] theory."
  • #1,018
http://arxiv.org/abs/0911.1479
Is the spacetime metric Euclidean rather than Lorentzian?
Authors: Rafael D. Sorkin (Perimeter Institute and Syracuse University)
(Submitted on 8 Nov 2009)
Abstract: My answer to the question in the title is "No". In support of this point of view, we analyze some examples of saddle-point methods, especially as applied to quantum "tunneling" in nonrelativistic particle mechanics and in cosmology. Along the way we explore some of the interrelationships among different ways of thinking about path-integrals and saddle-point approximations to them
  • #1,019
http://arxiv.org/abs/0911.1945
Topological Graph Polynomials in Colored Group Field Theory
Razvan Gurau
(Submitted on 10 Nov 2009)
"In this paper we analyze the open Feynman graphs of the Colored Group Field Theory introduced in [arXiv:0907.2582]. We define the boundary graph [tex]\mathfrak{G}_{\partial}[/tex] of an open graph [tex]\mathfrak{G}[/tex] and prove it is a cellular complex. Using this structure we generalize the topological (Bollobas-Riordan) Tutte polynomials associated to (ribbon) graphs to topological polynomials adapted to Colored Group Field Theory graphs in arbitrary dimension."
  • #1,020
http://arxiv.org/abs/0911.2204
Recurrence relations for spin foam vertices
Valentin Bonzom, Etera R. Livine, Simone Speziale
(Submitted on 11 Nov 2009)
We study recurrence relations for various Wigner 3nj-symbols and the non-topological 10j-symbol. For the 6j-symbol and the 15j-symbols which correspond to basic amplitudes of 3d and 4d topological spin foam models, recurrence relations are obtained from the invariance under Pachner moves and can be interpreted as quantizations of the constraints of the underlying classical field theories. We also derive recurrences from the action of holonomy operators on spin network functionals, making a more precise link between the topological Pachner moves and the classical constraints. Interestingly, our recurrence relations apply to any SU(2) invariant symbol, depending on the cycles of the corresponding spin network graph. Another method is used for non-topological objects such as the 10j-symbol and pseudo-isoceles 6j-symbols. The recurrence relations are also interpreted in terms of elementary geometric properties. Finally, we discuss the extension of the recurrences to take into account boundary states which leads to equations similar to Ward identities for correlation functions in the Barrett-Crane model.
http://arxiv.org/abs/0911.2135
Approaches To Quantum Gravity
Cecilia Flori
One of the main challenges in theoretical physics over the last five decades has been to reconcile quantum mechanics with general relativity into a theory of quantum gravity. However, such a theory has been proved to be hard to attain due to i) conceptual difficulties present in both the component theories (General Relativity (GR) and Quantum Theory); ii) lack of experimental evidence, since the regimes at which quantum gravity is expected to be applicable are far beyond the range of conceivable experiments. Despite these difficulties, various approaches for a theory of Quantum Gravity have been developed.
In this thesis we focus on two such approaches: Loop Quantum Gravity and the Topos theoretic approach. The choice fell on these approaches because, although they both reject the Copenhagen interpretation of quantum theory, their underpinning philosophical approach to formulating a quantum theory of gravity are radically different. In particular LQG is a rather conservative scheme, inheriting all the formalism of both GR and Quantum Theory, as it tries to bring to its logical extreme consequences the possibility of combining the two. On the other hand, the Topos approach involves the idea that a radical change of perspective is needed in order to solve the problem of quantum gravity, especially in regard to the fundamental concepts of `space' and `time'. Given the partial successes of both approaches, the hope is that it might be possible to find a common ground in which each approach can enrich the other.
  • #1,021
http://arxiv.org/abs/0911.2404
Emergent Dirac Hamiltonians in Quantum Gravity
Johannes Aastrup, Jesper M. Grimstrup, Mario Paschke
1 figure
(Submitted on 12 Nov 2009)
"We modify the construction of the spectral triple over an algebra of holonomy loops by introducing additional parameters in form of families of matrices. These matrices generalize the already constructed Euler-Dirac type operator over a space of connections. We show that these families of matrices can naturally be interpreted as parameterizing foliations of 4-manifolds. The corresponding Euler-Dirac type operators then induce Dirac Hamiltonians associated to the corresponding foliation, in the previously constructed semi-classical states."
Aastrup and Grimstrup have been pursuing the goal of merging the standard particle model in Connes NCG form, with a variant of canonical LQG. The "spectral triple" is the Connes NCG part---this has to be accommodated on a LQG space.
See their earlier papers for an overview of their project. This appears to be a minor contributory piece of the puzzle.
http://arxiv.org/abs/0911.2391
Wilson loops, geometric operators and fermions in 3d group field theory
R.J. Dowdall
13 pages, many figures
"Group field theories whose Feynman diagrams describe 3d gravity with a varying configuration of Wilson loop observables and 3d gravity with volume observables at each vertex are defined. The volume observables are created by the usual spin network grasping operators which require the introduction of vector fields on the group. We then use this to define group field theories that give a previously defined spin foam model for fermion fields coupled to gravity, and the simpler quenched approximation, by using tensor fields on the group. The group field theory naturally includes the sum over fermionic loops at each order of the perturbation theory."
Richard Dowdall is at Nottingham, John Barrett's student and recent co-author. I guess this paper fits into the overall spin foam program, and contributes towards inclusion of matter.
  • #1,022
http://arxiv.org/abs/0911.2326
Superfluidity and Stationary Space-Times
Authors: George Chapline (LLNL), Pawel O. Mazur (USC Columbia)
Abstract: A connection between superfluidity and gravitation is established for physical stationary gravitational fields. We show that the spinning cosmic string metric describes the gravitational field associated with the single vortex in a superfluid condensate model for space-time outside the vortex core. This metric differs significantly from the usual acoustic metric for the Onsager-Feynman vortex. We also consider the question of what happens when many vortices are present, and show that on large scales a G\"odel-like metric emerges. In both the single and multiple vortex cases the presence of closed time-like curves is attributed to the
  • #1,023
http://arxiv.org/abs/0911.2136
Noncommutative Solitons of Gravity
Authors: Tsuguhiko Asakawa, Shinpei Kobayashi
Abstract: We investigate a three-dimensional gravitational theory on a noncommutative space which has a cosmological constant term only. We found various kinds of nontrivial solutions, by applying a similar technique which was used to seek noncommutative solitons in noncommutative scalar field theories. Some of those solutions correspond to bubbles of spacetimes, or represent dimensional reduction. The solution which interpolates $G_{\mu\nu}=0$ and Minkowski metric is also found. All solutions we obtained are non-perturbative in the noncommutative parameter $\theta$, therefore they are different from solutions found in other contexts of noncommutative theory of gravity and would have a close relation to quantum gravity.
  • #1,024
http://arxiv.org/abs/0911.2653
Triangulated Loop Quantum Cosmology: Bianchi IX and inhomogenous perturbations
Marco Valerio Battisti, Antonino Marciano, Carlo Rovelli
21 pages
(Submitted on 13 Nov 2009)
"We develop the 'triangulated' version of loop quantum cosmology, recently introduced in the literature. We focus on the 'dipole' cosmology, where space is a three-sphere and the triangulation is formed by two tetrahedra. We show that the discrete fiducial connection has a simple and appealing geometrical interpretation and we correct the ansatz on the relation between the model variables and the Friedmann-Robertson-Walker scale factor. The modified ansatz leads to the convergence of the Hamiltonian constraint to the continuum one. We then ask which degrees of freedom are captured by this model. We show that the model is rich enough to describe the (anisotropic) Bianchi IX Universe, and give the explicit relation between the Bianchi IX variables and the variables of the model. We discuss the possibility of using this path in order to define the quantization of the Bianchi IX Universe. The model contains more degrees of freedom than Bianchi IX, and therefore captures some inhomogeneous degrees of freedom as well. Inhomogeneous degrees of freedom can be expanded in representations of the SU(2) Bianchi IX isometry group, and the dipole model captures the lowest integer representation of these, connected to hyper-spherical harmonic of angular momentum j=1."
http://arxiv.org/abs/0911.2698
A solution of the strong CP problem a la Peccei-Quinn through the Nieh-Yan modified gravity and cosmological implications
Massimiliano Lattanzi, Simone Mercuri
8 pages, 1 figure
"By identifying the recently introduced Barbero-Immirzi field with the QCD axion, the strong CP problem can be solved through the Peccei-Quinn mechanism. A specific energy scale for the Peccei-Quinn symmetry breaking is naturally predicted by this model. This provides a complete dynamical setting to evaluate the contribution of such an axion to the cold dark matter content of the Universe, as function of the initial misalignment angle. Furthermore, a tight upper bound on the tensor-to-scalar ratio production of primordial gravitational waves can be fixed, representing a strong experimental test for this model."
My comment, see footnote [18].
  • #1,025
http://arxiv.org/abs/0911.3097
On the spinfoam expansion in cosmology
Carlo Rovelli, Francesca Vidotto
(Submitted on 16 Nov 2009)
We consider the technique introduced in a recent work by Ashtekar, Campiglia and Henderson, which generate a spinfoam-like sum from a Hamiltonian theory. We study the possibility of using it for finding the generalized projector of a constraint on physical states, without first deparametrising the system. We illustrate this technique in the context of a very simple example. We discuss the infinities that appear in the calculation, and argue that they can be appropriately controlled. We apply these ideas to write a spinfoam expansion for the "dipole cosmology".
http://arxiv.org/abs/0911.2761
Phenomenological Quantum Gravity
If the history of science has taught us anything, it's that persistence and creativity makes the once impossible possible. It has long been thought experimental tests of quantum gravity are impossible. But during the last decade, several different approaches have been proposed that allow us to test, if not the fundamental theory of quantum gravity itself, so at least characteristic features this theory can have. For the first time we can probe experimentally domains in which quantum physics and gravity cohabit, in spite of our failure so far to make a convincing marriage of them on a theoretical level.
  • #1,026
http://arxiv.org/abs/0911.2727
Astrophysical implications of the Asymptotic Safety Scenario in Quantum Gravity
Alfio Bonanno
28 pages, 6 figures. Invited talk at Workshop on Continuum and Lattice Approaches to Quantum Gravity. Sept. 2008, Brighton UK. To appear in the Proceedings
"In recent years it has emerged that the high energy behavior of gravity could be governed by an ultraviolet non-Gaussian fixed point of the (dimensionless) Newton's constant, whose behavior at high energy is thus antiscreened. This phenomenon has several astrophysical implications. In particular in this article recent works on renormalization group improved cosmologies based upon a renormalization group trajectory of Quantum Einstein Gravity with realistic parameter values will be reviewed. It will be argued that quantum effects can account for the entire entropy of the present Universe in the massless sector and give rise to a phase of inflationary expansion. Moreover the prediction for the final state of the black hole evaporation is a Planck size remnant which is formed in an infinite time."
If you choose to print this paper by Bonanno, limit the printing to pages 1-29
After page 29 there is an earlier, imperfect, copy of the paper, which someone neglected to erase when the finished copy was uploaded.
MTd2 has already spotted the next one, so I just make brief mention of it:
Sabine Hossenfelder, Lee Smolin
3 pages. To appear in Physics in Canada
  • #1,027
http://arxiv.org/abs/0911.3165
Asymptotically Safe Inflation
Steven Weinberg
Inflation is studied in the context of asymptotically safe theories of gravitation. It is found to be possible under several circumstances to have a long period of nearly exponential expansion that eventually comes to an end.
  • #1,028
http://arxiv.org/abs/0911.3428
On the Relation between Operator Constraint --, Master Constraint --, Reduced Phase Space --, and Path Integral Quantisation
Muxin Han, Thomas Thiemann
43 pages
(Submitted on 17 Nov 2009)
"Path integral formulations for gauge theories must start from the canonical formulation in order to obtain the correct measure. A possible avenue to derive it is to start from the reduced phase space formulation. In this article we review this rather involved procedure in full generality. Moreover, we demonstrate that the reduced phase space path integral formulation formally agrees with the Dirac's operator constraint quantisation and, more specifically, with the Master constraint quantisation for first class constraints. For first class constraints with non trivial structure functions the equivalence can only be established by passing to Abelian(ised) constraints which is always possible locally in phase space. Generically, the correct configuration space path integral measure deviates from the exponential of the Lagrangian action. The corrections are especially severe if the theory suffers from second class secondary constraints. In a companion paper we compute these corrections for the Holst and Plebanski formulations of GR on which current spin foam models are based."
http://arxiv.org/abs/0911.3431
On the Relation between Rigging Inner Product and Master Constraint Direct Integral Decomposition
25 pages
"Canonical quantisation of constrained systems with first class constraints via Dirac's operator constraint method proceeds by the thory of Rigged Hilbert spaces, sometimes also called Refined Algebraic Quantisation (RAQ). This method can work when the constraints form a Lie algebra. When the constraints only close with nontrivial structure functions, the Rigging map can no longer be defined.
To overcome this obstacle, the Master Constraint Method has been proposed which replaces the individual constraints by a weighted sum of absolute squares of the constraints. Now the direct integral decomposition methods (DID), which are closely related to Rigged Hilbert spaces, become available and have been successfully tested in various situations.
It is relatively straightforward to relate the Rigging Inner Product to the path integral that one obtains via reduced phase space methods. However, for the Master Constraint this is not at all obvious. In this paper we find sufficient conditions under which such a relation can be established. Key to our analysis is the possibility to pass to equivalent, Abelian constraints, at least locally in phase space. Then the Master Constraint DID for those Abelian constraints can be directly related to the Rigging Map and therefore has a path integral formulation."
http://arxiv.org/abs/0911.3432
Path-integral for the Master Constraint of Loop Quantum Gravity
Muxin Han
19 pages
"In the present paper, we start from the canonical theory of loop quantum gravity and the master constraint programme. The physical inner product is expressed by using the group averaging technique for a single self-adjoint master constraint operator. By the standard technique of skeletonization and the coherent state path-integral, we derive a path-integral formula from the group averaging for the master constraint operator. Our derivation in the present paper suggests there exists a direct link connecting the canonical Loop quantum gravity with a path-integral quantization or a spin-foam model of General Relativity."
http://arxiv.org/abs/0911.3433
Canonical path integral measures for Holst and Plebanski gravity. I. Reduced Phase Space Derivation
Jonathan Engle, Muxin Han, Thomas Thiemann
26 pages
An important aspect in defining a path integral quantum theory is the determination of the correct measure. For interacting theories and theories with constraints, this is non-trivial, and is normally not the heuristic "Lebesgue measure" usually used. There have been many determinations of a measure for gravity in the literature, but none for the Palatini or Holst formulations of gravity. Furthermore, the relations between different resulting measures for different formulations of gravity are usually not discussed.
In this paper we use the reduced phase technique in order to derive the path-integral measure for the Palatini and Holst formulation of gravity, which is different from the Lebesgue measure up to local measure factors which depend on the spacetime volume element and spatial volume element.
From this path integral for the Holst formulation of GR we can also give a new derivation of the Plebanski path integral and discover a discrepancy with the result due to Buffenoir, Henneaux, Noui and Roche (BHNR) whose origin we resolve. This paper is the first in a series that aims at better understanding the relation between canonical LQG and the spin foam approach."
http://arxiv.org/abs/0911.3436
Canonical Path-Integral Measures for Holst and Plebanski Gravity. II. Gauge Invariance and Physical Inner Product
Muxin Han
34 pages
"This article serves as a continuation for the discussion in arXiv:0911.3433, we analyze the invariance properties of the gravity path-integral measure derived from canonical framework, and discuss which path-integral formula may be employed in the concrete computation e.g. constructing a spin-foam model, so that the final model can be interpreted as a physical inner product in the canonical theory."
http://arxiv.org/abs/0911.3553
The Fine Structure of SU(2) Intertwiners from U(N) Representations
Laurent Freidel, Etera R. Livine
21 pages
(Submitted on 18 Nov 2009)
"In this work we study the Hilbert space space of N-valent SU(2) intertwiners with fixed total spin, which can be identified, at the classical level, with a space of convex polyhedra with N face and fixed total boundary area. We show that this Hilbert space provides, quite remarkably, an irreducible representation of the U(N) group. This gives us therefore a precise identification of U(N) as a group of area preserving diffeomorphism of polyhedral spheres. We use this results to get new closed formulae for the black hole entropy in loop quantum gravity."
  • #1,029
http://arxiv.org/abs/0911.3745
Loop quantum gravity and the CMB: toward pre-Big Bounce cosmology
Aurelien Barrau
Comments: Proceedings of the 12th Marcel Grossman Meeting on General Relativity. 3 pages, no figure
Subjects: General Relativity and Quantum Cosmology (gr-qc)
This brief article sums up the possible imprints of loop quantum gravity effects on the cosmological microwave background. We focus on semi-classical terms and show that "Big Bounce" corrections, together with the "pre Big Bounce" state, could modify the observed spectrum.
  • #1,030
http://arxiv.org/abs/0911.3793
Gravity-Yang-Mills-Higgs unification by enlarging the gauge group
Alexander Torres-Gomez, Kirill Krasnov (University of Nottingham)
We revisit an old idea that gravity can be unified with Yang-Mills theory by enlarging the gauge group of gravity formulated as gauge theory. Our starting point is an action that describes a generally covariant gauge theory for a group G. The Minkowski background breaks the gauge group by selecting in it a preferred gravitational SU(2) subgroup. We expand the action around this background and find the spectrum of linearized theory to consist of the usual gravitons plus Yang-Mills fields charged under the centralizer of the SU(2) in G. In addition, there is a set of Higgs fields that are charged both under the gravitational and Yang-Mills subgroups. These fields are generically massive and interact with both gravity and Yang-Mills sector in the standard way. The arising interaction of the Yang-Mills sector with gravity is also standard. Parameters such as the Yang-Mills coupling constant and Higgs mass arise from the potential function defining the theory. Both are realistic in the sense explained in the paper.
  • #1,031
http://arxiv.org/abs/0911.4208
New aspects of two-dimensional quantum gravity
J. Ambjorn, R. Loll, Y. Watabiki, W. Westra, S. Zohren
(Submitted on 21 Nov 2009)
Causal dynamical triangulations (CDT) can be used as a regularization of quantum gravity. In two dimensions the theory can be solved anlytically, even before the cut-off is removed and one can study in detail how to take the continuum limit. We show how the CDT theory is related to Euclidean 2d quantum gravity (Liouville quantum gravity), how it can be generalized and how this generalized CDT model has a string field theory representation as well as a matrix model representationof a new kind, and finally how it examplifies the possibility that time in quantum gravity might be the stochastic time related to the branching of space into baby
http://arxiv.org/abs/0911.4211
Proper time is stochastic time in 2d quantum gravity
We show that proper time, when defined in the quantum theory of 2d gravity, becomes identical to the stochastic time associated with the stochastic quantization of space. This observation was first made by Kawai and collaborators in the context of 2d Euclidean quantum gravity, but the relation is even simpler and more transparent in he context of 2d gravity formulated in the framework of CDT (causal dynamical triangulations).http://arxiv.org/abs/0911.4141
Lattice Loop Quantum Gravity
(Submitted on 20 Nov 2009)
We present a separable version of Loop Quantum Gravity (LQG) based on an inductive system of cubic lattices. We construct semi-classical states for which the LQG operators -- the flux, the area and the volume operators -- have the right classical limits. Also, we present the Hamilton and diffeomorphism constraints as operator constraints and show that they have the right classical limit. Finally, we speculate whether the continuum limit, which these semi-classical states probe, can be defined for the entire construction and thereby restore an action of the diffeomorphism group.
  • #1,032
I think this paper is an interesting one for you Fra.
http://arxiv.org/abs/0911.4307
Quantum Darwinism in non-ideal environments
Authors: Michael Zwolak, H. T. Quan, Wojciech H. Zurek
(Submitted on 22 Nov 2009)
Abstract: Quantum Darwinism provides an information-theoretic framework for the emergence of the objective, classical world from the quantum substrate. The key to this emergence is the proliferation of redundant information throughout the environment where observers can then intercept it. We study this process for a purely decohering interaction when the environment, E, is in a non-ideal (e.g., mixed) initial state. In the case of good decoherence, that is, after the pointer states have been unambiguously selected, the mutual information between the system, S, and an environment fragment, F, is given solely by F's entropy increase. This demonstrates that the environment's capacity for recording the state of S is directly related to its ability to increase its entropy. Environments that remain nearly invariant under the interaction with S, either because they have a large initial entropy or a misaligned initial state, therefore have a diminished ability to acquire information. To elucidate the concept of good decoherence, we show that - when decoherence is not complete - the deviation of the mutual information from F's entropy change is quantified by the quantum discord, i.e., the excess mutual information between S and F is information regarding the initial coherence between pointer states of S. In addition to illustrating these results with a single qubit system interacting with a multi-qubit environment, we find scaling relations for the redundancy of information acquired by the environment that display a universal behavior independent of the initial state of S. Our results demonstrate that Quantum Darwinism is robust with respect to non-ideal initial states of the environment: the environment almost always acquires redundant information about the system but its rate of acquisition can be reduced.
  • #1,033
"Last but not least" two new papers by Martin Kober i spotted his work last march.
http://arxiv.org/abs/0910.3303
About the Origin of the Division between Internal and External Symmetries in Quantum Field Theory
Authors: Martin Kober
(Submitted on 17 Oct 2009)
Abstract: It is made the attempt to explain why there exists a division between internal symmetries referring to quantum numbers and external symmetries referring to space-time within the description of relativistic quantum field theories. It is hold the attitude that the symmetries of quantum theory are the origin of both sorts of symmetries in nature. Since all quantum states can be represented as a tensor product of two dimensional quantum objects, called ur objects, which can be interpreted as quantum bits of information, described by spinors reflecting already the symmetry properties of space-time, it seems to be possible to justify such an attitude. According to this, space-time symmetries can be considered as a consequence of a representation of quantum states by quantum bits. Internal symmetries are assumed to refer to relations of such fundamental objects, which are contained within the state of one single particle, with respect to each other. In this sense the existence of space-time symmetries, the existence of internal symmetries and their division could obtain a derivation from quantum theory interpreted as a theory of information.
http://arxiv.org/abs/0905.0408
Copenhagen Interpretation of Quantum Theory and the Measurement Problem
(Submitted on 4 May 2009 (v1), last revised 5 Nov 2009 (this version, v3))
Abstract: The Copenhagen interpretation of quantum theory is investigated from a philosophical point of view. It is justified the opinion that the philosophical attitude the Copenhagen interpretation is based on is in principle inevitable for a real comprehension of quantum theory. This attitude is mainly related to epistemological arguments. However, the measurement problem often seems not to be treated clearly enough within the interpretation. By referring to the property of the necessity to use macroscopic measurement instruments obeying classical concepts it is made the attempt to solve the measurement problem. According to this consideration the indeterministic character of quantum theory seems to have its origin in a lack of knowledge and thus it appears in a similar but more principle way than in statistical mechanics. It is emphasized the ontological character of the uncertainty relation and the related non locality of quantum theory suggesting that the existence of a position space is not as fundamental as the assumptions of general quantum theory.
  • #1,034
http://arxiv.org/abs/0911.4903
Effective metric Lagrangians from an underlying theory with two propagating degrees of freedom
Kirill Krasnov
(Submitted on 25 Nov 2009)
We describe an infinite-parametric class of effective metric Lagrangians that arise from an underlying theory with two propagating degrees of freedom. The Lagrangians start with the Einstein-Hilbert term, continue with the standard R^2, (Ricci)^2 terms, and in the next order contain (Riemann)^3 as well as on-shell vanishing terms. This is exactly the structure of the effective metric Lagrangian that renormalizes quantum gravity divergences at two-loops. This shows that the theory underlying the effective field theory of gravity may have no more degrees of freedom than is already contained in general relativity. We show that the reason why an effective metric theory may describe just two propagating degrees of freedom is that there exists a (non-local) field redefinition that maps an infinitely complicated effective metric Lagrangian to the usual Einstein-Hilbert one. We describe this map for our class of theories and, in particular, exhibit it explicitly for the (Riemann)^3 term.
  • #1,035
http://arxiv.org/abs/0911.4950
Effective Constraints and Physical Coherent States in Quantum Cosmology: A Numerical Comparison
Martin Bojowald, Artur Tsobanjan
32 pages, 25 figures
"A cosmological model with a cyclic interpretation is introduced, which is subject to quantum back-reaction and yet can be treated rather completely by physical coherent state as well as effective constraint techniques. By this comparison, the role of quantum back-reaction in quantum cosmology is unambiguously demonstrated. Also the complementary nature of strengths and weaknesses of the two procedures is illustrated. Finally, effective constraint techniques are applied to a more realistic model filled with radiation, where physical coherent states are not available."
  • #1,036
http://arxiv.org/abs/0911.5156
A Theory of Neutrino Oscillations and Late Time Acceleration
Stephon H.S. Alexander
6 Pages, 1 figure
(Submitted on 26 Nov 2009)
"We provide a microphysical model that connects neutrino oscillations to dark energy, which has predictions of Lorentz and CPT violating neutrino oscillations. We argue that the DE is a BCS condensate of flavored neutrinos. As neutrinos propigate in their own condensate they naturally have oscillations proportional to the DE energy density. All that is assumed in this model is a covariant coupling of neutrinos to gravity and a finite number density of neutrinos in the cosmic rest frame; this situation yields an attractive channel for the formation of a spin zero neutrino condensate leading to late time acceleration self consistently. Moreover, the vacuum oscillation has two predictions: (1) CPT violating oscillations proportional to the DE density (2) A connection between the evolution of the equation of state of the DE condensate and the neutrino oscillations. These predictions can be probed independently with future Supernovae and Neutrino Telescopes."
http://arxiv.org/abs/0911.5331
Born--Oppenheimer decomposition for quantum fields on quantum spacetimes
Kristina Giesel, Johannes Tambornino, Thomas Thiemann
38 pages, 2 figures
(Submitted on 27 Nov 2009)
"Quantum Field Theory on Curved Spacetime (QFT on CS) is a well established theoretical framework which intuitively should be a an extremely effective description of the quantum nature of matter when propagating on a given background spacetime. If one wants to take care of backreaction effects, then a theory of quantum gravity is needed. It is now widely believed that such a theory should be formulated in a non-perturbative and therefore background independent fashion. Hence, it is a priori a puzzle how a background dependent QFT on CS should emerge as a semiclassical limit out of a background independent quantum gravity theory. In this article we point out that the Born-Oppenheimer decomposition (BOD) of the Hilbert space is ideally suited in order to establish such a link, provided that the Hilbert space representation of the gravitational field algebra satisfies an important condition. If the condition is satisfied, then the framework of QFT on CS can be, in a certain sense, embedded into a theory of quantum gravity. The unique representation of the holonomy-flux algebra underlying Loop Quantum Gravity (LQG) violates that condition. While it is conceivable that the condition on the representation can be relaxed, for convenience in this article we consider a new classical gravitational field algebra and a Hilbert space representation of its restriction to an algebraic graph for which the condition is satisfied. An important question that remains and for which we have only partial answers is how to construct eigenstates of the full gravity-matter Hamiltonian whose BOD is confined to a small neighbourhood of a physically interesting vacuum spacetime."
http://arxiv.org/abs/0911.5004
Thermodynamical Aspects of Gravity: New insights
T.Padmanabhan
81 pages; 4 figures
"The fact that one can associate thermodynamic properties with horizons brings together principles of quantum theory, gravitation and thermodynamics and possibly offers a window to the nature of quantum geometry. This review discusses certain aspects of this topic concentrating on new insights gained from some recent work. After a brief introduction of the overall perspective, Sections 2 and 3 provide the pedagogical background on the geometrical features of bifurcation horizons, path integral derivation of horizon temperature, black hole evaporation, structure of Lanczos-Lovelock models, the concept of Noether charge and its relation to horizon entropy. Section 4 discusses several conceptual issues introduced by the existence of temperature and entropy of the horizons. In Section 5 we take up the connection between horizon thermodynamics and gravitational dynamics and describe several peculiar features which have no simple interpretation in the conventional approach. The next two sections describe the recent progress achieved in an alternative perspective of gravity. In Section 6 we provide a thermodynamic interpretation of the field equations of gravity in any diffeomorphism invariant theory and in Section 7 we obtain the field equations of gravity from an entropy maximization principle. The last section provides a summary."
http://arxiv.org/abs/0911.5012
Neutrino Condensate as Origin of Dark Energy
Jitesh R. Bhatt, Bipin R. Desai, Ernest Ma, G. Rajasekaran, Utpal Sarkar
5 pages
"We propose a new solution to the origin of dark energy. We suggest that it was created dynamically from the condensate of a singlet neutrino at a late epoch of the early Universe through its effective self interaction. This singlet neutrino is also the Dirac partner of one of the three observed neutrinos, hence dark energy is related to neutrino mass. The onset of this condensate formation in the early Universe is also related to matter density and offers an explanation of the coincidence problem of why dark energy (70%) and total matter (30%) are comparable at the present time. We demonstrate this idea in a model of neutrino mass with (right-handed) singlet neutrinos and a singlet scalar."
http://arxiv.org/abs/0911.5075
A quantum Bose-Hubbard model with evolving graph as toy model for emergent spacetime
Alioscia Hamma, Fotini Markopoulou, Seth Lloyd, Francesco Caravelli, Simone Severini, Klas Markstrom
23 pages, 6 figures
"We present a toy model for interacting matter and geometry that explores quantum dynamics in a spin system as a precursor to a quantum theory of gravity. The model has no a priori geometric properties, instead, locality is inferred from the more fundamental notion of interaction between the matter degrees of freedom. The interaction terms are themselves quantum degrees of freedom so that the structure of interactions and hence the resulting local and causal structures are dynamical. The system is a Hubbard model where the graph of the interactions is a set of quantum evolving variables. We show entanglement between spatial and matter degrees of freedom. We study numerically the quantum system and analyze its entanglement dynamics. We analyze the asymptotic behavior of the classical model. Finally, we discuss analogues of trapped surfaces and gravitational attraction in this simple model."
  • #1,037
http://arxiv.org/abs/0912.0090
The Box-Problem in Deformed Special Relativity
S. Hossenfelder
20 pages, 3 figures
(Submitted on 1 Dec 2009)
"We examine the transformation of particle trajectories in models with deformations of Special Relativity that have an energy-dependent and observer-independent speed of light. These transformations necessarily imply that the notion of what constitutes the same space-time event becomes dependent on the observer's inertial frame. To preserve observer-independence, the such arising nonlocality should not be in conflict with our knowledge of particle interactions. This requirement allows us to derive strong bounds on deformations of Special Relativity and rule out a modification to first order in energy over the Planck mass."
http://arxiv.org/abs/0911.5464
Quasi-linear formulation of MOND
Mordehai Milgrom
23 pages.
(Submitted on 29 Nov 2009)
"A new formulation of MOND as a modified-potential theory of gravity is propounded. In effect, the theory dictates that the MOND potential phi produced by a mass distribution rho is a solution of the Poisson equation for the modified source density rho*=-(4 pi G)-1divergence(g), where g=nu(|gN|/a0)gN, and gN is the Newtonian acceleration field of rho. This makes phi simply the scalar potential of the algebraic acceleration field g. The theory thus involves solving only linear differential equations, with one nonlinear, algebraic step. It is derivable from an action, satisfies all the usual conservation laws, and gives the correct center-of-mass acceleration to composite bodies. The theory is akin in some respects to the nonlinear Poisson formulation of Bekenstein and Milgrom, but it is different from it, and is obviously easier to apply. The two theories are shown to emerge as natural modifications of a Palatini-type formulation of Newtonian gravity, and are members in a larger class of bi-potential theories."
  • #1,038
http://arxiv.org/abs/0911.5729
Critical dynamics of decoherence
Authors: Bogdan Damski, H. T. Quan, Wojciech H. Zurek
(Submitted on 30 Nov 2009)
Abstract: The quantum-classical border Niels Bohr postulated to account for the definiteness of measurement outcomes is explained by decoherence. Decoherence, as a destroyer of quantum coherence and entanglement, is also a respected foe in novel applications of quantum physics (such as quantum computing or quantum metrology). So far, studies of decoherence focused on systems prepared typically in a Schroedinger cat-like superposition, and then instantaneously coupled to an otherwise static environment. We study decoherence induced by many-body dynamic environment undergoing a non-equilibrium (quantum) phase transition. As environment "monitors" the quantum system, its sensitivity -- and, consequently, efficiency of decoherence -- is amplified by a phase transition, as is often the case in the real world detectors (bubble chambers, photographic emulsions, or rhodopsin in our eyes). We show that decoherence happens almost exclusively as the critical point of the environment is traversed, and is significantly enhanced by its non-equilibrium phase transition dynamics. Our calculation yields a simple expression that relates decoherence to the universal critical exponents in a way that parallels theory of topological defect creation in non-equilibrium phase transitions.
  • #1,039
http://arxiv.org/abs/0912.0208
Asymptotic safety of gravity and the Higgs boson mass
Mikhail Shaposhnikov, Christof Wetterich
12 pages
"There are indications that gravity is asymptotically safe. The Standard Model (SM) plus gravity could be valid up to arbitrarily high energies. Supposing that this is indeed the case and assuming that there are no intermediate energy scales between the Fermi and Planck scales we address the question of whether the mass of the Higgs boson [tex]m_H[/tex] can be predicted. For a positive gravity induced anomalous dimension [tex]A_\lambda>0[/tex] the running of the quartic scalar self interaction [tex]\lambda[/tex] at scales beyond the Planck mass is determined by a fixed point at zero. This results in [tex]m_H=m_{\rm min}=126[/tex] GeV, with only a few GeV uncertainty. This prediction is independent of the details of the short distance running and holds for a wide class of extensions of the SM as well. For [tex]A_\lambda <0[/tex] one finds [tex]m_H[/tex] in the interval [tex]m_{\rm min}< m_H < m_{\rm max}\simeq 174[/tex] GeV, now sensitive to [tex]A_\lambda[/tex] and other properties of the short distance running. The case [tex]A_\lambda>0[/tex] is favored by explicit computations existing in the literature."
http://arxiv.org/abs/0912.0162
The LQC evolution operator of FRW universe with positive cosmological constant
Wojciech Kaminski, Tomasz Pawlowski
8 pages
"The self-adjointness of an evolution operator [tex]\Theta_{\Lambda}[/tex] corresponding to the model of flat FRW universe with massless scalar field and cosmological constant quantized in the framework of Loop Quantum Cosmology is studied in the case [tex]\Lambda>0[/tex]. It is shown, that for [tex]\Lambda<\Lambda_c\approx 10.3 \l_{Pl}^{-2}[/tex] the operator admits many self-adjoint extensions, each of the purely discrete spectrum. On the other hand for [tex]\Lambda\geq\Lambda_c[/tex] the operator is essentially self-adjoint, however the physical Hilbert space of the model does not contain any physically interesting states.
http://arxiv.org/abs/0912.0220
The microstructure of a quantum universe
Leonardo Modesto, Piero Nicolini
4 pages, 1 figure
"In this paper, we calculate in a transparent way the spectral dimension of a quantum spacetime, considering a diffusion process propagating on a fluctuating manifold. To describe the erratic path of the diffusion, we implement a minimal length by averaging the graininess of the quantum manifold in the flat space case. As a result we obtain that for large diffusion times, the quantum spacetime behaves like a smooth differential manifold of discrete dimension. On the other hand, for smaller diffusion times, the spacetime looks like a fractal surface with a reduced effective dimension. For the specific case in which the diffusion time has the size of the minimal length, the spacetime turns out to have a spectral dimension equal to two, suggesting a possible renormalizable character of gravity in this regime. For smaller diffusion times, the spectral dimension approaches zero, making less reliable any physical interpretation in this extreme regime. We extend our result to the presence of a background field and curvature. We show that in this case the spectral dimension has a more complicated relation with the diffusion time and conclusions about the renormalizable character of gravity become less straightforward with respect to what found with the flat space analysis."
  • #1,040
http://arxiv.org/abs/0912.0540
The EPRL intertwiners and corrected partition function
Wojciech Kamiński, Marcin Kisielowski, Jerzy Lewandowski
14 pages, 5 figures
(Submitted on 3 Dec 2009)
"Do the SU(2) intertwiners parametrize the space of the EPRL solutions to the simplicity constraint? What is a complete form of the partition function written in terms of this parametrization? We prove that the EPRL map is injective in the general n-valent vertex case for the Barbero-Immirzi parameter less then 1. We find, however, that the EPRL map is not isometric. In the consequence, in order to be written in a SU(2) amplitude form, the formula for the partition function has to be rederived. We do it and obtain a new, complete formula for the partition function. The result goes beyond the SU(2) spin-foam models framework."
  • #1,041
http://arxiv.org/abs/0912.0554
Emergence of General Relativity from Loop Quantum Gravity
Chun-Yen Lin (University of California at Davis)
7 pages, 2 figures
"I show that general relativity emerges from loop quantum gravity, in a relational description of gravitation field in terms of coordinates defined by matter. Local Dirac observables and coherent states are constructed for an explicit evaluation of the dynamics. The dynamics of large scales conforms with general relativity, up to the corrections near singularities."
Chun-Yen is a PhD student of Steve Carlip at UC-Davis. Carlip has another PhD student doing Causal Dynamical Triangulations. Carlip's was the lead talk at the July 2009 Planck Scale conference and one of the best talks---comparing spontaneous dimensional reduction in several different nonstring quantum gravity approaches and suggesting a semiclassical explanation for why it happens. Chun-Yen has a longer GR-from-LQG paper in preparation and probably a dissertation on this topic. Details like this make Carlip's group at Davis. interesting.
http://arxiv.org/abs/0912.0556
On Unitary Evolution in Quantum Field Theory in Curved Spacetime
Daniele Colosi (UNAM), Robert Oeckl (UNAM)
11 pages
"We investigate the question of unitarity of evolution between hypersurfaces in quantum field theory in curved spacetime from the perspective of the general boundary formulation. Unitarity thus means unitarity of the quantum operator that maps the state space associated with one hypersurface to the state space associated with the other hypersurface. Working in Klein-Gordon theory, we find that such an evolution is generically unitary given a one-to-one correspondence between classical solutions in neighborhoods of the respective hypersurfaces. This covers the case of pairs of Cauchy hypersurfaces, but also certain cases where hypersurfaces are timelike. The tools we use are the Schroedinger representation and the Feynman path integral."
Both Oeckl and Colosi have track records of publication in LQG and LQG-related areas. This particular paper, while not explicitly treating quantum gravity, can be seen as relevant to the program--joining quantum field theory with the path-integral version of LQG. A strong QG group has been assembled at UNAM-Morelia (which hosted the Loops 2007 conference and will host the 2010 Americas QG school.)
  • #1,042
Marcus left this one for me:
  • #1,043
http://arxiv.org/abs/0912.0808
Time and Spacetime: The Crystallizing Block Universe
George F. R. Ellis, Tony Rothman
25 Pages. 3 figures
(Submitted on 4 Dec 2009)
"The nature of the future is completely different from the nature of the past. When quantum effects are significant, the future shows all the signs of quantum weirdness, including duality, uncertainty, and entanglement. With the passage of time, after the time-irreversible process of state-vector reduction has taken place, the past emerges, with the previous quantum uncertainty replaced by the classical certainty of definite particle identities and states. The present time is where this transition largely takes place, but the process does not take place uniformly: Evidence from delayed choice and related experiments shows that isolated patches of quantum indeterminacy remain, and that their transition from probability to certainty only takes place later. Thus, when quantum effects are significant, the picture of a classical Evolving Block Universe (`EBU') cedes place to one of a Crystallizing Block Universe (`CBU'), which reflects this quantum transition from indeterminacy to certainty, while nevertheless resembling the EBU on large enough scales."
George Ellis (who co-authored Hawking-Ellis Large Scale Structure of Space Time) is a pioneer in cosmology, and in the philosophy of cosmology. He just celebrated his 70th birthday and a lot of people prominent in quantum gravity and cosmology went to Capetown to give papers in his honor. The guy has an extra good mind and IMHO if he gives us a new idea of the universe, like here, we do well to take a careful look.
  • #1,044
http://arxiv.org/abs/0912.1095
Supergravity as a constrained BF theory
R. Durka, J. Kowalski-Glikman, M. Szczachor
7 pages
(Submitted on 6 Dec 2009)
"In this paper we formulate N=1 supergravity as a constrained BF theory with OSp(4|1) gauge superalgebra. We derive the modified supergravity Lagrangian that, apart from the standard supergravity with negative cosmological constant, contains terms proportional to the (inverse of) Immirzi parameter. Although these terms do not change classical field equations, they might be relevant in quantum theory. We briefly discuss the perturbation theory around the supersymmetric topological vacuum."
  • #1,045
http://arxiv.org/abs/0912.1546
Encoding simplicial quantum geometry in group field theories
Daniele Oriti, Tamer Tlas
15 pages, 2 figures
(Submitted on 8 Dec 2009)
"We show that a new symmetry requirement on the GFT field, in the context of an extended GFT formalism, involving both Lie algebra and group elements, leads, in 3d, to Feynman amplitudes with a simplicial path integral form based on the Regge action, to a proper relation between the discrete connection and the triad vectors appearing in it, and to a much more satisfactory and transparent encoding of simplicial geometry already at the level of the GFT action."
http://arxiv.org/abs/0912.1817
From covariant to canonical formulations of discrete gravity
Bianca Dittrich, Philipp A Hoehn
37 pages, 5 figures
(Submitted on 9 Dec 2009)
"Starting from an action for discretized gravity we derive a canonical formalism that exactly reproduces the dynamics and (broken) symmetries of the covariant formalism. For linearized Regge calculus on a flat background -- which exhibits exact gauge symmetries -- we derive local and first class constraints for arbitrary triangulated Cauchy surfaces. These constraints have a clear geometric interpretation and are a first step towards obtaining anomaly--free constraint algebras for canonical lattice gravity. Taking higher order dynamics into account the symmetries of the action are broken. This results in a consistency conditions on the background gauge parameters arising from the lowest non--linear equations of motion. In the canonical framework the constraints to quadratic order turn out to depend on the background gauge parameters and are therefore pseudo constraints. These considerations are important for connecting path integral and canonical quantizations of gravity, in particular if one attempts a perturbative expansion."
http://arxiv.org/abs/0912.1823
A model for non-singular black hole collapse and evaporation
Sabine Hossenfelder, Leonardo Modesto, Isabeau Premont-Schwarz
6 pages, 3 figures
"We study the formation of a black hole and its subsequent evaporation in a model employing a minisuperspace approach to loop quantum gravity. In previous work the static solution was obtained and shown to be singularity-free. Here, we examine the more realistic dynamical case by generalizing the static case with help of the Vaidya metric. We track the formation and evolution of trapped surfaces during collapse and evaporation and examine the buildup of quantum gravitationally caused stress-energy preventing the formation of a singularity."
  • #1,046
http://arxiv.org/abs/0912.1748
Nonequilibrium Dynamics in Noncommutative Spacetime
Authors: Chong-Sun Chu, Chiu Man Ho
Abstract: We study the effects of spacetime noncommutativity on the nonequilibrium dynamics of particles in a thermal bath. We show that the noncommutative thermal bath does not suffer from any further IR/UV mixing problem in the sense that all the finite-temperature non-planar quantities are free from infrared singularities. We also point out that the combined effect of finite temperature and noncommutative geometry has a distinct effect on the nonequilibrium dynamics of particles propagating in a thermal bath: depending on the momentum of the mode of concern, noncommutative geometry may switch on or switch off their decay and thermalization. This momentum dependent alternation of the decay and thermalization rates could have significant impacts on the nonequilibrium phenomena in the early universe at which spacetime noncommutativity may be present. Our results suggest a re-examination of some of the important processes in the early universe such as reheating after inflation, baryogenesis and the freeze-out of superheavy dark matter candidates.
http://arxiv.org/abs/0912.1798
Quantum key distribution and 1 Gbit/s data encryption over a single fibre
Authors: Patrick Eraerds, Nino Walenta, Matthieu Legre, Nicolas Gisin, Hugo Zbinden
Abstract: We perform quantum key distribution (QKD) in the presence of 4 classical channels in a C-band dense wavelength division multiplexing (DWDM) configuration using a commercial QKD system. The classical channels are used for key distillation and 1 Gbps encrypted communication, rendering the entire system independent from any other communication channel than a single dedicated fibre. We successfully distil secret keys over fibre spans of up to 50 km. The separation between quantum channel and nearest classical channel is only 200 GHz, while the classical channels are all separated by 100 GHz. In addition to that we discuss possible improvements and alternative configurations, for instance whether it is advantageous to choose the quantum channel at 1310 nm or to opt for a pure C-band configuration.
http://arxiv.org/abs/0912.1475
Quantum nonlocality: How does Nature perform the trick?\cite{Bellprize}
Authors: N. Gisin
Abstract: Since our early childhood we know in our bones that in order to interact with an object we have either to go to it or to throw something at it. Yet, contrary to all our daily experience, Nature is nonlocal: there are spatially separated systems that exhibit nonlocal correlations. In recent years this led to new experiments, deeper understanding of the tension between quantum physics and relativity and to proposals for disruptive technologies.
  • #1,047
http://arxiv.org/abs/0912.2441
The group field theory approach to quantum gravity: some recent results
Daniele Oriti
15 pages, 5 figures, aipproc class, extended version of the proceedings of the XXV Max Born symposium: The Planck Scale, Wroclaw, 29th June-3rd July 2009
(Submitted on 12 Dec 2009)
"We introduce the key ideas behind the group field theory approach to quantum gravity, and the basic elements of its formalism. We also briefly report on some recent results obtained in this approach, concerning both the mathematical definition of these models, and possible avenues towards extracting interesting physics from them."
http://arxiv.org/abs/0912.2712
A bound on Planck-scale modifications of the energy-momentum composition rule from atomic interferometry
M. Arzano, J. Kowalski-Glikman, A. Walkus
5 pages
(Submitted on 14 Dec 2009)
"High sensitivity measurements in atomic spectroscopy were recently used in Amelino-Camelia et. al. to constraint the form of possible modifications of the energy-momentum dispersion relation resulting from Lorentz invariance violation (LIV). In this letter we show that the same data can be used successfully to set experimental bounds on deformations of the energy-momentum composition rule. Such modifications are natural in models of deformed Lorentz symmetry which are relevant in certain quantum gravity scenarios. We find the bound for the deformation parameter kappa to be a few orders of magnitude below the Planck scale and of the same magnitude as the next-to-leading order effect found in Amelino-Camelia et. al. We briefly discuss how it would be possible to distinguish between these two scenarios."
http://arxiv.org/abs/0912.2435
On Quantum Regge Calculus of Einstein-Cartan Theory
She-Sheng Xue
32 pages and 5 figures. Expanded from the brief letter "Quantum Regge Calculus of Einstein-Cartan theory" in Phys. Lett. B682 (2009) 300. Detailed calculation, references.
"This article presents detailed discussions and calculations of the recent letter "Quantum Regge Calculus of Einstein-Cartan theory" in Phys. Lett. B682 (2009) 300 [arXiv:0902.3407]. The Euclidean space-time is discretized by a 4-simplices complex. We adopt basic tetrad and spin-connection fields to describe the 4-simplices complex. Introducing diffeomorphism and local Lorentz invariant holonomy fields, we study a regularized Einstein-Cartan theory for the quantum dynamics of the 4-simplices complex and fermions. This regularized Einstein-Cartan action is shown to properly approaches to its continuum counterpart in the continuum limit. Based on the local Lorentz invariance, we derive the dynamical equations satisfied by invariant holonomy fields. In the mean-field approximation, we show the averaged size of 4-simplex, the element of the 4-simplices complex, has to be larger than the Planck length. This formulation provides a theoretical framework for analytical calculations and numerical simulations to study the quantum Einstein-Cartan theory."
  • #1,048
http://arxiv.org/abs/0912.2862
Groups of flux-like transformations in loop quantum gravity
J. M. Velhinho
3 pages. Proceedings of the 12th Marcel Grossmann Meeting, Paris, Jul 2009. Talk based on arXiv:0804.3765
(Submitted on 15 Dec 2009)
"We present a group of transformations in the quantum configuration space of loop quantum gravity that contains the set of all transformations generated by the flux variables."
http://arxiv.org/abs/0912.3142
Fractal universe and quantum gravity
Gianluca Calcagni
5 pages
(Submitted on 16 Dec 2009)
"We propose a field theory which lives in fractal spacetime and is argued to be Lorentz invariant, power-counting renormalizable, UV finite, and causal. The system flows from an ultraviolet fixed point, where spacetime has Hausdorff dimension 2, to an infrared limit coinciding with a standard four-dimensional field theory. Classically, the fractal-world where fields live dissipates energy-momentum in the bulk with integer topological dimension. However, the total energy-momentum is conserved. We consider the dynamics and the propagator of a scalar field. The spectrum has a mass gap between a massless mode and a continuum of massive modes. Implications for quantum gravity, cosmology, and the cosmological constant are discussed."
http://arxiv.org/abs/0912.3165
Equipartition of energy in the horizon degrees of freedom and the emergence of gravity
T. Padmanabhan
6 pages
"It is possible to provide a physical interpretation for the field equations of gravity based on a thermodynamical perspective. The virtual degrees of freedom associated with the horizons perceived by the local Rindler observers, play a crucial role in this approach. In this context, the relation S=E/2T between the entropy (S), active gravitational mass (E) and temperature (T) - obtained previously in gr-qc/0308070 [CQG, 21, 4485 (2004)] - can be reinterpreted as the law of equipartition E = (1/2) nkT where n is the number (density) of microscopic horizon degrees of freedom. Conversely, one can use the equipartition argument to provide a thermodynamic interpretation of even non-relativistic gravity. These results emphasize the intrinsic quantum nature of all gravitational phenomena and diminishes the distinction between thermal phenomena associated with local Rindler horizons and the usual thermodynamics of macroscopic bodies in non-inertial frames. Just like the original thermodynamic interpretation, these results also hold for a wide class of gravitational theories like the Lanczos-Lovelock models."
Brief mention:
http://pirsa.org/09120114/
On the Relation between Operator Constraint, Master Constraint, Reduced Phase Space, and Path Integral Quantisation, with Application to Quantum Gravity
Video lecture 16 December 2009
Muxin Han
http://arxiv.org/abs/0912.3011
Higher curvature counter terms cause the bounce in loop cosmology
Robert C. Helling
  • #1,049
http://arxiv.org/abs/0912.2935
Post-Minkowskian Gravity: Dark Matter as a Relativistic Inertial Effect?
Authors: Luca Lusanna (INFN, Firenze)
Abstract: A review is given of the theory of non-inertial frames (with the associated inertial effects and the study of the non-relativistic limit) in Minkowski space-time, of parametrized Minkowski theories and of the rest-frame instant form of dynamics for isolated systems admitting a Lagrangian description. The relevance and gauge equivalence of the clock synchronization conventions for the identification of the instantaneous 3-spaces (Euclidean only in inertial frames) are described. Then this formalism is applied to tetrad gravity in globally hyperbolic, asymptotically Minkowskian space-times without super-translations, where the equivalence principle implies the absence of global inertial frames. The recently discovered York canonical basis, diagonalizing the York-Lichnerowicz approach, allows to identify the gauge variables (inertial effects in general relativity) and the tidal ones (the gravitational waves of the linearized theory) and to clarify the meaning of the Hamilton equations. The role of the gauge variable ${}^3K$, the trace of the extrinsic curvature of the non-Euclidean 3-space (the York time not existing in Newton theory), as a source of inertial effects is emphasized. After the presentation of preliminary results on the linearization of tetrad gravity in the family of non-harmonic 3-orthogonal gauges with a free value of ${}^3K$, we define post-Minkowskian gravitational waves (without post-Newtonian approximations on the matter sources) propagating in a non-Euclidean 3-space, emphasizing the non-graviton-like aspects of gravity. It is conjectured that dark matter may be explained as a relativistic inertial effect induced by ${}^3K$: it would simulate the need to choose a privileged gauge connected with the observational conventions for the description of matter.
http://arxiv.org/abs/0912.3491
Sugawara-type constraints in hyperbolic coset models
Authors: Thibault Damour, Axel Kleinschmidt, Hermann Nicolai
(Submitted on 17 Dec 2009)
Abstract: In the conjectured correspondence between supergravity and geodesic models on infinite-dimensional hyperbolic coset spaces, and E10/K(E10) in particular, the constraints play a central role. We present a Sugawara-type construction in terms of the E10 Noether charges that extends these constraints infinitely into the hyperbolic algebra, in contrast to the truncated expressions obtained in arXiv:0709.2691 that involved only finitely many generators. Our extended constraints are associated to an infinite set of roots which are all imaginary, and in fact fill the closed past light-cone of the Lorentzian root lattice. The construction makes crucial use of the E10 Weyl group and of the fact that the E10 model contains both D=11 supergravity and D=10 IIB supergravity. Our extended constraints appear to unite in a remarkable manner the different canonical constraints of these two theories. This construction may also shed new light on the issue of `open constraint algebras' in traditional canonical approaches to gravity.
http://arxiv.org/abs/0912.3021
Emergent Abelian Gauge Fields from Noncommutative Gravity
Authors: A. Stern
Abstract: We construct exact solutions to noncommutative gravity following the formulation of Chamseddine and show that they are in general accompanied by Abelian gauge fields which are first order in the noncommutative scale. This provides a mechanism for generating cosmological electromagnetic fields from an expanding space-time background, and also leads to multipole-like fields surrounding black holes. Exact solutions to noncommutative Einstein-Maxwell theory can give rise to first order corrections to the metric tensor, as well as to the electromagnetic fields. This leads to first order shifts in the horizons of charged black holes.
http://arxiv.org/abs/0911.4817
Emergent Spacetime
Authors: Robert de Mello Koch, Jeff Murugan
(Submitted on 25 Nov 2009 (v1), last revised 16 Dec 2009 (this version, v2))
Abstract: We give an introductory account of the AdS/CFT correspondence in the 1/2-BPS sector of ${\cal N}=4$ super Yang-Mills theory.Six of the dimensions of the string theory are emergent in the Yang-Mills theory. In this article we suggest how these dimensions and local physics in these dimensions emerge. The discussion is aimed at non-experts.
http://arxiv.org/abs/0912.2678
New Physics at Low Accelerations (MOND): an Alternative to Dark Matter
Authors: Mordehai Milgrom (Weizmann Institute)
Abstract: I describe the MOND paradigm, which posits a departure from standard physics below a certain acceleration scale. This acceleration as deduced from the dynamics in galaxies is found mysteriously to agree with the cosmic acceleration scales defined by the present day expansion rate and by the density of `dark energy'. I put special emphasis on phenomenology and on critical comparison with the competing paradigm based on classical dynamics plus cold dark matter. I also describe briefly nonrelativistic and relativistic MOND theories.
  • #1,050
http://arxiv.org/abs/0912.4054
Coherent spin-networks
Eugenio Bianchi, Elena Magliaro, Claudio Perini
11 pages
(Submitted on 20 Dec 2009)
"In this paper we discuss a proposal of coherent states for Loop Quantum Gravity. These states are labeled by a point in the phase space of General Relativity as captured by a spin-network graph. They are defined as the gauge invariant projection of a product over links of Hall's heat-kernels for the cotangent bundle of SU(2). The labels of the state are written in terms of two unit-vectors, a spin and an angle for each link of the graph. The heat-kernel time is chosen to be a function of the spin. These labels are the ones used in the Spin Foam setting and admit a clear geometric interpretation. Moreover, the set of labels per link can be written as an element of SL(2,C). Therefore, these states coincide with Thiemann's coherent states with the area operator as complexifier. We study the properties of semiclassicality of these states and show that, for large spins, they reproduce a superposition over spins of spin-networks with nodes labeled by Livine-Speziale coherent intertwiners. Moreover, the weight associated to spins on links turns out to be given by a Gaussian times a phase as originally proposed by Rovelli."
http://arxiv.org/abs/0912.4093
Loop quantum cosmology and slow roll inflation
Abhay Ashtekar, David Sloan
8 pages, 1 table
(Submitted on 21 Dec 2009)
"In loop quantum cosmology the big bang is replaced by a quantum bounce which is followed by a robust phase of super-inflation. We show that this phase has an unforeseen implication: in presence of suitable inflationary potentials it funnels all dynamical trajectories to conditions which virtually guarantee a slow roll inflation with more than 68 e-foldings, without any input from the pre-big bang regime. This is in striking contrast to the situation in general relativity where it has been argued that the a priori probability of obtaining a slow roll inflation with N e-foldings is suppressed by a factor Exp(-3N)."
  • Beyond the Standard Models
