Loop-and-allied QG bibliography
In summary, Rovelli's program for loop gravity involves coupling the standard model to quantized QG loops, allowing for interactions between eigenvalues of length and momentum. This approach allows for non-perturbative calculations without infinity problems and does not require a continuum limit. The main difference in loop gravity is that the excitations of space are represented by polymers, or ball-and-stick models, that can be labeled with numbers to determine the volume and area of any region or surface. This allows for a more intuitive understanding of the geometry of the universe.
  • #2,486
Naturalness of asymptotically safe Higgs
Giulio Maria Pelaggi, Francesco Sannino, Alessandro Strumia, Elena Vigiani
(Submitted on 5 Jan 2017)
We introduce a model that contains a Higgs-like scalar with gauge, Yukawa and quartic interactions that enter a perturbative asymptotically safe regime at energies above a scale Λ. The model serves as a concrete example to test whether scalars masses unavoidably receive quantum correction of order Λ. The answer is that scalars can be naturally lighter. Although we do not have an answer to whether the Standard Model hypercharge coupling growth towards a Landau pole around Λ∼1040 GeV can be tamed by non-perturbative asymptotic safety, our toy-SM shows that such a possibility is worth exploring. In fact, if successful, it might also offer an explanation for the unbearable lightness of the Higgs.
Comments: 16 pages
Subjects: High Energy Physics - Phenomenology (hep-ph)
Report number: CERN-PH-TH-2017-001, CP3-Origins-2017-001, IFUP-TH/2017
Cite as: arXiv:1701.01453 [hep-ph]
(or arXiv:1701.01453v1 [hep-ph] for this versio
Likes atyy
  • #2,487
Detailed investigation of the duration of inflation in loop quantum cosmology for a Bianchi-I universe with different inflaton potentials and initial conditions
Killian Martineau, Aurélien Barrau, Susanne Schander
(Submitted on 10 Jan 2017)
There is a wide consensus on the correct dynamics of the background in loop quantum cosmology. In this article we make a systematic investigation of the duration of inflation by varying what we think to be the most important "unknowns" of the model: the way to set initial conditions, the amount of shear at the bounce and the shape of the inflaton potential.
Subjects: General Relativity and Quantum Cosmology (gr-qc); Cosmology and Nongalactic Astrophysics (astro-ph.CO); High Energy Physics - Phenomenology (hep-ph)
Cite as: arXiv:1701.02703 [gr-qc]
Likes atyy
  • #2,488
Numerical simulations of loop quantum Bianchi-I spacetimes
Peter Diener, Anton Joe, Miguel Megevand, Parampreet Singh
(Submitted on 20 Jan 2017)
Due to the numerical complexities of studying evolution in an anisotropic quantum spacetime, in comparison to the isotropic models, the physics of loop quantized anisotropic models has remained largely unexplored. In particular, robustness of bounce and the validity of effective dynamics have so far not been established. Our analysis fills these gaps for the case of vacuum Bianchi-I spacetime. To efficiently solve the quantum Hamiltonian constraint we perform an implementation of the Cactus framework which is conventionally used for applications in numerical relativity. Using high performance computing, numerical simulations for a large number of initial states with a wide variety of fluctuations are performed. Big bang singularity is found to be replaced by anisotropic bounces for all the cases. We find that for initial states which are sharply peaked at the late times in the classical regime and bounce at a mean volume much greater than the Planck volume, effective dynamics is an excellent approximation to the underlying quantum dynamics. Departures of the effective dynamics from the quantum evolution appear for the states probing deep Planck volumes. A detailed analysis of the behavior of this departure reveals a non-monotonic and subtle dependence on fluctuations of the initial states. We find that effective dynamics in almost all of the cases underestimates the volume and hence overestimates the curvature at the bounce, a result in synergy with earlier findings in isotropic case. The expansion and shear scalars are found to be bounded throughout the evolution.
Comments: 27 pages, 22 figures
Cite as: arXiv:1701.05824 [gr-qc]
(or arXiv:1701.05824v1 [gr-qc] for this version)
Submission history
Likes atyy
  • #2,489
https://arxiv.org/abs/1701.07420
Shape Dynamical Loop Gravity from a Conformal Immirzi Parameter
Patrick J. Wong
(Submitted on 25 Jan 2017)
The Immirzi parameter of loop quantum gravity is a one parameter ambiguity of the theory whose precise interpretation is not universally agreed upon. It is an inherent characteristic of the quantum theory as it appears in the spectra of geometric operators, despite being irrelevant at the classical lever. The parameter's appearance in the area and volume spectra to the same power as the Planck area suggest that it plays a role in determining the fundamental length scale of space. In fact, a consistent interpretation is that it represents a constant rescaling of the kinematical spatial geometry. An interesting realization is that promoting the Immirzi parameter to be a general conformal transformation leads to a system which can be identified as analogous to the linking theory of shape dynamics. A three-dimensional gravitational gauge connection is then constructed within the linking theory in a manner analogous to loop quantum gravity, thereby facilitating the application of the established procedure of loop quantization.
https://arxiv.org/abs/1701.07519
SO*(2N) coherent states for loop quantum gravity
Florian Girelli, Giuseppe Sellaroli
A SU(2) intertwiner with N legs can be interpreted as the quantum state of a convex polyhedron with N faces (when working in 3d). We show that the intertwiner Hilbert space carries a representation of the non-compact group SO*(2N). This group can be viewed as the subgroup of the symplectic group Sp(4N,R) which preserves the SU(2) invariance. We construct the associated Perelomov coherent states and discuss the notion of semi-classical limit, which is more subtle that we could expect. Our work completes the work by Freidel and Livine which focused on the U(N) subgroup of SO*(2N).
Likes kodama
  • #2,490
The black hole quantum atmosphere
Ramit Dey, Stefano Liberati, Daniele Pranzetti
(Submitted on 22 Jan 2017)
Ever since the discovery of black hole evaporation, the region of origin of the radiated quanta has been a topic of debate. Recently it was argued by Giddings that the Hawking quanta originate from a region well outside the black hole horizon by calculating the effective radius of a radiating body via the Stefan--Boltzmann law. In this paper we try to further explore this issue and end up corroborating this claim, using both a heuristic argument and a detailed study of the stress energy tensor. We show that the Hawking quanta originate from what might be called a quantum atmosphere around the black hole with energy density and fluxes of particles peaked at about 4M, running contrary to the popular belief that these originate from the ultra high energy excitations very close to the horizon. This long distance origin of Hawking radiation could have a profound impact on our understanding of the information and transplanckian problems.
Cite as: arXiv:1701.06161 [gr-qc]
  • #2,491
research papers on the topic of MOND as a low energy 4D QG effect esp in Verlinde emergent gravity theory
Anisotropic Distribution of High Velocity Galaxies in the Local Group
Indranil Banik, Hongsheng Zhao
(Submitted on 21 Jan 2017)
We recently showed that several Local Group (LG) galaxies have much higher radial velocities (RVs) than in a 3D dynamical model of it based on ΛCDM, the standard cosmological paradigm (MNRAS, stx151). 5 out of these 6 galaxies are located very close to a plane with root mean square thickness of only 88.2 kpc despite a radial extent of almost 1 Mpc. This plane also passes within 140 kpc of both the Milky Way (MW) and M31 and just 6 kpc from their mid-point. The orientation of the plane is such that the MW-M31 line is only 20∘ from lying within it.
We develop a basic model in which a past MW-M31 flyby encounter forms tidal dwarf galaxies that later settle into the recently discovered planes of satellites around the MW and M31. The MW-M31 orbital plane required by this scenario is oriented similarly to that of the LG dwarfs with anomalously high RVs. The fast relative motion of the MW and M31 at one time would lead to LG dwarfs being flung out via gravitational slingshot encounters. These encounters would likely be most efficient for objects flung out close to the MW-M31 orbital plane. This suggests a possible dynamical reason for our findings, which are otherwise difficult to explain as a chance alignment of isotropically distributed galaxies (probability < 0.01).
Comments: 13 pages, 8 figures, 7 tables. Submitted to the Monthly Notices of the Royal Astronomical Society in this form
Subjects: Astrophysics of Galaxies (astro-ph.GA)
Cite as: arXiv:1701.06559 [astro-ph.GA]
Perspective on MOND emergence from Verlinde's "emergent gravity" and its recent test by weak lensing
Mordehai Milgrom (Weizmann Institute), Robert H. Sanders (Kapteyn Institute)
(Submitted on 30 Dec 2016 (v1), last revised 17 Jan 2017 (this version, v2))
We highlight phenomenological aspects of Verlinde's recent proposal to account for the mass anomalies in galactic systems without dark matter -- in particular in their relation to MOND. Welcome addition to the MOND lore as it is, this approach have reproduced, so far, only a small fraction of MOND phenomenology, and is still rather tentative, both in its theoretical foundations and in its phenomenology. What Verlinde has extracted from this approach, so far, is a formula -- of rather limited applicability, and with no road to generalization in sight -- for the effective gravitational field of a spherical, isolated, static baryonic system. This formula cannot be used to calculate the gravitational field of disk galaxies, with their rich MOND phenomenology. Notably, it cannot predict their rotation curves, except asymptotically. It does not apply to the few-, or many-body problem; so, it cannot give, e.g., the two-body force between two galaxies, or be used to conduct N-body calculations of galaxy formation, evolution, and interactions. The formula cannot be applied to the internal dynamics of a system embedded in an external field, where MOND predicts important consequences. etc. MOND is backed by full-fledged, Lagrangian theories that can be, and are, routinely applied to all the above phenomena, and more. Verlinde's formula, as it now stands, strongly conflicts with solar-system and possibly earth-surface constraints, and cannot fully account for the mass anomalies in the cores of galaxy clusters (a standing conundrum in MOND). The recent weak-lensing test of the formula is, in fact, testing a cornerstone prediction of MOND, one that the formula does reproduce, and which has been tested before in the very same way.
Comments: 6 pages; added discussion of earth-surface effects
Subjects: Astrophysics of Galaxies (astro-ph.GA); Cosmology and Nongalactic Astrophysics (astro-ph.CO); General Relativity and Quantum Cosmology (gr-qc); High Energy Physics - Phenomenology (hep-ph); High Energy Physics - Theory (hep-th)
Cite as: arXiv:1612.09582 [astro-ph.GA]
A universal velocity dispersion profile for pressure supported systems: evidence for MONDian gravity across 7 orders of magnitude in mass
R. Durazo, X. Hernandez, B. Cervantes Sodi, S. F. Sanchez
(Submitted on 12 Jun 2015 (v1), last revised 2 Dec 2016 (this version, v2))
For any MONDian extended theory of gravity where the rotation curves of spiral galaxies are explained through a change in physics rather than the hypothesis of dark matter, a generic dynamical behavior is expected for pressure supported systems: an outer flattening of the velocity dispersion profile occurring at a characteristic radius, where both the amplitude of this flat velocity dispersion and the radius at which it appears are predicted to show distinct scalings with the total mass of the system. By carefully analyzing the dynamics of globular clusters and elliptical galaxies, we are able to significantly extend the astronomical diversity of objects in which MONDian gravity has been tested, from spiral galaxies, to the much larger mass range covered by pressure supported systems. We show that a universal projected velocity dispersion profile accurately describes various classes of pressure supported systems, and further, that the expectations of extended gravity are met, across seven orders of magnitude in mass. These observed scalings are not expected under dark matter cosmology, and would require particular explanations tuned at the scales of each distinct astrophysical system.
Comments: 12 pages, 15 figures 1 table
Cite as: arXiv:1506.04099 [astro-ph.GA]
dℓ(z) and BAO in the emergent gravity and the dark universe
Ding-fang Zeng
(Submitted on 3 Jan 2017)
We illustrate that ΛMOND cosmology following from E. Verlinde's emergent gravity idea which contains only constant dark energy and baryonic matters governed by linear inverse gravitation forces at and beyond galaxy scales fit with the luminosity distance v.s. redshift relationship, i.e. dℓ(z) of type Ia supernovae equally well as the standard ΛCDM cosmology does. But in a rather broad and reasonable parameter space, ΛMOND gives too strong baryon acoustic oscillation, i.e. BAO signals on the matter power spectrum contradicting with observations from various galaxy survey and counting experiments.
Comments: 4.2 two column style pages, 4 figures, version asking for comments
Subjects: Cosmology and Nongalactic Astrophysics (astro-ph.CO); High Energy Physics - Theory (hep-th)
Cite as: arXiv:1701.00690 [astro-ph.CO]
(or arXiv:1701.00690v1 [astro-ph.CO] for this version)
On the Davies-Unruh effect in a wide range of temperatures
Carlos E. Navia
(Submitted on 12 Jan 2017)
The Debye model of the specific heat of solid at low temperatures is incorporate in the Entropic Gravity Theory (EGT). Rather of a smooth surface, the holographic screen is considered as an oscillating elastic membrane, with a continuous range of frequencies, that cuts off at a maximum (Debye) temperature, TD. We show that at low temperatures T<TD, the conservation of the equivalence principle in EGT requires a modification of the Davies-Unruh effect. While the maintenance of Davies-Unruh effect requires a violation of the equivalence principle. These two possibilities are equivalents, because both can emulate the same quantity of dark matter. However, in both cases, the central mechanism is the Davies-Unruh effect, this seems to indicate that the modification of the Davies-Unruh effect emulates dark matter which in turn can be see as a violation of the equivalence principle. This scenario is promising to explain why MOND theory works at very low temperatures (accelerations) regime, i. e., the galaxies sector. We also show that in the intermediate region, for temperatures slightly lower or slightly higher than Debye temperature, EGT predicts the mass-temperature relation of hot X-ray galaxy clusters.
Comments: 4 pages, 4 figures
Cite as: arXiv:1701.03442 [astro-ph.GA]
(or arXiv:1701.03442v1 [astro-ph.GA] for this version)
  • #2,492
general Relativity and Quantum Cosmology
Time evolution in deparametrized models of loop quantum gravity
Mehdi Assanioussi, Jerzy Lewandowski, Ilkka Mäkinen
(Submitted on 6 Feb 2017)
An important aspect in understanding the dynamics in the context of deparametrized models of LQG is to obtain a sufficient control on the quantum evolution generated by a given Hamiltonian operator. More specifically, we need to be able to compute the evolution of relevant physical states and observables with a relatively good precision. In this article, we introduce an approximation method to deal with the physical Hamiltonian operators in deparametrized LQG models, and apply it to models in which a free Klein-Gordon scalar field or a non-rotational dust field is taken as the physical time variable. This method is based on using standard time-independent perturbation theory of quantum mechanics to define a perturbative expansion of the Hamiltonian operator, the small perturbation parameter being determined by the Barbero-Immirzi parameter β. This method allows us to define an approximate spectral decomposition of the Hamiltonian operators and hence to compute the evolution over a certain time interval. As a specific example, we analyze the evolution of expectation values of the volume and curvature operators starting with certain physical initial states, using both the perturbative method and a straightforward expansion of the expectation value in powers of the time variable. This work represents a first step towards achieving the goal of understanding and controlling the new dynamics developed in [25, 26].
Comments: 23 pages, 18 figures
Subjects: General Relativity and Quantum Cosmology (gr-qc); High Energy Physics - Theory (hep-th)
Cite as: arXiv:1702.01688 [gr-qc]
(or arXiv:1702.01688v1 [gr-qc] for this version)
  • #2,493
Loop-Quantum-Gravity Simplicity Constraint as Surface Defect in Complex Chern-Simons Theory
Muxin Han, Zichang Huang
(Submitted on 10 Feb 2017)
The simplicity constraint is studied in the context of 4d spinfoam models with cosmological constant. We find that the quantum simplicity constraint is realized as the 2d surface defect in SL(2,C) Chern-Simons theory in the construction of spinfoam amplitudes. By this realization of simplicity constraint in Chern-Simons theory, we are able to construct the new spinfoam amplitude with cosmological constant for arbitrary simplicial complex (with many 4-simplices). The semiclassical asymptotics of the amplitude is shown to reproduce correctly the 4-dimensional Einstein-Regge action with cosmological constant term.
Comments: 16 pages, 3 figures
Subjects: General Relativity and Quantum Cosmology (gr-qc); High Energy Physics - Theory (hep-th); Mathematical Physics (math-ph)
Cite as: arXiv:1702.03285 [gr-qc]
(or arXiv:1702.03285v1 [gr-qc] for this version)
  • #2,494
Hybrid loop quantum cosmology and predictions for the cosmic microwave background
Laura Castelló Gomar, Daniel Martín de Blas, Guillermo A. Mena Marugán, Javier Olmedo
(Submitted on 20 Feb 2017)
We investigate the consequences of the hybrid quantization approach for primordial perturbations in loop quantum cosmology, obtaining predictions for the cosmic microwave background and comparing them with data collected by the Planck mission. In this work, we complete previous studies about the scalar perturbations and incorporate tensor modes. We compute their power spectrum for a variety of vacuum states. We then analyze the tensor-to-scalar ratio and the consistency relation between this quantity and the spectral index of the tensor power spectrum. We also compute the temperature-temperature, electric-electric, temperature-electric, and magnetic-magnetic correlation functions. Finally, we discuss the effects of the quantum geometry in these correlation functions and confront them with observations.
Comments: 33 pages, 23 figures and 1 table
Report number: IGC-17|2-1
Cite as: arXiv:1702.06036 [gr-qc]
(or arXiv:1702.06036v1 [gr-qc] for this version)
  • #2,495
Gravity as an SU(1,1) gauge theory in four dimensions
Hongguang Liu, Karim Noui
(Submitted on 22 Feb 2017)
We start with the Hamiltonian formulation of the first order action of pure gravity with a full sl(2,C) internal gauge symmetry. We make a partial gauge-fixing which reduces sl(2,C) to its sub-algebra su(1,1). This case corresponds to a splitting of the space-time M=Σ×R where Σ inherits an arbitrary Lorentzian metric of signature (−,+,+). Then, we find a parametrization of the phase space in terms of an su(1,1) commutative connection and its associated conjugate electric field. Following the techniques of Loop Quantum Gravity, we start the quantization of the theory and we consider the kinematical Hilbert space on a given fixed graph Γ whose edges are colored with unitary representations of su(1,1). We compute the spectrum of area operators acting of the kinematical Hilbert space: we show that space-like areas have discrete spectra, in agreement with usual su(2) Loop Quantum Gravity, whereas time-like areas have continuous spectra. We conclude on the possibility to make use of this formulation of gravity to construct a holographic description of black holes in the framework of Loop Quantum Gravity.
Comments: 19 pages, 2 figures
Cite as: arXiv:1702.06793 [gr-qc]
(or arXiv:1702.06793v1 [gr-qc] for this version)
  • #2,496
https://arxiv.org/abs/1702.04137
Asymptotically safe cosmology - a status report
Alfio Bonanno, Frank Saueressig
(Submitted on 14 Feb 2017)
Asymptotic Safety, based on a non-Gaussian fixed point of the gravitational renormalization group flow, provides an elegant mechanism for completing the gravitational force at sub-Planckian scales. At high energies the fixed point controls the scaling of couplings such that unphysical divergences are absent while the emergence of classical low-energy physics is linked to a crossover between two renormalization group fixed points. These features make Asymptotic Safety an attractive framework for cosmological model building. The resulting scenarios may naturally give rise to a quantum gravity driven inflationary phase in the very early universe and an almost scale-free fluctuation spectrum. Moreover, effective descriptions arising from an renormalization group improvement permit a direct comparison to cosmological observations as, e.g. Planck data.
https://arxiv.org/abs/1702.04439
Black Hole Entropy from BMS Symmetry at the Horizon
S. Carlip
(Submitted on 15 Feb 2017 (v1), last revised 1 Mar 2017 (this version, v2))
Near the horizon, the obvious symmetries of a black hole spacetime---the horizon-preserving diffeomorphisms---are enhanced to a larger symmetry group with a BMS3 algebra. Using dimensional reduction and covariant phase space techniques, I investigate this augmented symmetry, and show that it is strong enough to determine the black hole entropy.
Likes kodama
  • #2,497
https://arxiv.org/abs/1703.01156
Quantum Surface and Intertwiner Dynamics in Loop Quantum Gravity
Alexandre Feller, Etera R. Livine
(Submitted on 3 Mar 2017)
We introduce simple generic models of surface dynamics in loop quantum gravity (LQG). A quantum surface is defined as a set of elementary patches of area glued together. We provide it with an extra structure of locality (nearest neighbors), thought of as induced by the whole spin network state defining the 3d bulk geometry around the quantum surface. Here, we focus on classical surface dynamics, using a spinorial description of surface degrees of freedom. We introduce two classes of dynamics, to be thought as templates for future investigation of LQG dynamics with in mind the dynamics of quantum black holes. The first defines global dynamics of the closure defect of the surface, with two basic toy-models, either a dissipative dynamics relaxing towards the closure constraint or a Hamiltonian dynamics precessing the closure defect. The second class of dynamics describes the isolated regime, when both area and closure defect are conserved throughout the evolution. The surface dynamics is implemented through U(N) transformations and generalizes to a Bose-Hubbard Hamiltonian with a local quadratic potential interaction. We briefly discuss the implications of modeling the quantum black hole dynamics by a surface Bose-Hubbard model.
Likes kodama
  • #2,498
A Covariant Version of Verlinde's Emergent Gravity
S. Hossenfelder
(Submitted on 4 Mar 2017)
A generally covariant version of Erik Verlinde's emergent gravity model is proposed. The Lagrangian constructed here allows an improved interpretation of the underlying mechanism. It suggests that de-Sitter space is filled with a vector-field that couples to baryonic matter and, by dragging on it, creates an effect similar to dark matter. We solve the covariant equation of motion in the background of a Schwarzschild space-time and obtain correction terms to the non-covariant expression. Furthermore, we demonstrate that the vector field can also mimic dark energy.
Comments: 14 pages, no figures
Cite as: arXiv:1703.01415 [gr-q
  • #2,499
https://arxiv.org/abs/1703.03710
The matter-ekpyrotic bounce scenario in Loop Quantum Cosmology
Jaume Haro, Jaume Amorós, Llibert Aresté Saló
(Submitted on 10 Mar 2017)
We will perform a detailed study of the matter-ekpyrotic bouncing scenario in Loop Quantum Cosmology using the methods of the dynamical systems theory. We will show that when the background is driven by a single scalar field, at very late times, in the contracting phase, all orbits depict a matter dominated Universe, which evolves to an ekpyrotic phase. After the bounce the Universe enters in the expanding phase, where the orbits leave the ekpyrotic regime going to a kination (also named deflationary) regime. Moreover, this scenario supports the production of heavy massive particles conformally coupled with gravity, which reheats the universe at temperatures compatible with the nucleosynthesis bounds and also the production of massless particles non-conformally coupled with gravity leading to very high reheating temperatures but ensuring the nucleosynthesis success. Dealing with cosmological perturbations, these background dynamics produce a nearly scale invariant power spectrum for the modes that leave the Hubble radius, in the contracting phase, when the Universe is quasi-matter dominated, whose spectral index and corresponding running is compatible with the recent experimental data obtained by PLANCK's team.
https://arxiv.org/abs/1703.03757
Canonical LQG operators and kinematical states for plane gravitational waves
F. Hinterleitner
In a 1+1 dimensional model of plane gravitational waves the flux-holonomy algebra of loop quantum gravity is modified in such a way that the new basic operators satisfy canonical commutation relations. Thanks to this construction it is possible to find kinematical solutions for unidirectional plane gravitational waves with finite geometric expectation values and fluctuations, which was problematic in a more conventional approach in a foregoing paper by the author and coauthors.
Likes kodama
  • #2,500
https://arxiv.org/abs/1703.03443
Classical and quantum: a conflict of interest
T. P. Singh
(Submitted on 9 Mar 2017)
We highlight three conflicts between quantum theory and classical general relativity, which make it implausible that a quantum theory of gravity can be arrived at by quantising classical gravity. These conflicts are: quantum nonlocality and space-time structure; the problem of time in quantum theory; and the quantum measurement problem. We explain how these three aspects bear on each other, and how they point towards an underlying noncommutative geometry of space-time.
Likes kodama
  • #2,501
Repulsive gravity induced by a conformally coupled scalar field implies a bouncing radiation-dominated universe
Vicente Antunes, Mario Novello
(Submitted on 8 Mar 2017)
In the present work we revisit a model consisting of a scalar field with a quartic self-interaction potential non-minimally (conformally) coupled to gravity [1]. When the scalar field vacuum is in a broken symmetry state, an effective gravitational constant emerges which, in certain regimes, can lead to gravitational repulsive effects when only ordinary radiation is coupled to gravity. In this case, a bouncing universe is shown to be the only cosmological solution admissible by the field equations when the scalar field is in such a broken symmetry state.
Comments: 10 pages, 1 figure
Cite as: arXiv:1703.03060 [gr-qc]
Poincaré gauge gravity: an emergent scenario
J.L. Chkareuli
The Poincar\'e gauge gravity (PGG) with the underlying vector fields of tetrads and spin-connections is perhaps the best theory candidate for gravitation to be unified with the other three elementary forces of nature. There is a clear analogy between local frame in PGG and local internal symmetry space in the Standard Model. As a result, the spin-connection fields, gauging the local frame Lorentz symmetry group SO(1,3)_{LF}, appear in PGG much as photons and gluons appear in SM. We propose that such an analogy may follow from their common emergent nature allowing to derive PGG in the same way as conventional gauge theories. In essence, we start with an arbitrary theory of some vector and fermion fields which possesses only global spacetime symmetries, such as Lorentz and translational invariance, in flat Minkowski space. The two vector field multiplets involved are proposed to belong, respectively, to the adjoint (A_{{\mu}}^{ij}) and vector (e_{{\mu}}^{i}) representations of the starting global Lorentz symmetry. We show that if these prototype vector fields are covariantly constrained, A_{{\mu}}^{ij}A_{ij}^{{\mu}}=M_{A} and e_{{\mu}}^{i}e_{i}^{{\mu}}=M_{e}, thus causing a spontaneous violation of the accompanying global symmetries (M_{A,e} are their proposed violation scales), then the only possible theory compatible with these length-preserving constraints is turned out to be the gauge invariant PGG, while the corresponding massless (pseudo)Goldstone modes are naturally collected in the emergent gauge fields of tetrads and spin-connections. In a minimal theory case being linear in a curvature we unavoidably come to the Einstein-Cartan theory. The extending theories with propagating spin-connection and tetrad modes are also considered and their possible unification with the Standard Model is briefly discussed.
Comments: 33 pages, submitted to Physical Review D. arXiv admin note: text overlap with arXiv:1305.6898
Subjects: General Relativity and Quantum Cosmology (gr-qc); High Energy Physics - Phenomenology (hep-ph); High Energy Physics - Theory (hep-th)
Cite as: arXiv:1703.01492 [gr-qc]
Gravastars in f(R,T) gravity
Amit Das, Shounak Ghosh, Swapan Das, B.K. Guha, Saibal Ray
(Submitted on 26 Feb 2017)
We propose a unique stellar model under the f(R,T) gravity by using the conjecture of Mazur-Mottola~\cite{Mazur2001,Mazur2004} which is known as gravastar and a viable alternative to the black hole as available in literature. This gravastar is described by the three different regions, viz., (I) Interior core region, (II) Intermediate thin shell, and (III) Exterior spherical region. The pressure within the interior region is equal to the constant negative matter density which provides a repulsive force over the thin spherical shell. This thin shell is assumed to be formed by a fluid of ultra relativistic plasma and the pressure, which is directly proportional to the matter-energy density according to Zel'dovich's conjecture of stiff fluid~\cite{zeldovich1972}, does counter balance the repulsive force exerted by the interior core region. The exterior spherical region is completely vacuum and assumed to be de Sitter spacetime which can be described by the Schwarzschild solution. Under this specification we find out a set of exact and singularity-free solution of the collapsing star which presents several other physically valid features within the framework of alternative gravity.
Comments: 7 pages, 4 figures
Cite as: arXiv:1702.08873 [gr-qc]
  • #2,502
Poincaré Gauge Gravity Cosmology
Hongchao Zhang, Lixin Xu
(Submitted on 2 Mar 2017)
In this work, we construct the logical framework of the Poincar\'e gauge gravity cosmology based on five postulations, and introduce the modified redshift relation within this framework. Then we solve a system with quadratic action and some other assumptions to get an analytic solution on background level. The evolution of the Universe on background can be reproduced from this solution without hypothesizing dark energy. Further, we use the type Ia supernova data set JLA to test the effect of the modified redshift relation under the constraints of system parameters. The results show that the constraint on some parameters are compact.
Comments: 5 pages, 3 figures, 2 tables
Cite as: arXiv:1703.00639 [gr-qc]
(or arXiv:1703.00639v1 [gr-qc] for this version)
Likes atyy
  • #2,503
Analogue Gravity Models From Conformal Rescaling
Sabine Hossenfelder, Tobias Zingg
(Submitted on 13 Mar 2017)
Analogue gravity is based on a mathematical identity between quantum field theory in curved space-time and the propagation of perturbations in certain condensed matter systems. But not every curved space-time can be simulated in such a way, because one does not only need a condensed matter system that generates the desired metric tensor, but that system then also has to obey its own equations of motion. And specifying the metric tensor that one wishes to realize usually overdetermines the underlying condensed matter system, such that its equations of motion are in general not fulfilled, in which case the desired metric does not have an analogue.
Here, we show that the class of metrics that have an analogue is bigger than what a first cursory consideration might suggest. This is due to the analogue metric only being defined up to a choice of parametrization of the perturbation in the underlying condensed matter system. In this way, the class of analogue gravity models can be vastly expanded. In particular, we demonstrate how this freedom of choice can be used to insert an intermediary conformal factor. Then, as a corollary, we find that any metric conformal to a Painlev\'e--Gullstrand type line element can, potentially, result as an analogue of a perturbation propagating in a non-viscous, barotropic fluid.
Comments: 12 pages
MSC classes: 83-XX
Cite as: arXiv:1703.04462 [gr-qc]
(or arXiv:1703.04462v1 [gr-qc] for this version)
Likes atyy
  • #2,504
Gravitational echoes from macroscopic quantum gravity effects
Carlos Barceló, Raúl Carballo-Rubio, Luis J. Garay
(Submitted on 31 Jan 2017 (v1), last revised 1 Feb 2017 (this version, v2))
New theoretical approaches developed in the last years predict that macroscopic quantum gravity effects in black holes should lead to modifications of the gravitational wave signals expected in the framework of classical general relativity, with these modifications being characterized by the existence of dampened repetitions of the primary signal. Here we use the fact that non-perturbative corrections to the near-horizon external geometry of black holes are necessary for these modifications to exist, in order to classify different proposals and paradigms with respect to this criterion and study in a neat and systematic way their phenomenology. Proposals that lead naturally to the existence of echoes in the late-time ringdown of gravitational wave signals from black hole mergers must share the replacement of black holes by horizonless configurations with a physical surface showing reflective properties in the relevant range of frequencies. On the other hand, proposals or paradigms that restrict quantum gravity effects on the external geometry to be perturbative, such as black hole complementarity or the closely related firewall proposal, do not display echoes. For the sake of completeness we exploit the interplay between the timescales associated with the formation of firewalls and the mechanism behind the existence of echoes in order to conclude that even unconventional distortions of the firewall concept (such as naked firewalls) do not lead to this phenomenon.
Comments: V1: 21 pages + references, 1 figure. V2: updated references
Subjects: General Relativity and Quantum Cosmology (gr-qc); High Energy Astrophysical Phenomena (astro-ph.HE); High Energy Physics - Theory (hep-th)
Cite as: arXiv:1701.09156 [gr-qc]
Flowing to the continuum in discrete tensor models for quantum gravity
Astrid Eichhorn, Tim Koslowski
(Submitted on 11 Jan 2017)
Tensor models provide a way to access the path-integral for discretized quantum gravity in d dimensions. As in the case of matrix models for two-dimensional quantum gravity, the continuum limit can be related to a Renormalization Group fixed point in a setup where the tensor size N serves as the Renormalization Group scale. We develop functional Renormalization Group tools for tensor models with a main focus on a rank-3 model for three-dimensional quantum gravity. We rediscover the double-scaling limit and provide an estimate for the scaling exponent. Moreover, we identify two additional fixed points with a second relevant direction in a truncation of the Renormalization Group flow. The new relevant direction might hint at the presence of additional degrees of freedom in the corresponding continuum limit.
Comments: 16 pages
Cite as: arXiv:1701.03029 [gr-qc]
(or arXiv:1701.03029v1 [gr-qc] for this version)
Likes atyy
  • #2,505
Quantum Metric and Entanglement on Spin Networks
Fabio M. Mele
(Submitted on 19 Mar 2017)
Motivated by the idea that, in the background-independent framework of a Quantum Theory of Gravity, entanglement is expected to play a key role in the reconstruction of spacetime geometry, we investigate the possibility of using the formalism of Geometric Quantum Mechanics (GQM) to give a tensorial characterization of entanglement on spin network states. Our analysis focuses on the simple case of a single link graph (Wilson line state) for which we define a dictionary to construct a Riemannian metric tensor and a symplectic structure on the space of states. The manifold of (pure) quantum states is then stratified in terms of orbits of equally entangled states and the block-coefficient matrices of the corresponding pulled-back tensors fully encode the information about separability and entanglement. In particular, the off-diagonal blocks define an entanglement monotone interpreted as a distance with respect to the separable state. As such, it provides a measure of graph connectivity. Finally, in the maximally entangled gauge-invariant case, the entanglement monotone is proportional to a power of the area of the surface dual to the link. This suggests a connection between the GQM formalism and the (simplicial) geometric properties of spin network states through entanglement.
Comments: 162 pages, 11 figures, Master Thesis
Subjects: General Relativity and Quantum Cosmology (gr-qc); High Energy Physics - Theory (hep-th); Quantum Physics (quant-ph)
Cite as: arXiv:1703.06415 [gr-qc]
Fisher Metric, Geometric Entanglement and Spin Networks
Goffredo Chirco, Fabio M. Mele, Daniele Oriti, Patrizia Vitale
(Submitted on 15 Mar 2017)
We introduce the geometric formulation of Quantum Mechanics in the quantum gravity context, and we use it to give a tensorial characterization of entanglement on spin network states. Starting from the simplest case of a single-link graph (Wilson line), we define a dictionary to construct a Riemannian metric tensor and a symplectic structure on the space of spin network states, showing how they fully encode the information about separability and entanglement, and, in particular, an entanglement monotone interpreted as a distance with respect to the separable state. In the maximally entangled gauge-invariant case, the entanglement monotone is proportional to a power of the area of the surface dual to the link thus supporting a connection between entanglement and the (simplicial) geometric properties of spin network states. We extend then such analysis to the study of non-local correlations between two non-adjacent regions of a generic spin network. In the end, our analysis shows that the same spin network graph can be understood as an information graph whose connectivity encodes, both at the local and non-local level, the quantum correlations among its parts. This gives a further connection between entanglement and geometry.
Comments: 51 pages, 3 figures
Cite as: arXiv:1703.05231 [gr-qc]
Holographic spin networks from tensor network states
Sukhwinder Singh, Nathan A. McMahon, Gavin K. Brennen
(Submitted on 1 Feb 2017)
In the holographic correspondence of quantum gravity, a global onsite symmetry at the boundary generally translates to a local gauge symmetry in the bulk. In this paper, we extend the tensor network based toy model for holography introduced in [arXiv:1701.04778] to incorporate this feature. We lift the multi-scale renormalization ansatz (MERA) representation of the ground state of a one dimensional (1D) local Hamiltonian, which has a global onsite symmetry, to a dual quantum state of a 2D lattice on which the symmetry appears gauged. We show how the 2D bulk state decomposes in terms of spin network states, which label a basis in the gauge-invariant sector of the bulk lattice. This decomposition is instrumental to obtain expectation values of gauge-invariant observables in the bulk, and also reveals that the bulk state is generally entangled between the gauge and the remaining bulk degrees of freedom that are not fixed by the symmetry. (In analogy with the holographic correspondence, we interpret the latter to possibly include "gravitational" degrees of freedom.) We illustrate these features for a particular subset of bulk states referred to as copy bulk states. We present numerical results for ground states of several 1D critical spin chains to illustrate that: (i) entanglement in the dual copy bulk states potentially depends on the central charge of the underlying conformal field theories, and (ii) the spectrum of a bulk density matrix, obtained by tracing out the gauge degrees of freedom, exhibits degeneracies, possibly suggesting an emergent symmetry in the non-gauge sector of the bulk. We also illustrate the possibility of emergent topological order in the bulk. More broadly, our holographic model translates the MERA, a tensor network state, to a superposition of spin network states, as they appear in lattice gauge theories in one higher dimension.
Comments: 21 pages, 18 figures
Subjects: Strongly Correlated Electrons (cond-mat.str-el); High Energy Physics - Theory (hep-th); Quantum Physics (quant-ph)
Cite as: arXiv:1702.00392 [cond-mat.str-el]
Likes atyy
  • #2,506
On the fate of the Hoop Conjecture in quantum gravity
Fabio Anzà, Goffredo Chirco
(Submitted on 15 Mar 2017 (v1), last revised 21 Mar 2017 (this version, v2))
We consider a closed region R of 3d quantum space modeled by SU(2) spin-networks. Using the concentration of measure phenomenon we prove that, whenever the ratio between the boundary ∂R and the bulk edges of the graph overcomes a finite threshold, the state of the boundary is always thermal, with an entropy proportional to its area. The emergence of a thermal state of the boundary can be traced back to a large amount of entanglement between boundary and bulk degrees of freedom. Using the dual geometric interpretation provided by loop quantum gravity, we interprete such phenomenon as a pre-geometric analogue of Thorne's "Hoop conjecture", at the core of the formation of a horizon in General Relativity.
Comments: 7 pages, 2 figures, minor improvements
Subjects: General Relativity and Quantum Cosmology (gr-qc); Quantum Physics (quant-ph)
Cite as: arXiv:1703.05241 [gr-qc]
Naturalizing Gravity of the Quantum Fields, and the Hierarchy Problem
Durmus Demir
It is shown that gravity can be incorporated into the Standard Model (SM) in a way solving the hierarchy problem. For this, the SM effective action in flat spacetime is adapted to curved spacetime via not only the general covariance but also the gauge invariance. For the latter, gauge field hard masses, induced by loops at the UV scale Λ, are dispelled by construing Λ as the constant value assigned to curvature. This gives way to an unprecedented mechanism for incorporating gravity into the SM in that the hierarchy problem is solved by transmutation of the Higgs boson Λ2--mass into the Higgs-curvature coupling, and the cosmological constant problem is alleviated by metamorphosis of the vacuum Λ4--energy into the Einstein-Hilbert term. Gravity emerges correctly if the SM is accompanied by a secluded dark sector sourcing non-interacting dark matter, dark energy and dark radiation. Physics beyond the SM, containing Higgs-phobic scalars that resolve the strong CP problem, flavor problem, baryogenesis and inflation, respects the hierarchy. Majorana neutrinos are naturally incorporated if Λ lies at the see-saw scale. This mechanism, in general, leaves no compelling reason to anticipate new particles at the LHC or higher-energy colliders.
Comments: 27 pages, 2 tables
Subjects: High Energy Physics - Phenomenology (hep-ph); General Relativity and Quantum Cosmology (gr-qc); High Energy Physics - Theory (hep-th)
  • #2,507
https://arxiv.org/abs/1703.07396
The Overview Chapter in Loop Quantum Gravity: The First 30 Years
Abhay Ashtekar, Jorge Pullin
(Submitted on 21 Mar 2017)
This is the introductory Chapter in the monograph Loop Quantum Gravity: The First 30 Years, edited by the authors, that was just published in the series "100 Years of General Relativity. The 8 invited Chapters that follow provide fresh perspectives on the current status of the field from some of the younger and most active leaders who are currently shaping its development. The purpose of this Chapter is to provide a global overview by bridging the material covered in subsequent Chapters. The goal and scope of the monograph is described in the Preface which can be read by following the Front Matter link at the website listed below.
https://arxiv.org/abs/1703.07556
Evolution of Universes in Causal Set Cosmology
Fay Dowker, Stav Zalel
(Submitted on 22 Mar 2017)
The causal set approach to the problem of quantum gravity is based on the hypothesis that spacetime is fundamentally discrete. Spacetime discreteness opens the door to novel types of dynamical law for cosmology and the Classical Sequential Growth (CSG) models of Rideout and Sorkin form an interesting class of such laws. It has been shown that a renormalisation of the dynamical parameters of a CSG model occurs whenever the universe undergoes a Big Crunch-Big Bang bounce. In this paper we propose a way to model the creation of a new universe after the singularity of a black hole. We show that renormalisation of dynamical parameters occurs in a CSG model after such a creation event. We speculate that this could realize aspects of Smolin's Cosmological Natural Selection proposal.
Likes kodama
  • #2,508
Fermions in Loop Quantum Cosmology
Beatriz Elizaga Navascués, Mercedes Martín-Benito, Guillermo A. Mena Marugán
(Submitted on 30 Mar 2017)
This work pioneers the quantization of primordial fermion perturbations in hybrid Loop Quantum Cosmology (LQC). We consider a Dirac field coupled to a spatially flat, homogeneous, and isotropic cosmology, sourced by a scalar inflaton, and treat the Dirac field as a perturbation. We describe the inhomogeneities of this field in terms of creation and annihilation variables, chosen to admit a unitary evolution if the Dirac fermion were treated as a test field. Considering instead the full system, we truncate its action at quadratic perturbative order and construct a canonical formulation. In particular this implies that, in the global Hamiltonian constraint of the model, the contribution of the homogeneous sector is corrected with a quadratic perturbative term. We then adopt the hybrid LQC approach to quantize the full model, combining the loop representation of the homogeneous geometry with the Fock quantization of the inhomogeneities. We assume a Born-Oppenheimer ansatz for physical states and show how to obtain a Schr\"odinger equation for the quantum evolution of the perturbations, where the role of time is played by the homogeneous inflaton. We prove that the resulting quantum evolution of the Dirac field is indeed unitary, despite the fact that the underlying homogeneous geometry has been quantized as well. Remarkably, in such evolution, the fermion field couples to an infinite sequence of quantum moments of the homogeneous geometry. Moreover, the evolved Fock vacuum of our fermion perturbations is shown to be an exact solution of the Schr\"odinger equation. Finally, we discuss in detail the quantum backreaction that the fermion field introduces in the global Hamiltonian constraint. For completeness, our quantum study includes since the beginning (gauge-invariant) scalar and tensor perturbations, that were studied in previous works.
Comments: 38 pages. Prepared to submit to JCAP
Cite as: arXiv:1703.10391 [gr-qc]
Loop quantum cosmology and singularities
Ward Struyve
Loop quantum gravity is believed to eliminate singularities such as the big bang and big crunch singularity. In order to base this belief on theoretical analysis, the notorious problems such as the problem of time and the problem of the actual meaning of singularities must be addressed and eventually overcome. In this paper, we address the problem of singularities in the context of the Bohmian formulation of loop quantum cosmology (which describes symmetry-reduced models of quantum gravity using the quantization techniques of loop quantum gravity). This formulation solves the mentioned conceptual problems. For example the notion of singularity is clear in this case, since there is an actual metric in addition to the wave function. As such, there is a singularity whenever this actual metric is singular. It is shown that in the loop quantum cosmology for a homogeneous and isotropic Friedmann-Lemaitre-Robertson-Walker space-time with arbitrary constant spatial curvature and possibly a cosmological constant, coupled to a massless homogeneous scalar field, a big bang or big crunch singularity is never obtained. This result is obtained without assuming any boundary conditions. This result should also be contrasted with the fact that in the Bohmian formulation of the Wheeler-DeWitt theory singularities may exist (depending on the wave function and the initial conditions for the metric and scalar field).
Comments: 17 pages, no figures, LaTeX
Cite as: arXiv:1703.10274 [gr-qc]
(or arXiv:1703.10274v1 [gr-qc] for this version)
Black Holes in Loop Quantum Gravity
Alejandro Perez
(Submitted on 27 Mar 2017)
This is a review of the results on black hole physics in the framework of loop quantum gravity. The key feature underlying the results is the discreteness of geometric quantities at the Planck scale predicted by this approach to quantum gravity. Quantum discreteness follows directly from the canonical quantization prescription when applied to the action of general relativity that is suitable for the coupling of gravity with gauge fields and specially with Fermions. Planckian discreteness and causal considerations provide the basic structure for the understanding of the thermal properties of black holes close to equilibrium. Discreteness also provides a fresh new look at more (at the moment) speculative issues such as those concerning the fate of information in black hole evaporation. The hypothesis of discreteness leads also to interesting phenomenology with possible observational consequences. The theory of loop quantum gravity is a developing program. This review reports its achievements and open questions in a pedagogical manner with an emphasis on quantum aspects of black hole physics.
Cite as: arXiv:1703.09149 [gr-qc]
(or arXiv:1703.09149v1 [gr-qc] for this version)
Inflation and Bounce from Classical and Loop Quantum Cosmology Imperfect Fluids
V.K. Oikonomou
We investigate how various inflationary and bouncing cosmologies can be realized by imperfect fluids with a generalized equation of state, in the context of both classical and loop quantum cosmology. With regards to the inflationary cosmologies, we study the intermediate inflation scenario, the R2 inflation scenario and two constant-roll inflation scenarios and with regards to the bouncing cosmologies we study the matter bounce scenario, the singular bounce and the super bounce scenario. Within the context of the classical cosmology, we calculate the spectral index of the power spectrum of primordial curvature perturbations, the scalar-to-tensor ratio and the running of the spectral index and we compare the resulting picture with the Planck data. As we demonstrate, partial compatibility with the observational data is achieved in the imperfect fluid description, however none of the above scenarios is in full agreement with data. This result shows that although it is possible to realize various cosmological scenarios using different theoretical frameworks, it is not guaranteed that all the theoretical descriptions are viable.
Comments: IJMPD Accepted
Cite as: arXiv:1703.09009 [gr-qc]
(or arXiv:1703.09009v1 [gr-qc] for this version)
  • #2,509
Resolving Cosmological Singularities
Ali H. Chamseddine, Viatcheslav Mukhanov
(Submitted on 18 Dec 2016)
We find a simple modification of the longitudinal mode in General Relativity which incorporates the idea of limiting curvature. In this case the singularities in contracting Friedmann and Kasner universes are avoided, and instead, the universe has a regular bounce which takes place during the time inversely proportional to the square root of the limiting curvature. Away from the bounce, corrections to General Relativity are negligible. In addition the non-singluar modification of General Relativity delivers for free a realistic candidate for Dark Matter.
Comments: 15 pages
Subjects: General Relativity and Quantum Cosmology (gr-qc); Cosmology and Nongalactic Astrophysics (astro-ph.CO); High Energy Physics - Theory (hep-th)
DOI: 10.1088/1475-7516/2017/03/009
Cite as: arXiv:1612.05860 [gr-qc]
(or arXiv:1612.05860v1 [gr-qc] for this version)
Subjects:
Cite as: arXiv:1703.10670 [gr-qc]
(or arXiv:1703.10670v1 [gr-qc] for this version)
Effective loop quantum cosmology as a higher-derivative scalar-tensor theory
Hongguang Liu, Karim Noui, Edward Wilson-Ewing, David Langlois
(Submitted on 31 Mar 2017)
Recently, Chamseddine and Mukhanov introduced a higher-derivative scalar-tensor theory which leads to a modified Friedmann equation allowing for bouncing solutions. As we note in the present work, this Friedmann equation turns out to reproduce exactly the loop quantum cosmology effective dynamics for a flat isotropic and homogeneous space-time. We generalize this result to obtain a class of scalar-tensor theories, belonging to the family of mimetic gravity, which all reproduce the loop quantum cosmology effective dynamics for flat, closed and open isotropic and homogeneous space-times.
Comments: 19 pages
Cite as: arXiv:1703.10812 [gr-qc]
On the canonical structure of general relativity with a limiting curvature and its relation to loop quantum gravity
Norbert Bodendorfer, Andreas Schäfer, John Schliemann
Chamseddine and Mukhanov recently proposed a modified version of general relativity that implements the idea of a limiting curvature. In the spatially flat, homogeneous, and isotropic sector, their theory turns out to agree with the effective dynamics of the simplest version of loop quantum gravity if one identifies their limiting curvature with a multiple of the Planck curvature. At the same time, it extends to full general relativity without any symmetry assumptions and thus provides an ideal toy model for full loop quantum gravity in the form of a generally covariant effective action known to all orders. In this paper, we study the canonical structure of this theory and point out some interesting lessons for loop quantum gravity. We also highlight in detail how the two theories are connected in the spatially flat, homogeneous, and isotropic sector.
Comments: 12 pages
  • #2,510
MOND as a regime of quantum gravity
Lee Smolin
(Submitted on 3 Apr 2017)
We propose that there is a regime of quantum gravity phenomena, for the case that the cosmological constant is small and positive, which concerns phenomena at temperatures below the deSitter temperature, or length scales larger than the horizon. We observe that the standard form of the equivalence principle does not apply in this regime; we consider instead that a weakened form of the equivalence principle might hold in which the ratio of gravitational to inertial mass is a function of environmental and global parameters. We consider possible principles to determine that function. These lead to behaviour that, in the limit of hbar to zero and the speed of light is taken to infinity, reproduces the modifications of Newtonian dynamics first proposed by Milgrom. Thus MOND is elucidated as coding the physics of a novel regime of quantum gravity phenomena.
We propose also an effective description of this regime in terms of a bi-metric theory, valid in the approximation where the metric is static. This predicts a new effect, which modifies gravity for radial motions.
Comments: LaTex 22 pages, one figure
Subjects: General Relativity and Quantum Cosmology (gr-qc); Astrophysics of Galaxies (astro-ph.GA); High Energy Physics - Theory (hep-th)
Cite as: arXiv:1704.00780 [gr-qc]
  • #2,511
https://arxiv.org/abs/1704.01141
Finite entanglement entropy and spectral dimension in quantum gravity
Michele Arzano, Gianluca Calcagni
(Submitted on 4 Apr 2017 (v1), last revised 6 Apr 2017 (this version, v2))
What are the conditions on a spacetime geometry leading to a finite entanglement entropy density? We prove a very general result based on the analytic properties of the spectral zeta function of the theory: If the spectral dimension of the spatial boundary flows to zero at any scale, then the entanglement entropy cannot be finite. On one hand, this conclusion negatively affects a wide class of theories with ultraviolet (UV) finite two-point functions, including some models with compact momentum space, non-local quantum gravity and many states of quantum geometry in discrete combinatorial approaches such as loop quantum gravity, spin foams and group field theory (GFT). Possible ways out are considered. On the other hand, the above necessary condition agrees with the finding of a finite entropy density in string theory. We show that also multi-fractional theories yield a finite entanglement entropy density, even in the cases where the propagator is not particularly well behaved in the UV.
https://arxiv.org/abs/1704.02404
An algorithm for quantum gravity phenomenology
Yuri Bonder
(Submitted on 7 Apr 2017)
Quantum gravity phenomenology is the strategy towards quantum gravity where the priority is to make contact with experiments. Here I describe what I consider to be the best procedure to do quantum gravity phenomenology. The key step is to have a generic parametrization which allows one to perform self-consistency checks and to deal with many different experiments. As an example I describe the role that the Standard Model Extension has played when looking for Lorentz violation.
https://arxiv.org/abs/1704.02905
CDT and the Big Bang
J. Ambjorn, Y. Watabiki
(Submitted on 10 Apr 2017)
We describe a CDT-like model where breaking of W3 symmetry will lead to the emergence of time and subsequently of space. Surprisingly the simplest such models which lead to higher dimensional spacetimes are based on the four "magical" Jordan algebras of 3x3 Hermitian matrices with real, complex, quaternion and octonion entries, respectively. The simplest symmetry breaking leads to universes with spacetime dimensions 3, 4, 6, and 10.
Likes kodama
  • #2,512
https://arxiv.org/abs/1704.03691
Towards a Cosmological subsector of Spin Foam Quantum Gravity
Benjamin Bahr, Sebastian Kloser, Giovanni Rabuffo
(Submitted on 12 Apr 2017)
We examine the four dimensional path integral for Euclidean quantum gravity in the context of the EPRL-FK spin foam model. The state sum is restricted to certain symmetric configurations which resembles the geometry of a flat homogeneous and isotropic universe. The vertex structure is specially chosen so that a basic concept of expansion and contraction of the lattice universe is allowed.
We compute the asymptotic form of the spin foam state sum in the symmetry restricted setting, and recover a Regge-type action, as well as an explicit form of the Hessian matrix, which captures quantum corrections. We investigate the action in the three cases of vacuum, a cosmological constant, and coupled to dust, and find that in all cases, the corresponding FRW dynamics is recovered in the limit of large lattices. While this work demonstrates a large intersection with computations done in the context of cosmological modelling with Regge Calculus, it is ultimately a setup for treating curved geometries in the renormalization of the EPRL-FK spin foam model.
Likes kodama
  • #2,513
https://arxiv.org/abs/1704.04067
From Coarse-Graining to Holography in Loop Quantum Gravity
Etera R. Livine
(Submitted on 13 Apr 2017)
We discuss the relation between coarse-graining and the holographic principle in the framework of loop quantum gravity and ask the following question: when we coarse-grain arbitrary spin network states of quantum geometry, are we integrating out physical degrees of freedom or gauge degrees of freedom? Focusing on how bulk spin network states for bounded regions of space are projected onto boundary states, we show that all possible boundary states can be recovered from bulk spin networks with a single vertex in the bulk and a single internal loop attached to it. This partial reconstruction of the bulk from the boundary leads us to the idea of realizing the Hamiltonian constraints at the quantum level as a gauge equivalence reducing arbitrary spin network states to one-loop bulk states. This proposal of "dynamics through coarse-graining" would lead to a one-to-one map between equivalence classes of physical states under gauge transformations and boundary states, thus defining holographic dynamics for loop quantum gravity.
Likes kodama
  • #2,514
Interpreting the isolated horizon boundary condition in terms of higher gauge theory
Thomas Zilker
(Submitted on 16 Mar 2017)
The purpose of this letter is to point out a relation between the boundary condition satisfied by spherically symmetric isolated horizons (formulated in terms of Ashtekar-Barbero variables) and the source-target matching condition (also known as fake flatness condition) in higher gauge theory. This relation may prove useful in the attempt to quantize the isolated horizon boundary condition which is in turn a possible starting point for the search for black hole solutions in the full theory of loop quantum gravity. Also, since a 2-connection is the mathematical object required for describing the parallel transport of 1-dimensional objects, the relation presented in this letter may provide further insight into the coupling of LQG to string-like objects investigated in other contexts.
Comments: 4 pages
Cite as: arXiv:1703.05620 [gr-qc]
(or arXiv:1703.05620v1 [gr-qc] for this version)
Edge modes and corner ambiguities in 3d Chern-Simons theory and gravity
Marc Geiller
(Submitted on 14 Mar 2017)
Boundaries in gauge field theories are known to be the locus of a wealth of interesting phenomena, as illustrated for example by the holographic principle or by the AdS/CFT and bulk-boundary correspondences. In particular, it has been acknowledged for quite some time that boundaries can break gauge invariance, and thereby turn gauge degrees of freedom into physical ones. There is however no known systematic way of identifying these degrees of freedom and possible associated boundary observables. Following recent work by Donnelly and Freidel, we show that this can be achieved by extending the covariant Hamiltonian formalism so as to make it gauge-invariant under arbitrary large gauge transformations. This can be done at the expense of introducing new boundary fields, which in turn determine new boundary symmetries and observables. We present the general framework behind this construction, and find the conditions under which it can be applied to an arbitrary Lagrangian. By studying the example of Abelian Chern-Simons theory, we then show that the new boundary observables in this case are nothing but the edge currents that are known to describe quantum Hall states. In three-dimensional gravity, the non-Abelian nature of the gauge transformations does however lead to a richer boundary theory. We derive the new boundary observables and show that they satisfy a covariant ISU(2) Kac-Moody affine algebra. We expect that this will play a major role for the quantization of gravity in finite regions.
Comments: 50+7 pages
Cite as: arXiv:1703.04748 [gr-qc]
(or arXiv:1703.04748v1 [gr-qc] for this version)
Likes atyy
  • #2,515
On effective loop quantum geometry of Schwarzschild interior
Jerónimo Cortez, William Cuervo, Hugo A. Morales-Técotl, Juan C. Ruelas
(Submitted on 11 Apr 2017)
The success of loop quantum cosmology to resolve classical singularities of homogeneous models has led to its application to the classical Schwarzschild black hole interior, which takes the form of a homogeneous Kantowski-Sachs model. The first steps of this were done in pure quantum mechanical terms, hinting at the traversable character of the would-be classical singularity, and then others were performed using effective heuristic models capturing quantum effects that allowed a geometrical description closer to the classical one but avoided its singularity. However, the problem of establishing the link between the quantum and effective descriptions was left open. In this work, we propose to fill in this gap by considering the path-integral approach to the loop quantization of the Kantowski-Sachs model corresponding to the Schwarzschild black hole interior. We show that the transition amplitude can be expressed as a path integration over the imaginary exponential of an effective action which just coincides, under some simplifying assumptions, with the heuristic one. Additionally, we further explore the consequences of the effective dynamics. We prove first that such dynamics imply some rather simple bounds for phase-space variables, and in turn, remarkably, in an analytical way, they imply that various phase-space functions that were singular in the classical model are now well behaved. In particular, the expansion rate, its time derivative, and the shear become bounded, and hence the Raychaudhuri equation is finite term by term, thus resolving the singularities of classical geodesic congruences. Moreover, all effective scalar polynomial invariants turn out to be bounded.
Comments: 26 pages, matches the PRD published version
Journal reference: Phys.Rev. D95 (2017) no.6, 064041
DOI: 10.1103/PhysRevD.95.064041
Cite as: arXiv:1704.03362 [gr-qc]
Likes atyy
  • #2,516
New boundary variables for classical and quantum gravity on a null surface
Wolfgang Wieland
(Submitted on 24 Apr 2017)
The covariant Hamiltonian formulation for general relativity is studied in terms of self-dual variables on a manifold with an internal and lightlike boundary. At this inner boundary, new canonical variables appear: a spinor and a spinor-valued two-form that encode the entire intrinsic geometry of the null surface. At a two-dimensional cross-section of the boundary, quasi-local expressions for the generators of two-dimensional diffeomorphisms, time translations, and dilatations of the null normal are introduced and written in terms of the new boundary variables. In addition, a generalisation of the first-law of black-hole thermodynamics for arbitrary null surfaces is found, and the relevance of the framework for non-perturbative quantum gravity is stressed and explained.
Comments: 41 pages, one figure
Cite as: arXiv:1704.07391 [gr-qc]
(or arXiv:1704.07391v1 [gr-qc] for this version)
Likes atyy
  • #2,517
https://arxiv.org/abs/1705.01554
SYK-like Tensor Models on the Lattice
Prithvi Narayan, Junggi Yoon
(Submitted on 3 May 2017)
We study large N tensor models on lattice without disorder. We introduce techniques which can be applied to a wide class of models, and illustrate it by studying some specific rank-3 tensor models. In particular, we study Klebanov-Tarnopolsky model on lattice, Gurau-Witten model (by treating it as a tensor model on four sites) and also a new model which interpolates between these two models. In each model, we evaluate various four point functions at large N and strong coupling, and discuss their spectrum and long time behaviours. We find similarities as well as differences from SYK model. We also generalize our analysis to rank-D tensor models where we obtain analogous results as D=3 case for the four point functions which we computed. For D>5, we are able to compute the next-to-subleading 1/N corrections for a specific four point function.
https://arxiv.org/abs/1705.01848
Impact of topology in foliated Quantum Einstein Gravity
W.B. Houthoff, A. Kurov, F. Saueressig
(Submitted on 4 May 2017)
We use a functional renormalization group equation tailored to the Arnowitt-Deser-Misner formulation of gravity to study the scale-dependence of Newton's coupling and the cosmological constant on a background spacetime with topology S^1xS^d. The resulting beta functions possesses a non-trivial renormalization group fixed point, which may provide the high-energy completion of the theory through the asymptotic safety mechanism. The fixed point is robust with respect to changing the parametrization of the metric fluctuations and regulator scheme. The phase diagrams show that this fixed point is connected to a classical regime through a crossover. In addition the flow may exhibit a regime of "gravitational instability", modifying the theory in the deep infrared. Our work complements earlier studies of the gravitational renormalization group flow on a background topology S^1xT^d and establishes that the flow is essentially independent of the background topology.
  • #2,518
https://arxiv.org/abs/1705.01964
Discrete Gravity on Random Tensor Network and Holographic Rényi Entropy
Muxin Han, Shilin Huang
In this paper we apply the discrete gravity and Regge calculus to tensor networks and Anti-de Sitter/conformal field theory (AdS/CFT) correspondence. We construct the boundary many-body quantum state |Ψ⟩ using random tensor networks as the holographic mapping, applied to the Wheeler-deWitt wave function of bulk Euclidean discrete gravity in 3 dimensions. The entanglement R\'enyi entropy of |Ψ⟩ is shown to holographically relate to the on-shell action of Einstein gravity on a branch cover bulk manifold. The resulting R\'enyi entropy Sn of |Ψ⟩ approximates with high precision the R\'enyi entropy of ground state in 2-dimensional conformal field theory (CFT). In particular it reproduces the correct n dependence. Our results develop the framework of realizing the AdS3/CFT2 correspondence on random tensor networks, and provide a new proposal to approximate CFT ground state.
  • #2,519
https://arxiv.org/abs/1705.02685
Conformal Anomaly and Off-Shell Extensions of Gravity
Krzysztof A. Meissner, Hermann Nicolai
(Submitted on 7 May 2017)
The gauge dependence of the conformal anomaly for spin 3/2 and spin 2 fields in non-conformal supergravities has been a long standing puzzle. In this Letter we argue that the `correct' gauge choice is the one that follows from requiring all terms that would imply a violation of the Wess-Zumino consistency condition to be absent in the counterterm, because otherwise the usual link between the anomaly and the one-loop divergence becomes invalid. Remarkably, the `good' choice of gauge is the one that confirms our previous result that a complete cancellation of conformal anomalies in D=4 can only be achieved for N-extended (Poincar\'e) supergravities with N≥5.
  • #2,520
https://arxiv.org/abs/1705.05558
Functional perturbative RG and CFT data in the ε-expansion
Alessandro Codello, Mahmoud Safari, Gian Paolo Vacca, Omar Zanusso
(Submitted on 16 May 2017)
We show how the use of standard perturbative RG allows for a renormalization group based computation of both the spectrum and the coefficients of the operator product expansion (OPE) for a given universality class. The task is greatly simplified by a straightforward generalization of perturbation theory to a functional perturbative RG approach. We illustrate our procedure by obtaining the leading and next-to-leading corrections in the ϵ-expansion of spectrum and OPE coefficients of Ising and Lee-Yang universality classes and then give several results for the whole family of renormalizable multicritical models ϕ2n. The universal results explicitly match the ones recently derived in CFT frameworks.
https://arxiv.org/abs/1705.05417
Dimension and Dimensional Reduction in Quantum Gravity
S. Carlip
(Submitted on 15 May 2017)
A number of very different approaches to quantum gravity contain a common thread, a hint that spacetime at very short distances becomes effectively two dimensional. I review this evidence, starting with a discussion of the physical meaning of "dimension" and concluding with some speculative ideas of what dimensional reduction might mean for physics.
https://arxiv.org/abs/1705.05493
Quantum mechanix plus Newtonian gravity violates the universality of free fall
Matt Visser (Victoria University of Wellington)
Classical point particles in Newtonian gravity obey, as they do in general relativity, the universality of free fall. However classical structured particles, (for instance with a mass quadrupole moment), need not obey the universality of free fall. Quantum mechanically, an elementary "point" particle can be described by a localized wave-packet, for which we can define a probability quadrupole moment. This probability quadrupole can, under plausible hypotheses, affect the universality of free fall. This raises an important issue of principle, as possible quantum violations of the universality of free fall would fundamentally impact on our ideas of what "quantum gravity" might look like. I will present an estimate of the size of the effect, and discuss where if at all it might be measured.
https://arxiv.org/abs/1705.05585
Measuring the effects of Loop Quantum Cosmology in the CMB data
Spyros Basilakos, Vahid Kamali, Ahmad Mehrabi
In this Essay we investigate the observational signatures of Loop Quantum Cosmology (LQC) in the CMB data. First, we concentrate on the dynamics of LQC and we provide the basic cosmological functions. We then obtain the power spectrum of scalar and tensor perturbations in order to study the performance of LQC against the latest CMB data. We find that LQC provides a robust prediction for the main slow-roll parameters, like the scalar spectral index and the tensor-to-scalar fluctuation ratio, which are in excellent agreement within 1σ with the values recently measured by the Planck collaboration. This result indicates that LQC can be seen as an alternative scenario with respect to that of standard inflation.
https://arxiv.org/abs/1705.05696
Rotating black hole solutions in relativistic analogue gravity
Luca Giacomelli, Stefano Liberati
Simulation and experimental realization of acoustic black holes in analogue gravity systems have lead to a novel understanding of relevant phenomena such as Hawking radiation or superradiance. We explore here the possibility to use relativistic systems for simulating rotating black hole solutions and possibly get an acoustic analogue of a Kerr black hole. In doing so we demonstrate a precise relation between non-relativistic and relativistic solutions and provide a new class of vortex solutions for relativistic systems. Such solutions might be used in the future as a test bed in numerical simulations as well as concrete experiments.
https://arxiv.org/abs/1705.05722
Quantum fluctuating geometries and the information paradox
Rodrigo Eyheralde, Miguel Campiglia, Rodolfo Gambini, Jorge Pullin
We study Hawking radiation on the quantum space-time of a collapsing null shell. We use the geometric optics approximation as in Hawking's original papers to treat the radiation. The quantum space-time is constructed by superposing the classical geometries associated with collapsing shells with uncertainty in their position and mass. We show that there are departures from thermality in the radiation even though we are not considering back reaction. One recovers the usual profile for the Hawking radiation as a function of frequency in the limit where the space-time is classical. However, when quantum corrections are taken into account, the profile of the Hawking radiation as a function of time contains information about the initial state of the collapsing shell. More work will be needed to determine if all the information can be recovered. The calculations show that non-trivial quantum effects can occur in regions of low curvature when horizons are involved, as for instance advocated in the firewall scenario.
Likes kodama
  • Beyond the Standard Models
