Mythbusters: Blow your own sail
  • Thread starter Trev
In summary, the boat is being propelled by atmospheric pressure. The moving body of air between the fan and the sail has a lower pressure relative to the still air around the boat at right angles to the flow of air to the sail. As a consequence the air around the boat rushes into the space and results in increased mass pushing on the sail.
  • #71
Yes, Andrew. I think you are on the right track. There's a control experiment that would eliminate the complications introduced by the rearward component of air entering the fan. Use a rocket instead of the fan to generate a highly directional flow of gases onto the sail. The source of the flow, including the fuel, would be contained in the boat so no flow of external matter (air) is involved. Would such a vehicle go forward, backward or nowhere?
  • #72
georgir said:
it really doesn't matter if the sail isn't too good at reversing the stream velocity, all that's needed is for it to stop most of it from going forward and reverse just enough of it.
Exactly.
  • #73
He isn't just on the right track, in post #62 he has already shown mathematically that the boat can gain forward momentum. His then stated conclusion to the opposite reminds me of the DDWFTTW discussions, where people just couldn't accept something counter-intuitive to them, despite mathematical and practical proof. And "people" includes several physics professors here.
http://en.wikipedia.org/wiki/Blackbird_(land_yacht)
  • #74
It is more a matter of figuring out what is actually happening. So long as there is a net movement of air rearward, the boat can experience a forward force on the sail. That is all I am saying. This is not based on intuition. It is based on the application of the law of conservation of momentum.
If the fan is pointed directly at the sail so that it builds up higher pressure behind sail it transfers potential (PV) energy into the air behind the sail. If the fan were to stop, thereby reducing its forward pressure on that air, the higher than ambient internal pressure in that mass of air behind the sail would then result in rearward movement of that air and the boat would be pushed forward (conservation of momentum). That is, I think, what is happening in the Mythbusters video. That is why, I think, the boat is pushed forward only when the direction of the airflow from the fan is moved to the side. I also think that the rear movement of air involves a larger mass of air than was moved forward, which I have explained.
AM
  • #75
That is totally trivial. The discussion was about the net force on the boat, not just on the sail.
So what happens in the video where the fan always points the same way?
Sure, but that doesn't necessitate a greater flow rate at the sail than at the fan, as your own analysis in post #62 shows.
  • #76
If the fan is simply maintaining greater than ambient pressure on the sail, the flow rate forward through the fan would be reduced due to that increased pressure. It would have to pull in only enough air to replace the amount of spillage from the sides of the sail. I think we agree, and the experiment agrees, that this does not produce forward momentum.
When the fan is directed to the side, the pressurized volume of air between the fan and sail would be pushed backward from the sail and the sail and boat pushed forward. Whether that will be greater than the forward flow through the fan at that point is difficult to say without some measurements. That is why I suggest turning the fan off. But it does appear to be enough to cause a bit of forward momentum even with the fan on.
Better still would be to have the fan push air into a balloon, build up the pressure and then turn the fan off letting the air in the balloon shoot backward. That is essentially how a jet engine operates, except that it draws air in from in front so it can operate continuously.
The boat doesn't move.
AM
  • #77
No. Neither me, nor the experiment, nor your own math agrees with that conclusion.
I'm talking about the controlled experiment on the table, not the MB video. Can't you see the embedded video above? Try clicking on the link below:
www.youtube.com/watch?v=0CrXvOKPymk&t=71
  • #78
The premise is that the only air that is escaping is the air moving sideways due to the higher pressure between the fan and the sail. Are you suggesting that air moving sideways off the sail imparts forward momentum?
Ok. That is a very interesting demonstration. It does not appear that there is a net rearward flow of air there. There may be some very subtle effects due to turbulence at the sail edges. Fluid dynamics can be rather complicated. I would want to experiment with different sail and fan configurations. So I don't have an explanation at the moment but I will think about it.
AM
  • #79
That premise is flawed. The sail is not a flat surface, but has the upper/lower edges bent backwards, so the air leaving the sail across those edges has backwards momentum.
Of course there is, for the same reason as stated above.
  • #80
You may be right, but my point was that it is not apparent. A smoke trail might help to see if your theory that air is actually flowing backward off that sail is correct.
Perhaps you understand exactly how an airplane wing provides lift. I don't. There are several theories and still a lot of controversy over the physics of flight. See this, for example. Regardless of how the wing does it, it appears from principles of physics that in order to impart upward force, there has to be a net downward movement of air around the wing. This situation is a bit different than an airplane wing, but I think the same basic principle applies. I would be interested in hearing any comments you or others may have.
AM
  • #81
How else do you expect it to flow along the sail, other than parallel to the surface?
Yes, there is, but Bernoulli also applies. There is no contradiction between the two, so the debates are pointless. Look at the countless old threads on this.
  • #82
AM
Wat? No. We undertstand how airplane wings work. That article just discusses methods for simulating it. Edit: This is quite clearly stated near the start of the post.
As an example of this, look at the telltales on a sailboat. These are the little bits of string or tape attached to the sail that indicate airflow over the sail. Under some circumstances the telltales will reverse, showing you have reverse airflow over the sail (the wind loops around like a vortex). Obviously this is bad.
  • #83
That's not a good example for the mechanism discussed here, because the flow relative to that sail boat is uniform on a much larger scale, than the size of the sail.
In contrast, the flow generated by the fan here is much smaller than the sail they used. In particular it doesn't extend to the edges, so the air can flow parallel the sail surface at the edges. This wouldn't work if the fan was bigger than the sail.
  • #84
Rather than nice parallel airflow (edit: along the sail) you likely have massive turbulence, similar to a stalled plane wing.
@AT: Don't get me wrong though. I am not saying this boat does not work. It does and I can see you understand why.
  • #85
A stalled wing is another bad example, for the same reason I explained in post #83.
  • #86
Are we at least agreed there is turbulence? I don't remember the video. Was it a square sail powered from behind? In that case look at the side edges and see if they are flapping randomly or if there is smooth laminar flow over them. I'd be astonished if the sides weren't flapping about like mad.
  • #87
That is almost trivially true. Nobody claims that this is perfectly laminar flow, but it can be directed enough to work.
  • #88
rcgldr said:
The amount of air moving forward also accumulates as over time, an increasingly longer column of air is shifting forwards to continously fill in the lower pressure zone being created by the fan, but update - much of that air flow well behind the boat will have a vertical component as well as a horizontal component, but I don't know how the direction of flow varies versus distance behind the boat. Since the center of mass of the boat and air is not moving, then the continously backwards flow must be greater than the continously forward flow, despite the velocity differences in the immediate vincity of the sail boat, so that the center of mass of the affected air moves backwards as the boat moves forwards. At some point behind the boat, part of the backwards flow will circulate into the forwards flow, but the net flow has to be backwards as the boat moves forwards.
(Wondering how I got sucked into this thread)...
Last time we discussed this, we weren't allowed to say suck... I probably missed the train here, but I'll post anyway.
I just wan't to agree to rcgldr and Andrew Mason's statements that there are forces that pulls the boat backwards. There is a low pressure volume behind the boat, caused by the propeller, causing the boat to move towards it. Also (and I think this is a different force-dynamics) the propeller accelerates a directed mass of air closely behind the propeller, that "sucks" the boat backwards. Both of these forces are small though, compared to the (inefficient) propeller-sail-thrust.
The reason why suction is small, is that it is wrong to assume that air going into the propeller comes from behind the boat. It comes from everywhere. That's why Newton is not violated. Shortly behind the propeller, airflow is unidirectionally forwards, but then the direction dissipates. The low pressure volume behind the boat is filled with air from all directions. The thrust sum from the propeller-sail- system, however, has one direction, forwards.
Imagine a vacuum-cleaner. Pointing the pipe, without attachments, forwards, what is the experienced pulling force to holding the pipe, with a 2000 watt motor? And imagine a similar power leaf blower...
Thrust is directional, suction not so much. That, and Newton's laws, explains the result i MB.
Alternative solution: Say the sail reflects backwards the same molecules of air back into the propeller, and it cycles. There is an outer hemisphere of air moving from the sail to the propeller, filled with a forwards flow from the propeller to the sail. This system would also move the boat forwards, as air from this system would friction surrounding air producing a net forward motion. Like a paddle steamer.
Vespa71P.S. This device baffles me: http://demolab.phys.virginia.edu/demos/demos.asp?Demos=H&Subject=1&Demo=1H10.20#subtopic They must have deliberately designed it to prove some mistaken point. Note the rigid flat sail.
  • #89
What matters for Newton is how the prop and sail change the momentum of the air, not where it came from to the prop.
That doesn't help, but makes it less efficient.
  • #90
This thread is so long! So did a unanimous answer reveal itself?
My two badly damaged cents-
Like most vessels the boat would have a trim by stern i.e. lower in the water at aft. If the same force is applied to both directions the boat will have a resultant force slightly in the forward direction because a boat is always easier to move forward.
Also my problem with the air inertia theory is that all the reverse force being generated by the fan is directly used to push the boat aft mechanically without transmission loss.
The exact same force is being given to the air. But the transmission losses must be huge!
Or am I mad??
  • #91
That is completely irrelevant. Different drag between forwards and backwards movment cannot move the boat or determine whether it moves forwards or backwards.
The relevant force is that on the sail, which is greater than the one used to accelerate the air, because the air's momentum is partially reversed by the sail, not just canceled.
  • #92
A.T. said:
That is completely irrelevant. Different drag between forwards and backwards movment cannot move the boat or determine whether it moves forwards or backwards.The relevant force is that on the sail, which is greater than the one used to accelerate the air, because the air's momentum is partially reversed by the sail, not just canceled.
So the force being experienced by the sail is more than that being supplied by the fan? I am sorry if I seem stupid.
As to the matter of the trim- I work on ships and can assure you that boat design and trim have a substantial effect on speed. Given an equal force a vessel will move forward much more easily
  • #93
Yes
It's not about which way it would move faster if it was pushed that way. It's about whether that combination of fan & sail can push it forwards at all.
Likes Rippetherocker
  • #94
Trim by stern is more a powerboat thing. On a sailing vessel, the wind hitting the sail from behind will naturally pivot the boat about its centre of mass and push the bow (front) of the boat down. An aggressively handled sailboat is very wet: you get green water coming in over the bow all the time. Your objective is to find the optimum balance between sail area and not becoming a submarine.
I find the mythbusters airboat interesting in that it crosses over between sails and mechanical propulsion. All I can tell you about it is that without a keel and being unable to pivot the propeller due to the need to blow its own sail, it's not going to have any significant directional control, and will be very hard to keep moving in anythign except small, random circles.
  • #95
Andrew Mason said:
Ok. Here is the math. Let's assume a perfectly elastic rebound of the air from the sail, which is the best you can do.
Fan sends a mass of air ##\Delta t\dot m## forward toward the sail at speed v. The (rearward) impulse to the boat from this is ##-v\Delta t\dot m##. This same mass of air strikes the sail and bounces off the sail at -v imparting a forward momentum of ##2v\Delta t\dot m## for a net forward momentum of ##v\Delta t\dot m##. Now if the fan had stopped, you would be fine. But it doesn't stop. It keeps pushing air forward. So, meanwhile, the fan has scooped another packet of air and is sending it forward at speed v creating another (rearward) impulse of ##-v\Delta t\dot m##. Net impulse = 0.
It might be easier to see with balls being scooped up and flung at the sail and bouncing back off the sail. So long as there is another ball that has been propelled toward the sail for every ball that is striking the sail, the net impulse to the boat will be 0. If not, perhaps you can explain where I am in error.
AM
Why did your analysis have 2 parcels of air pass through the fan, but only one of the two hit the sail? Steady state, the rate of mass hitting the sail is going to be the same as the rate of it passing through the fan, so as long as the ##\Delta V## of the airflow off the sail is larger than through the fan, it will (steady state) experience a net forward force. This just requires that the air rebound with some nonzero velocity on average off the sail. For example, if the fan is blowing air at some volumetric flow rate Q, the force the fan will feel (negative sign since force is to the rear of the boat) is simply going to be
##F_{fan} = -QV\rho##
where V is the exit velocity of the fan (I'm assuming the boat isn't moving and is in still air). If this air then rebounds off the sail on average at 0.05V in the rearward direction, the change in velocity at the sail will be 1.05V, so the force the sail will experience will be
##F_{sail} = 1.05QV\rho##
If these are both attached to the same craft, the craft will feel an overall net force of
##F_{fan} + F_{sail} = 1.05QV\rho - QV\rho = 0.05QV\rho##
Note that even though the rebound speed is very small compared to the fan exit speed, this net force is positive, indicating the boat will (very inefficiently) progress forwards.
  • #96
You could pivot or deform the sail to steer. But given that this is a completely inefficient propulsion scheme, it's rather pointless.
  • #97
I don't disagree but I was more discussing the inability to control your direction of travel, and not the ease with which you can rotate the boat by any number of means. A sailboat without a keel is worse than an ice skate without a blade. As you note by your comment on propulsion efficiency, the key is applying overwhelming amounts power in the desired direction.
  • #98
Most complete video investigation of this topic I saw so far:
Likes CWatters, nsaspook and DaveC426913
  • Classical Physics
  • Classical Physics
9K
  • Classical Physics
41K
  • Mechanical Engineering
  • Other Physics Topics
11K
  • Mechanics
