Newtonian stable universe model
In summary, the conversation discusses the possibility of a stable equilibrium in a finite spherical ball in Newtonian gravity theory, which is different from Einstein's universe model. However, there are limitations to this theory, such as the assumption of infinite distribution of homogeneous matter and the inability to use mathematics to show anything beyond this point. There is also a discussion on the stability of this finite ball depending on its size and scale, with the conclusion that there is no limit to the size of an object that can be in stable equilibrium in Newtonian physics. However, this theory cannot fully describe our universe as it does not take into account its actual composition.
Weran
I was discussing a problem related to Einstein's universe model. As we all know its an unstable equilibrium. So a small fluctuation in the density would result in an either expanding or contracting universe. However, I read that
"There are static and stable solutions in Newtonian gravity theory: stars, planets, etc... Even large nebulae. The Newtonian universe could be a large spherical ball in a state of stable equilibrium. The instability occurs mainly when you assume an infinite distribution of homogeneous matter, and even there, the potential is ill-defined. The theory breaks down at this point, and we can't use the math to show anything."
How can the Newtonian spherical ball be in stable equilibrium? What's the difference between this and Einstein's Universe model?
Space news on Phys.org
Welcome to the PF. :smile:
We require reputable references for discussion of topics like this. Can you link to where you read this? Are you aware of any peer-reviewed journal articles that discuss this?
It was in the physics stack exchange https://physics.stackexchange.com/q...the-only-way-to-show-that-the-universe-is-exp
I am not aware of it and that is the main problem. Its kind of a dead-end question...I know, but I thought maybe some poeple in this forum heard something like this and they can help me.
A Newtonian finite spherical ball. More precisely, a configuration of matter of finite extent, surrounded by vacuum extending out to infinity.
In the Einstein static universe, the spatial geometry is not flat. In Newtonian physics, the spatial geometry is flat.
Of course, the Newtonian ball must have several features for stability - pressure balancing gravity, and inability to radiate. The latter would seem to require something like absolute zero, but it is hard to square that with a source of pressure. So even the Newtonian ball is not really plausible for large distance and time scales (even with finite assumption).
In Newtonian physics, I don't know that there is any reason to require objects to radiate at finite temperatures. Of course, in Newtonian physics, there isn't really a microscopic model of matter at all; matter is just a blob of stuff described by density and pressure as a function of position. This model is self-consistent, but of course we have lots of evidence now that it isn't correct.
Likes PeroK
So I ll make some bulletpoints which one is correct ?
1 - A Newtonian finite ball is at stable equilibrium point and the size/scale does not affect this stability
2 - A Newtonian finite ball is at an unstable equilibrium point at all times
3 - A Newtonian finite ball is at the stable equilibrium point, however, the size/scale of this ball effects this stability. Hence after some scale, it becomes unstable.So I am right, the universe cannot be described by Newtonian finite ball (?).
A Newtonian finite ball can be in a stable equilibrium, if it is in hydrostatic equilibrium--pressure balancing gravity at every point.
Not necessarily, see above. If the ball is not in hydrostatic equilibrium, it will not be in stable equilibrium. But if it is, it will.
As far as I know there is no limit in Newtonian physics to the size of an object that can be in hydrostatic equilibrium; the size must be finite, but it can be any finite size.
Our universe can't be, because our universe is not a ball of matter of finite size surrounded by empty space. But I don't think the OP of this thread is asking about our universe; it's just asking about what is possible in Newtonian physics.
Likes Weran
I am the OP. Well both is okay for me. But I understand your point. Thanks
Neither the Newtonian spherical ball nor the Einstein static universe apply to our actual universe, so the topic of this thread has nothing to do with modeling our actual universe. If you want to ask what model describes our actual universe, you should start a separate thread for that.
Oh umm yes I understand. Okay The main problem was this.
I claimed that by just using mathematics, we can prove that matter-filled static universe is at unstable equilibrium (Basically Einstein's Static universe model). Then I tried to prove this by using fluid equations etc (which is a simple thing to do). Then another person claimed that this is not an exact prove since a matter filled static universe is also possible for a finite size Newtonian ball (which is stable at all times for under certain conditions).
So here the main question is can someone mathematically prove that a matter-filled static universe is always unstable ?
There are lots of things to account I guess. So its not a clear-cut thing to answer.
It just depends on what you mean by universe and by Newtonian physics. It is absolutely true that Newtonian physics allows an arbitrarily large, stable, ball of fluid. An infinite homogeneous state leads to self contradiction. My comment was more in line with "what would physicists in the second half of the 19th century - after Maxwell and Boltzman, before any notion of relativity - conclude about a model of the universe". They would see that a stable finite universe had great difficulties for thermodynamic reasons. Even more, the universe isn't fluid, and a large finite collection of gravitating bodies (i.e. galaxies) is generally unstable under pure Newtonian gravity, but this has to do with chaotic features of Newtonian gravity that Poincare first identified, not with a fluid model. Galaxies should occasionally eject from the 'ball', and this only adds to radiative instability. Thus they would have been very troubled by the state of affairs.
Likes Weran
First you have to make up your mind which mathematical theory you want to use. If you use General Relativity, yes, you can prove this. If you use Newtonian physics, you can't.
Likes Weran and PeroK
I see, could you share the approaches in simple terms or reccomend an article ?
What "approaches" do you mean? I've already listed the two theories you can pick from.
Sorry thanks for the help
Related to Newtonian stable universe model
1. What is the Newtonian stable universe model?
The Newtonian stable universe model is a cosmological theory proposed by Sir Isaac Newton in the 17th century. It suggests that the universe is infinite, static, and unchanging, with a fixed center and an unchanging distribution of matter and energy.
2. How does the Newtonian stable universe model differ from other cosmological models?
The Newtonian stable universe model differs from other cosmological models, such as the Big Bang theory, in that it does not include the concept of an expanding universe or a beginning to the universe. It also does not account for the observed redshift of distant galaxies.
3. Is the Newtonian stable universe model still considered a valid theory?
No, the Newtonian stable universe model has been largely replaced by the Big Bang theory, which has more evidence and observational support. However, some aspects of the Newtonian model, such as the law of gravity, are still used in modern cosmology.
4. What evidence supports the Newtonian stable universe model?
The main evidence for the Newtonian stable universe model comes from observations of the motion of planets and other celestial bodies, which follow the laws of gravity proposed by Newton. However, these observations do not provide enough evidence to support the model as a whole.
5. Are there any criticisms of the Newtonian stable universe model?
Yes, there are several criticisms of the Newtonian stable universe model. One major criticism is that it cannot explain the observed expansion of the universe or the cosmic microwave background radiation. It also does not account for the large-scale structure of the universe or the distribution of dark matter and dark energy.
  • Cosmology
