Stress point calculation some practical help
In summary, stress point calculation is a method used to determine the amount of stress a material can withstand before breaking or deforming. It is performed through mathematical equations, computer simulations, and physical testing and is important for understanding material limitations and ensuring safety in various applications. Common materials that undergo stress point calculation include metals, plastics, ceramics, and composites, and it is used in industries such as construction, aerospace, and automotive. However, there are limitations to stress point calculation, as it is based on assumptions and may not always accurately predict real-world conditions. Therefore, a combination of calculations and testing is necessary for a comprehensive understanding of stress points in a material.
pipeguy
TL;DR Summary
What are the possible materials (beams, H-profiles) etc that can be used to withstand the pressure of the whole system if there are 12 tonnes of wheat in the pipe at all times? How you would make this system work?
https://www.physicsforums.com/attachments/273785
There always has to be an angle so the grain flows
The link doesn't work.
Related to Stress point calculation some practical help
1. What is the purpose of stress point calculation?
The purpose of stress point calculation is to determine the maximum amount of stress that a material or structure can withstand before it fails. This information is crucial in designing and constructing safe and reliable structures.
2. How is stress point calculated?
Stress point is calculated by dividing the applied force or load by the cross-sectional area of the material. This results in a unit of force per unit of area, such as pounds per square inch (psi) or newtons per square meter (N/m^2).
3. What factors affect stress point calculation?
The factors that affect stress point calculation include the type and properties of the material, the shape and size of the structure, and the type and magnitude of the applied load. Other factors such as temperature, corrosion, and fatigue can also impact stress point.
4. What are some practical applications of stress point calculation?
Stress point calculation is used in a variety of industries and fields such as civil engineering, mechanical engineering, and material science. It is used to design and analyze structures such as buildings, bridges, and machinery, as well as to test the strength and durability of materials.
5. How can stress point calculation be helpful in everyday life?
Stress point calculation can help individuals make informed decisions about the safety and reliability of products and structures they use in their everyday lives. For example, knowing the stress point of a bridge can help determine if it is safe to drive over, or understanding the stress point of a household appliance can help prevent accidents and injuries.
  • Classical Physics
  • General Engineering
  • Mechanical Engineering
