Variable MOI: Rotational 2nd Law
In summary, the conversation discusses the difficulty in finding sources that discuss equations of motion with a changing moment of inertia, particularly in the case of a rocket that is assumed to be a rigid body. The conversation also addresses the use of the transport theorem to relate time derivatives in different frames, and the complexity of rotational dynamics in a dynamic mass system like a rocket.
jstluise
58
I'm having trouble finding any sources that discuss equations of motion that take into account a changing moment of inertia.
Just looking at the scaler case, angular momentum is [itex]L = I\omega[/itex]
Then, according to the 2nd law, [itex]\tau = \frac{d}{dt}(L) = \dot{I}\omega + I\alpha[/itex]
Is this correct? I understand the problem with doing this in the linear case (i.e. it does not respect Galilean invariance), but does the rotational case hold? I'm not sure it does...I mean, in the absence of torque ([itex]\tau = 0[/itex]), the equation says that [itex]\alpha \neq 0[/itex] if [itex]\dot{I} \neq 0[/itex] which doesn't quite make sense. Does the [itex]\dot{I}\omega[/itex] term just get lumped into [itex]\tau[/itex]? (like the linear case)
High school and freshman physics texts are very careful to avoid cases where the inertia tensor as expressed from the perspective of an inertial frame is not constant. They are also very careful to avoid cases where the inertia tensor needs to be treated as a tensor.
The inertia tensor for a rigid body is constant in a frame that rotates with the body. The angular momentum is still Iω. However, to be consistent with the fact that the inertia tensor is expressed in some body-fixed coordinate system, the angular velocity must be expressed in that same coordinate system. That means we're working in a rotating coordinate system. We're in a regime where Newton's laws don't exactly apply.
The transport theorem let's us relate the time derivatives in one frame to those in some other frame. For any vector quantity ##\vec q##, the time derivative of this quantity as observed in frame A and frame B are related by
[tex]\left(\frac {d\vec q}{dt}\right)_A =
\left(\frac {d\vec q}{dt}\right)_B + \vec \omega_{A\to B} \times \vec q[/tex]
The time derivative of angular momentum as expressed in the inertial frame is just the external torque. Applying the transport theorem to ##L=I\vec{\omega}## yields
[tex]\vec{\tau}_{\text{ext}} = \left(\frac {d\vec L}{dt}\right)_{I} =
\left(\frac {d\vec L}{dt}\right)_B + \vec \omega \times \vec L
= I\dot{\vec{\omega}} + \vec \omega \times (I\vec{\omega})[/tex]
Note that the transport theorem also tells us that the angular acceleration is the same in the inertial and body-fixed frames because ##\vec{\omega}\times \vec{\omega}## is identically zero.
What if the inertia tensor is not constant in the body fixed frame? That means the object in question is not a rigid body. The mass might be changing, or the body might be a flexible body. Needless to say, things get a lot hairier when either of these is the case.
Thanks for the reply.
I guess this is the case I am after. Particularly a model of a rocket that is assumed to be a rigid body. That makes sense when you say the MOI (and mass) of a rigid body is constant, and if it isn't, then it's not technically a rigid body. So what assumptions can be made so we can model the changing MOI while still considering it a rigid body?
A model I have run across is one that Matlab uses for a 3 degree-of-freedom variable mass/MOI object: http://www.mathworks.com/help/aeroblks/simplevariablemass3dofbodyaxes.html
For the rotation, they use the same equation that I listed in my first post.
Rockets are tricky because the mass isn't constant and neither is the MOI. And for really large rockets, I don't think you can consider them to be rigid, either.
Even translational behavior becomes rather difficult with a variable mass system. The center of mass moves within in a rocket. You won't see any physics text addressing this problem. Some graduate level aerospace engineering texts do.
The nice thing about translational behavior is that how mass flows within the body doesn't matter. All that matters is that it does flow, somehow, and the center of mass changes. That's not true with rotational motion. Suppose a fuel tank is connected to a rocket engine via a fuel line that wraps around the rocket a number of times. The flow from the tank to the rocket has a curl. Iω is not a complete description of the angular momentum.
The page you referenced does not fully reflect the rotational dynamics of a dynamic mass system, even with a curl-free flow. Iω still is not a complete description of the angular momentum even in the case of curl-free flow. The center of mass is moving within the vehicle, and one needs to account for that. The details of the motion are very complex when dealing with a rocket that ejects more than 90% of its mass in less than ten minutes (i.e., a typical rocket launch to low Earth orbit).
The model I made is a very simplified 3DoF model, so it's not going to include any complicated dynamics like structural bending, slosh, etc. About the only thing complicated about it is the changing mass/MOI...I'm not even considering the change in Cg right now. It's basically the same one that I referenced from Matlab, except with an additional moving frame to represent an Earth-centered, Earth-fixed frame.
Related to Variable MOI: Rotational 2nd Law
1. What is Variable MOI: Rotational 2nd Law?
Variable MOI: Rotational 2nd Law is a scientific principle that states that the angular acceleration of a rotating object is directly proportional to the torque applied to it and inversely proportional to its moment of inertia.
2. How is Variable MOI: Rotational 2nd Law different from Newton's 2nd Law?
While Newton's 2nd Law deals with linear motion and states that the acceleration of an object is directly proportional to the net force applied to it and inversely proportional to its mass, Variable MOI: Rotational 2nd Law deals with rotational motion and relates the angular acceleration to the torque and moment of inertia of a rotating object.
3. What is moment of inertia and how does it affect rotational motion?
Moment of inertia is a measure of an object's resistance to changes in its rotational motion. It depends on the mass and distribution of mass within the object, with objects with higher moments of inertia being harder to rotate.
4. How can Variable MOI: Rotational 2nd Law be applied in real-life situations?
Variable MOI: Rotational 2nd Law is applicable in many real-life situations, such as in the functioning of cars, bicycles, and other rotating machinery. It also plays a role in sports, such as in the spin of a ball in sports like baseball or tennis.
5. Can Variable MOI: Rotational 2nd Law be used to calculate the motion of non-uniform objects?
Yes, Variable MOI: Rotational 2nd Law can be used to calculate the motion of non-uniform objects by dividing the object into smaller parts with known moments of inertia and applying the law to each part separately. This can then be combined to determine the overall motion of the object.
