What is the difference between Otto engine and Carnot engine
In summary, an Otto engine is a type of internal combustion engine that uses controlled explosions to generate power, while a Carnot engine operates on a theoretical cycle to convert heat energy into work. The main difference between the two lies in their operating principles and efficiency. Otto engines typically use gasoline as fuel, while Carnot engines can run on any type of fuel as long as it can be heated and cooled to specific temperatures. In modern vehicles, Otto engines are more commonly used due to their lower cost and higher power output.
ChloeYip
93
What is the key difference between Otto engine and Carnot engine?
Other than it is reversible or not, it seems to me they are so similar.
Thanks.
Science news on Phys.org
Have you looked at a PV diagram for both? What is the maximum efficiency of both cycles?
efficiency is max for carnot engine...
the pv diagram looks a little bit different shape.
however, why?
thanks
Related to What is the difference between Otto engine and Carnot engine
Question 1: What is an Otto engine?
An Otto engine, also known as a spark-ignition engine, is a type of internal combustion engine that uses a spark plug to ignite the fuel-air mixture in the combustion chamber. This results in a controlled explosion that creates pressure, which pushes the piston and generates power.
Question 2: What is a Carnot engine?
A Carnot engine is a theoretical engine that operates on the Carnot cycle, which is the most efficient cycle for converting heat energy into mechanical work. It consists of two isothermal (constant temperature) and two adiabatic (no heat transfer) processes.
Question 3: What is the main difference between an Otto engine and a Carnot engine?
The main difference between an Otto engine and a Carnot engine lies in their operating principles. While an Otto engine relies on controlled explosions to generate power, a Carnot engine uses a theoretical cycle to convert heat energy into work. Additionally, a Carnot engine is considered the most efficient engine, while Otto engines have lower efficiency.
Question 4: What type of fuel is typically used in an Otto engine and a Carnot engine?
An Otto engine typically uses gasoline or petrol as fuel, while a Carnot engine can run on any type of fuel, as long as it can be heated and cooled to specific temperatures to operate on the Carnot cycle.
Question 5: Which engine is more commonly used in modern vehicles?
In modern vehicles, Otto engines are more commonly used due to their lower cost and higher power output compared to Carnot engines. However, with the growing emphasis on energy efficiency, there has been a shift towards developing more efficient engines, including Carnot engines.
12K
  • Thermodynamics
