- #106
JesseM
- 16
But during the period twin2 is accelerating, twin1 is moving inertially, so isn't that section of twin1's worldline already included in t', which is supposed to be the proper time of twin1's inertial phase? Or are you defining t' to be only the proper time along the section of twin1's worldline where twin1 is moving inertially and twin2 is not simultaneously (according to the definition of simultaneity in twin1's inertial rest frame) accelerating?cfrogue said:The equation c/a sinh(aBT/c) would be the elapsed proper time experienced by twin1 for the acceleration of twin2.
I'm not talking about the start and end points of the acceleration period. I'm talking about the start and endpoints of the worldline of each twin that you want to use to compare their elapsed proper time. Presumably the starting point is the point on each one's worldline when they first depart from one another at the same age (because twin1 begins to accelerate while twin2 continues to move inertially for a while)--note that this point on twin2's worldline lies well before the point where twin2 begins to accelerate himself. Then the endpoints have to be simultaneous in their final rest frame if you want to compare their ages in that frame, so even if you pick the point on twin2's worldline immediately after he stops accelerating, twin1 stopped accelerating much earlier so you'll have to pick a point on his worldline that lies well after he stopped accelerating (the part of his worldline between the end of his acceleration and the 'endpoint' is his inertial phase).cfrogue said:But, your point is valid.
Since acceleration is absolute motion under SR, then the start and end points of the acceleration period are different in each frame's proper time but can be decided.
According to the definition of simultaneity in twin2's rest frame during that phase, yes. But If twin2's entire aging during the inertial phase after twin1 departed is already included in t', then you don't need to add c/a sinh(aBT/c) separately.cfrogue said:For example, when twin1 accelerates for BT in its proper time, we know absolutely that twin2 elapsed c/a sinh(aBT/c).
Don't understand anything you said above. It would help if you'd address my question of why you think if twin1's inertial phase (or just the part of twin1's inertial phase when twin2 is not accelerating?) lasts for t', then twin2's inertial phase (or just the part of twin2's inertial phase when twin1 is not accelerating) lasts for t'/gamma. What is your reasoning?cfrogue said:Normally, under SR, one must have time intervals absolute only with an inertial frame, but acceleration is also absolute.
Thus, we are actually comparing simultaneity but with different clock beats given acceleration.
This is the trick I am using.
