- #36
- 46,823
- 23,304
JDoolin said:I've shown that the "obvious" answer (at 1.3 billion light years distance) is that the second observer ages 13.65 billion years, while the Earth ages 13.7 billion years. 13.65 billion and 13.7 billion are very close. This means that any observer within 1.3 billion light years should have approximately the *same* amount of proper time since the Big Bang event.
According to the "naive" calculation in the ECC frame, yes. But the difference will get larger as you go out to larger distances in the ECC frame. In the "cosmological" frame, the frame in which the FRW metric is written, *all* observers at the same cosmological time t have experienced *exactly* the same proper time since the Big Bang. See next comment.
JDoolin said:So now I need some clarification on what you've said above. "the second observer's proper time since the Big Bang at event E will be the *same* as the Earth's proper time since the Big Bang at event O" When you say this, are you already taking into account the speed of light delay? For instance, the image of a galaxy 1.3 billion light years away should not look 13.7 billion years old, but should look 12.4 billion years old, because the light originated from an event 1.3 billion years ago.
Remember that I said event E and event O are, by definition (or perhaps by construction) *simultaneous* in the ECC frame. That means event E is the event on the second observer's worldline that would be assigned the same time coordinate in the ECC frame as event O; in other words, event E is the event at which the Earth observer's "surface of simultaneity" at event O intersects the second observer's worldline. So the "speed of light delay" is already taken into account (at least, I think that's how you're using the term).
However, the way the ECC frame is constructed, its "surface of simultaneity" at event O exactly matches the (Euclidean) surface of constant cosmological time t = 13.7 billion years in the FRW frame, the (curved) spacetime metric in which cosmology is normally done. So according to the FRW frame, the second observer's proper time since the big bang at event E will be *exactly* 13.7 billion years, *not* 13.65 billion years.
