- #36
bhobba
Mentor
- 10,825
- 3,690
bolbteppa said:Apparently that paper derives the TISE from the TDSE, in other words the TDSE is derived from an equation (the TISE) which itself was derived from classical mechanical principles.
Sorry - must have missed the derivation of the TISE from classical mechanics principles.
The key thing is what you mean by classical mechanics principles
The POR is a classical mechanics principle and it can be used to derive QM and CM. But other things come into it as well - namely exactly what is the POR applied to - in CM its the PLA, in QM its the two axioms (or other equivalent ones) I gave. Those axioms are fundamentally different because CM and QM are fundamentally different. The PLA is a limiting case of the axioms of QM - the reverse is not true - nor can it be - there is no way one can derive QM from CM. The geometrical approach looks for formal connections at a deep level to elucidate exactly how you can figure out to quantize a classical system. But they are nothing but formal connections - QM is not derivable from CM.
No mate - I don't really have any zeal for finding the errors in claims like this. It's obviously not possible - its like the proofs of one equal zero - you know there is a division by zero somewhere - its the same here - they are making some assumptions about QM and apply CM principles to it - but those assumptions are different to CM - as they must be because QM is different to CM right at its foundations.
You know this because the axioms of QM and the PLA are different - one implies the other - but not conversely.
Thanks
Bill
