- #71
bolbteppa
- 309
- 41
Good idea:
My original questions were:
a) Why does one need to make an algebra out of mixing the Hamiltonian with Poisson brackets?
b) Why can't quantum mechanics just be modeled by extremizing a Lagrangian, or solving a H-J PDE?
c) How do complex numbers relate to this process?
These questions were motivated by the fact that Schrodinger's original derivation of the time-independent Schrodinger equation apparently assumes nothing more than classical mechanics. I was sloppy & missed the time-independence - after being shown this I thought the thread had ended, then in trying to find out about a time-dependent derivation I came across http://www.mpipks-dresden.mpg.de/~rost/jmr-reprints/brro01.pdf in which they purport to derive the TDSE from the TISE (among other things, well worth reading), however the derivation is pretty complicated & I don't understand it. But as it stands, the claim is that the TISE is derivable from classical mechanics, & that the TDSE is derivable from an equation derivable from classical mechanics. Therefore unless there is some step in this derivation that absolutely require quantum mechanical assumptions, it seems the TDSE may be derivable from classical mechanics also. Thus people are examining the strength of the claim that the TISE is derivable from classical mechanics, before examining the TDSE derivation in that article.
So how does this affect my questions?
a) If you can derive the TDSE from the TISE without axioms or quantum mechanical assumptions then it may be that all this algebra/vector space stuff is implicitly smuggling classical mechanics into it's very fabric. At present it seems that all the craziness results from the fact that eigenfunctions of the SE are, in general, complex-valued, that seems to be the only new thing going on thus far. An example of this is page 3 of the Max Planck article where Schrodinger's original derivation is given in terms of operators in a Hilbert space, it's nothing more than Schrodinger's derivation in disguise which means it may just be a classical mechanics derivation in the guise of algebra & arbitrary axioms & all this baggage was potentially added to the theory simply due to Schrodinger's inability to deal with the TDSE in the early years in the way the authors of the Max Planck article have done, that's what I'm trying to find out. It may be this machinery is not necessary, it's merely useful tricks the way the Hamilton-Jacobi equation could be seen as a trick for dealing with Lagrangians & Hamiltonians.
b) has an easy solution, it can be modeled by extremizing a Lagrangian, c.f. Landau QM Section 20. However as it stands we're only comfortable with the TISE, thus factoring in the notion that solutions are complex it makes sense to construct a Lagrangian in terms of complex functions as Landau does. The TDSE in the action is something we'd need to come back to later.
c) & it's Complex numbers are currently only justified in this by the fact that eigenfunction solutions of the TISE can in general be complex, however around page 16 of that article the authors make an interesting argument about the necessity of complex numbers in the TDSE as arising due to interactions of a system described by a TISE with a classical external environment, & that they not necessary when you ignore such an interaction, though to fully understand this I think one would need to follow the derivation completely.
Thus the question as it stands is to examine Schrodinger's original derivation, & to examine the derivation in that Max Planck article of the TDSE from the TISE & locate where (if any) new assumptions are forced on us & whether they are simply unavoidable, these two issues seem to be the crux on which everything rests.
