Understanding bell's theorem: why hidden variables imply a linear relationship?
In summary: Bell's theorem does not hold. In summary, the proof/logic of Bell's theorem goes thus: with the measurements oriented at intermediate angles between these basic cases, the existence of local hidden variables would imply a linear variation in the correlation. However, according to quantum mechanical theory, the correlation varies as the cosine of the angle. Experimental results match the [cosine] curve predicted by quantum mechanics.
  • #246
billschnieder said:
Your argument is that no-conspirary allows you to conclude that the inequality P(C|w) <= P(A|w) + P(B|w) which is valid for scenario (c) must be valid for scenario (b), ie P(C|z) <= P(A|x) + P(B|y) because according to you the no-conspiracy implies that P(C|z) = P(C|w) and P(A|x)=P(A|w) and P(B|w)= P(B|y). This is your argument.
Yes, it is.
My argument is is the following:
The inequality P(C|w) <= P(A|w) + P(B|w) is obtained from P(C|w) = P(A|w) + P(B|w) - 2P(AB|w). So if you are claiming that the inequality should apply to scenario (b) it means the equality should also apply. You can not take the inequality and reject the equality, the inequality is just a different view into the what is already there in the equality.
It is true that the equation in (c) implies the inequality in (c). But the inequality is its own statement, even if it's implied by another statement. Let me write things more explicitly so we can key in on our disagreement:
1. (P(A|w)+P(B|w)-P(C|w))/2=P(A & B|w)
2. P(A & B|w)≥0
3. (P(A|w)+P(B|w)-P(C|w))/2≥0
4. (P(A|x)+P(B|y)-P(C|z))/2≥0
Now I'm open in my "hiding" of a term. What I'm saying is that 1 and 2 imply 3, and even though 1 and 2 have no analogue for (b), it is nevertheless true that 3 implies 4.
However, you conveniently hide the 4th term by removing it and changing the equality sign to an inequality. By doing that, you are assuming that the meaningless undefined probability which does not exist has a value. Yet you do not see the problem.
No, I'm not assuming that P(A & B) is defined in any of the three probability spaces in (b). The equation implies the inequality, but the inequality need not imply the equation.
This is why I asked you earlier to derive the inequality directly from scenario (b) using any assumptions you like without going through (c). But you didn't and can't.
But there's a fundamental reason for that: counterfactual definiteness is a crucial assumption for Bell's theorem. If you were the kind of person who rejected counterfactual reasoning, in other words rejected reasoning in (c) as invalid, then this argument can't persuade you. If you restrict yourself to reasoning in (b), i.e. if you don't believe in counterfactual definiteness, then you can only carry out the argument for EPR, not Bell.
Look, I see no contradiction in saying the following:
1. The equation is meaningless in (b).
2. The equation is meaningful and correct in (c).
3. The equation in (c) implies the inequality in (c).
4. The inequality in (c) implies the inequality in (b)
5. The inequality is meaningful and correct in (b).
Then I can't help you.
What is the logical contradiction you see?
This much is obvious from you inability to derive the inequality directly under scenario (b) without invoking scenario (c) at all.
I explained my inability to do so.
This is precisely the fallacy you continue to make. You can not put P(A|x) and P(B|y) and P(C|z) together in a single expression and calculate anything empirically meaningful. There is no alternate logic, or alternate probability theory which allows you do do that. Yet you insist on doing just that.
OK, I still don't understand your point, since I'm just doing valid operations with numbers, but what if I side-stepped the issue and reasoned as follows:
1. P(C|w)≤P(A|w)+P(B|w)
2. P(A|x)=.25, P(B|y)=.25, P(C|z)=.75
3. P(A|x)=P(A|w), P(B|y)=P(B|w), P(C|z)=P(C|w)
4. P(A|w)=.25, P(B|w)=.25, P(C|w)=.75
5. .75 ≤ .25 + .25
What step do you think I'm going wrong in?
  • #247
5. .75 ≤ .25 + .25
1. P(C|w)=P(A|w)+P(B|w) - 2P(AB|w)
2. P(A|x)=.25, P(B|y)=.25, P(C|z)=.75, P(AB|x?y?)=?
3. P(A|x)=P(A|w), P(B|y)=P(B|w), P(C|z)=P(C|w), P(AB|x?y?)=?
4. P(A|w)=.25, P(B|w)=.25, P(C|w)=.75, P(AB|w)=??
5. .75 = .25 + .25 + ?
Steps (1), (2), (3), (4) and (5). You are hiding the dirt under the inequality "rug". Enough said. If you still do not understand my argument that's your problem.
  • #248
A short note that:
Bell's theorem, though fairly convincing, is not, as many of you are aware, the only "proof" of non-local action
Other experiments, for example those listed below, also provide evidence of quantum entanglement
- Two-photon interference - where interference is demonstrated (at a distance) without the entangled photons meeting at the beam-splitter which is not replicable via two (un-entangled) photons
- Quantum entangled swapping - where photons are entangled (via their "twins") without ever meeting
- improvements in Bell's test detection efficiency
  • #249
OK, let me be more explicit in my logic and not use inequalities at all.
1. P(C|w)=P(A|w)+P(B|w)-2P(A & B)|w)
3. P(A|x)=P(A|w), P(B|y)=P(B|w), P(C|z)=P(C|w) (From no-conspiracy.)
4. P(A|w)=.25, P(B|w)=.25, P(C|w)=.75 (From 2 and 3)
5. .75 = .25 + .25 -2P(A & B|w) (From 1 and 4)
6. P(A & B|w) = -.125 (From 5)
Now what step is in error? I am no longer "hiding" ill-defined probabilities like P(A & B|x) behind inequality signs.
  • #250
1. P(C|w)=P(A|w)+P(B|w)-2P(A & B|w)
Your argument is the same and the criticism is the same. P(AB|w) disappears in Step (2) and reappears in step (5). What happened to it in steps (2), (3) and (4)? In step (5) you have effectively the frankenstein equation P(C|z) = P(A|x) + P(B|y) - 2P(AB|w) from which you conclude in step (6) that 2P(AB|w) is negative! Why do you leave out the P(AB|..) terms from (2), (3) and (4)? Because you know that by including them, it reveals your error. Your equation (1) contains the term 2P(AB|w). How come your no-conspiracy condition can make a statement about P(C|w), P(A|w), and P(B|w) but conveniently ignores P(AB|w)? Isn't it curious that your "no-conspiracy" condition "just happens" to be silent about P(AB|w), the same probability on which your conclusion (6) hinges? That is the conspiracy of your "no-conspiracy".
How many different ways do I have to explain this? :cry:
  • #251
billschnieder and I continued this discussion in another thread, but on his suggestion I'm bringing it back here.
billschnieder said:
Your no-conspiracy condition is essentially that Scenario X and Scenario Y (from above) are exactly the same,
Yes, the no-conspiracy condition says that if a statement is meaningful in both scenarios, then the probability is equal for both scenarios.
in other words, your no-conspiracy condition is equivalent to saying, the QM result from a single wavefunction must be the same as the QM result from three different wavefunctions.
Where in the world did you get that from? We're talking about different possible measurements we could perform on a system with the same wavefunction. We're not talking about different wavefunctions.
And I showed you that step (3) was incomplete, Step (3) What does no-conspiracy say about P(AB|w). According to your logic, no-conspiracy also implies that P(AB|w)=P(AB|x,y).
No-conspiracy states that if a statement S is meaningful in both x and w, then P(S|w)=P(S|x) (and similarly for y and z). But A & B is not meaningful in x, so no-conspiracy doesn't tell you anything in this case.
Also, what do you mean by P(A & B|x,y)? Do you mean a combined space which is the union of x and y? Well, my reasoning doesn't talk about combined spaces like that. It only discusses x, y, z, and w.
But x and y are two different sets of photons, which means P(AB|x,y) is undefined/meaningless.
Again, I didn't say anything about P(A & B|x,y).
All you have proven is the triviality that the joint probablity distribution P(ABC|x,y,z) for outcomes from three different sets of photons (x,y,z) is undefined, although the joint probability distribution P(ABC|w) from the single set of photons (w) is well defined.
I didn't say anything about P(A & B & C|x,y,z). And again, since A & B & C is meaningless in x, y, or z, the no-conspiracy condition says nothing in this case either.
  • #252
But then, such a condition is seriously flawed.
Please review post #240 above:
billschnieder said:
Le us represent the sets of photons as one set "w" for scenario (c), and three different sets ("x", "y","z") for scenario (b). Then the probabilities for (c) are more accurately represented as P(A|w), P(B|w), P(C|w) ... the probabilities for scenario (b) are more accurately represented as P(A|x), P(B|y), P(C|z).
So clearly in the first scenario, we are talking about different measurements that could be done on the same real system, but since we can only measure the system once, the other two terms are counter-factual AND clearly, in the second scenario we are talking about three different measurements on three different systems "x", "y", "z" (hence 3 wavefunctions) and there is nothing counterfactual in it.
Your argument, at least as I understand it, is that:
- the probabilities from the first scenario should be the same as the probabilities from the second scenario, because according to what you call the "no-conspiracy" condition, if we can talk meaningfully of P(A|w), P(B|w), P(C|w) in the first scenario, and we can talk meaningfully of P(A|x), P(B|y), P(C|z) in the second scenario, then those probabilities must be equal, ie P(A|x) = P(A|w) and P(B|y) = P(B|w) and P(C|z) = P(C|w), and if P(C|w) <= P(A|w) + P(B|w), then it must also be true that under "no-conspiracy", P(C|z) <= P(A|x) + P(B|y). From which you argue that since P(A|x) = P(B|y) = 0.25 and P(C|z) = 0.75, the inequalty P(C|z) <= P(A|x) + P(B|y) will be violated. .75≤.25+.25.
Now, is the above not exactly your argument. Please, let me know if I've misunderstood your argument in any way. Once we are clear on what your argument is, I will proceed to show why such a "no-conspiracy" condition is seriously flawed.
  • #253
Well, before measurement the system is described by the same wavefunction in each of the three cases x, y, and z.
Yes, that is exactly my argument.
EDIT: In fact, your statement of my argument is unnecessarily cumbersome. We just need to say that P(C|w) <= P(A|w) + P(B|w), and by no-conspiracy P(A|x) = P(A|w), P(B|y) = P(B|w), P(C|z) = P(C|w), and according to QM we have P(A|x)=P(B|y)=.25 and P(C|z)=.75, so we have P(A|w)=P(B|w)=.25 and P(C|w)=.75, so we have .75 <= .25 + .25.
So we don't even need the intermediate step P(C|z) <= P(A|x) + P(B|y).
  • #254
I guess this is a key point of disagreement. There are three different systems of photons "x", "y" and "z". They can not be described by the same wavefunction. It is only in "w" that we have a single system.
Let me explain then what your problem is:
1) Theoretically: An inequality such as P(C|w) <= P(A|w) + P(B|w), is not an independent mathematical truth, but just a simplification of the equality P(C|w)= P(A|w)+P(B|w)-2P(AB|w) from which it is derived. Then, you claim that because of "no-conspiracy", P(A|x) = P(A|w) and P(B|y) = P(B|w) and P(C|z) = P(C|w). Now, if that is the case, then it must also be the case that P(C|z) = P(A|x) + P(B|y) - ?. What in your opinion is the missing term, there must be one, otherwise your no-conspiracy condition is inconsistent. I would guess that it should be 2P(AB|xy) = 2P(AB|w) because of "no-conspiracy". If that is the case, let us remind ourselves at this point what A,B all mean:
lugita15 said:
Where A denotes statement "The result at -30° differs from the result at 0°", B denotes the statement "The result at 0° differs from the result at 30°", and C denotes the statement "The result at -30° differs from the result at 30°".
P(AB|w) is therefore the probability that the set of photon pairs "w" were destined to mismatch at both (-30°, 0°) AND (30°, 0°). Note here, that it is the same set that must satisfy both conditions.
P(AB|xy) is the probability that the set of photon pairs "x" was destined to mismatch at (-30°, 0°) and a completely different set of pairs "y" was also destined to mismatch at (30°, 0°). Note here that each set has just a single condition to fulfill.
  • #255
Then, your no conspiracy condition boils down to the suggestion that a requirement for a single system to fulfill two conditions simultaneously, is the same as a requirement for two different systems to each fulfill only one of the two conditions. In simpler terms. The suggestion is akin to the suggestion that the probability of finding a tall girl in a class, is the same as the probability of finding a tall person in one class and a girl of any height in a different class.
2) Practically: When talking of measurements, since P(C|w), P(A|w), and P(B|w) are all derived from a single set of photon pairs, on which we can only ever measure one, two of the three must be counter-factual and unmeasurable. Since P(C|z), P(A|x), and P(B|y) are each derived from a different set of photon pairs, they are each directly measurable without any counter-factuals. Your no-conspiracy condition then becomes the suggestion that it is okay to substitute the results measured from three different systems into an inequality based on unmeasurable counterfactuals describing a single system.
Here is what Bell says about this idea:
"It was not the objective measurable predictions of quantum mechanics which ruled out hidden variables. It was the arbitrary assumption of a particular (and impossible) relation between the results of incompatible measurements either of which might be made on a given occasion but only one of which can in fact be made."
P(C|z), P(A|x), and P(B|y) are each objectively measurable.
P(C|w) <= P(A|w) + P(B|w), is an impossible relation between results of incompatible measurements either of which might be made on a given occasion but only one of which can in fact be made.
So it is the mixing of "w", with "x,y,z" that results in the violation. In otherwords, it is the so-called "no-conspiracy assumption" itself that has to be abandoned.
  • #256
On the other hand, if you refuse to provide the last term, let us leave it as ? and follow the calculation through.
0.75 = 0.25 + 0.25 - ?
and
? = - 0.25
Where is the violation? Why do you have a problem with ? = -0.25.
  • #257
I think this is just a minor point. x is the set of photon pairs for which we're going to measure polarization at -30 and 0, y is the set of photon pairs for which we're going to measure 0 and 30, and z is the set of photon pairs for which we're going to measure -30 and 30. All I was saying is that according to quantum mechanics, the wave function of a photon pair in any of these three sets is exactly the same. Do you really disagree with that?
That's why I rewrote things in terms of equations in post #249.
Just refer to my post #249: .75 = .25 + .25 - 2P(A & B|w). Remember, the no-conspiracy condition only applies to statements S which are meaningful in both x and w (and similarly for y and z). It does not apply to A & B, which is not meaningful for x, y, or z.
No, I'm not claiming anything about P(A & B|x,y).
  • #258
I don't see how the no-conspiracy condition boils down to that at all, because I see P(A & B|x,y) as irrelevant.
Yes, that's a fair summary,
Yes, and I think that it is okay in this case.
That quote isn't about the assumptions of Bell's theorem, it's about Von Neumann's earlier hidden variable theorem that Bell critiqued as being too demanding in its assumptions. I don't think Bell thought of his own theorem the same way.
I don't know why you call it an impossible relation. It's a relationship between unmeasurable things, but the no-conspiracy condition allows us to say that certain unmeasurable quantities are equal to certain measurable quantities.
What is wrong with an equation that contains x, y, z, and w? What is wrong with putting any numbers you want in an equation? That's fundamental to mathematics. Even if two numbers were taken from vastly different sources, if they have the same value, then they can be freely substituted into any statement without changing the truth value. That's Leibniz's famous Identity of Indiscernibles: if F(a) is true, and a=b, then F(b) must always be true. Is that what you're disputing?
OK, if you want to abandon it, you can, but at least address the argument I gave earlier in the thread for why it should be true:
lugita15 said:
I am talking about the result I would get if I perform a particular experiment on a particle, regardless of whether I actually perform that experiment. Now how do I connect this to real experiments, which are obviously concerned with possibility b)? I make the crucial assumption, which I expect that you disagree with or think is misleading, that the following two probabilities are always equal:
1. The probability that this photon would go through a polarizer if it is oriented at angle x, given that the polarizer is actually oriented at angle x.
2. The probability that this photon would go through a polarizer if it is oriented at angle x, given that the polarizer is NOT actually oriented at angle x, but instead some different angle y.
Now why do I assume that these two probabilities are equal? Because I am assuming that the answers to the following two questions are always the same:
1. What result would you get if you send this photon through a polarizer oriented at angle x, given that the polarizer is actually oriented at angle x?
2. What result would you get if you send the photon through a polarizer oriented at angle x, given that the polarizer is NOT oriented at angle x, but instead some different angle y?
And why do I assume that these questions have the same answer? That seems to me to be a consequence the no-conspiracy condition: the properties (or answers to questions) that are predetermined cannot depend on the specific measurement decisions that are going to be made later, since by assumption those decisions are free and independent.
What do you disagree with here? Do you disagree that questions 1 and 2 always have the same answer?
  • #259
and
? = - 0.25
I have a problem with .75 = .25 + .25 - 2P(A & B|w) as shown in post #249.
  • #260
Of course, they can not be exactly the same, there are 3 different systems with different space-time coordinates. You probably mean that the QM predictions for the three different systems
"x", "y", "z" as concerns this particular experiment are the same, which I will agree with.
.75 = .25 + .25 - 2P(A & B|w). Remember, the no-conspiracy condition only applies to statements S which are meaningful in both x and w (and similarly for y and z). It does not apply to A & B, which is not meaningful for x, y, or z.No, I'm not claiming anything about P(A & B|x,y).
But that is a nonsensical equation .75 = .25 + .25 - 2P(A & B|w). By your own argument, if your no-conspiracy condition can not say anything about P(A & B|x,y) then it can not say anything about 2P(A & B|w) either. Or do you want to explain how A&B is meaningful in both x and w (and similarly for y and z). By writing .75 = .25 + .25 - 2P(A & B|w), you are backhandedly trying to use it to say something about 2P(A & B|w). You say you are not making any claim about P(A & B|x,y) but I'm telling you that you are, indirectly.
How come you do not want to say anything about the equality for the second scenario only. In other words, why did you need w, why didn't you just write down the inequality using ONLY x, y, and z? What I'm asking you is, is there a genuine expression of the form
involving ONLY x,y,z and no w? If not, why not, and if so what is it?
  • #261
Of course Bell did not intend to argue against his own theorem in a paper written before his theorem. But the point is that his argument is sound, and obviously applies just as well to his theorem whether he thought about it or not.
You've answered your own question. As far as measurements are concerned, it is an impossible relation.
Nothing. Until you start drawing physical inferences from the equation. As I explained previously, if the time to put on just shoes is Ta, and the time to put on just socks is Tb, then you can write any equation you like which includes Ta and Tb. But you can not conclude that the Ta + Tb = Time to put on shoes and then socks.
That's just not correct. Two numbers do not have the same value just because you claim they do. It is the physical situation producing the two values that determines whether they have the same value or not, not lugita. And I've already explained to you that the probability of finding a tall girl in a class is not the same as the probability of finding a tall person in one class and finding a girl of any height in another class.
That's Leibniz's famous Identity of Indiscernibles: if F(a) is true, and a=b, then F(b) must always be true. Is that what you're disputing?OK, if you want to abandon it, you can
What are you talking about? :confused:
Continuing in the next post ...
  • #262
lugita15 said:
I make the crucial assumption, ... that the following two probabilities are always equal:
To illustrate the error, I will rephrase it as follows:
*) The expected result R1, if the photon is measured at angle x
*) The expected result R3, if the photon were instead measured at angle x, given that we already measured it at angle y and obtained result R2.
Your crucial point is that R1 must be equal to R3 because of no-conspiracy. Of course that is false. I will give you a clear counterexample example using Bernouli's urn.
We have an urn with 2 balls, 1 white and 1 red, we pick two balls in sequence without replacement.
*) The probability of the first ball being Red, R1
*) The probability of the first ball being Red, R3, given that the second ball was revealed to be Red R2.
According to your no-conspiracy condition, R1 = R3 which is false. R1 = 1/2 and R3 = 0. As I hope you appreciate, the underlined statements (R2) place restrictions on what we are allowed to say about R3. By ignoring this part of your argument, it has obscured your ability to see the error.
Not only do we have results for the actually measured angle y, we are also using it jointly in the same expression as the results at angle x.
Obviously false or naive. In the Bernouli example above, the result of the first pick was dependent on the result of the second pick which was made later.
So I will appreciate answers to my own questions too:
  • #263
The wavefunction of a system can be written as a product of a positional part and a spin part. All I meant is that the spin state of each photon pair is the same.
Why is it nonsensical?
Whether the no-conspiracy condition says anything about P(A & B|x,y) is not really something that concerns me, because it's completely irrelevant to my argument. But yes, the no-conspiracy condition does not allow you to conclude that P(A & B|w) = P(A & B|x), for instance, because A & B is not meaningful in x. To repeat, the no-conspiracy condition states that if S is meaningful in both x and w, then P(S|w)=P(S[x).
No, it's definitely not meaningful in x, y, or z.
All I'm saying is that you can't directly apply the no-conspiracy condition to P(A & B|w).
How am I doing that?
Well, you can write the inequality in terms of only x, y, and z, but you can't write the equation in terms of only x, y, and z. How is that a problem?
In a deeper sense, if you're asking why we need w at all in this proof, that's because one of the assumptions of Bell's theorem is counterfactual definiteness.
No, there isn't. (I mean, of course there are equations of that form, but nothing relevant.) And the reason there isn't is that the no-conspiracy condition applies to P(A|w), P(B|w), and P(C|w), but it doesn't apply to P(A & B|w), because A & B is only meaningful in w.
  • #264
OK, fair enough, it's just that the way you've been using the quote makes it seem like Bell was acknowledging a shortcoming in his own theorem.
Well, if all you mean is that P(C|w) <= P(A|w) + P(B|w) is a relationship between quantities that are not directly measurable, then yes I agree with that.
I think this is where we fundamentally disagree. If the mass of a stick and the mass of a stone are equal, and the mass of the stick is great than the mass of an ant, then the mass of the stone is also greater than the mass of the ant. Numbers which are equal can be freely substituted for each other in any statement without changing the truth value of that statement, whether that statement is about the physical world or not. Do you really disagree with that? That's Leibniz's law.
But all your example shows is that the time to do a then b is not equal to the time to do a + the time to do b, or in symbols, T_(a then b) does not equal T_a + T_b. In other words, the "then" operation of actions does not correspond to the addition operation. But we're not dealing with that kind of issue at all here.
I didn't say that any two numbers are equal if I say so. All I said is IF they'e equal, then they can be freely substituted. So if you want to disagree with me, you have to disagree with P(A|w)=P(A|x). But if I'm right about that, then after that you can't disagree, can you, with me substituting P(A|x) into the equation P(C|w)= P(A|w)+P(B|w)-2P(AB|w), and drawing valid physical inferences from a correct equation?
I agree with that, but I don't see how I'm doing anything analogous to that.
I'm talking about Leibniz's Law, known as the Identity of Indiscernibles. It says that if F(a) is a true statement (like "a is an apple"), and a=b is a true statement, then F(b) ("b is an apple") must always be a true statement. Do you disagree with that?
  • #265
I am NOT asserting that the probability that a given photon would have yielded a certain result R1 at angle x, given that it was measured at y and yielded R2, is equal to the probability that it that will yield R1 if we measure it at x. Instead I'm saying that the probability that a given photon have yielded R1 at x, given that it was measured at y, but NOT given the result of the measurement, is equal to the probability that it will yield R1 if we measure it at x.
That was a long string of words, so let me write it in fraction form. This is what I am NOT saying, but what you seem to think I'm saying:
(number of photons yielded R2 at y but would have yielded R1 at x)/(number of photons which yielded R2 at y) = (number of photons which yielded R1 at x)/(number of photons measured at x).
This is what I AM saying:
(number of photons which were measured at y but would have yielded R1 at x)/(number of photons which were measured at y) = (number of photons which yielded R1 at x)/(number of photons measured at x).
If you disagree with this statement, you can, but please tell me your thoughts on the argument I presented for it:
"Now why do I assume that these two probabilities are equal? Because I am assuming that the answers to the following two questions are always the same:
And why do I assume that these questions have the same answer? That seems to me to be a consequence the no-conspiracy condition: the properties (or answers to questions) that are predetermined cannot depend on the specific measurement decisions that are going to be made later, since by assumption those decisions are free and independent."
Do you agree or disagree that these two questions have the same answer?
This is not at all what I'm doing.
  • #266
I can only assume then that you do not understand what you are saying. Do you at least agree now, that the two probabilities would not be the same if R2 were given? If you can agree to this, then you have understood the argument and all I have to do is to convince you that in your argument, R2 is indeed given.
What do you think I've been doing? You are just repeating the same post and ignoring my argument against it. Do you even understand the argument at all, let-alone agreeing with it?
Now why do I say R2 must be given. Because you have both results in the same expression from which you are trying to draw physical conclusions. You are arguing as if you only had a single probability written on one sheet of paper, and another probability written on another sheet of paper. Rather you have an expression P(A|x) + P(B|y) which includes BOTH the results at x and the results at y, so how can the results at y not be given?! You have "given" it, by having it in the expression. You can't have your cake and not have it.
It is indeed, as I've explained now, maybe 5 different ways. Each time you simply say it is not. Just because you phrase your argument in a way that obscures the argument does not mean I can not see through it and go right through to the core issue. That is what I have done, many times already.
  • #267
lugita15 said:
Numbers which are equal can be freely substituted for each other in any statement without changing the truth value of that statement ... Do you really disagree with that?
But the numbers are not equal, isn't that the argument? Otherwise why are you asking me to explain why I claim the numbers are not equal.
You completely missed the point which was to show you that the value of T_a, T_b in the expression T_a + T_b, will be different from the value of just T_a or T_b separately. The point being that the physical situation of in the expression "T_a + T_b" (putting on shoes and then Socks) determines which value T_a or T_b will have in the expression and you can not simply take values from considering T_a separately and plug them in expecting things to be meaningful. Of course you are free to do it, but do not be surprised when nonsensical paradoxes result.
And I'm arguing that the free standing T_b is not the same as the T_b when considering it jointly with T_a. I'm arguing that they are not equal.
No I don't. I disagree with you going from
to P(C|z)= P(A|x)+P(B|y)-2P(AB|w)
And apparently, you too disagree with it when if agree that there is no genuine expression of the form P(C|z) = P(A|x) + P(B|y) - ? involving only x, y, z.
I disagree with "P(A|w)=P(A|x) AND P(B|w)=P(B|y) AND P(C|w)=P(C|z) simultaneously"
Please, please it is very relevant. This is at the core of the disagreement, how can it not be relevant. Please provide the equation. Unless you just want to wiggle out of admitting that there is none. The question did not include any w, so why even bring no-conspiracy into it. Do you have a complete expression including just x, y, z for of the form P(C|z) = P(A|x) + P(B|y) - ? or not? If you do please provide it. If none exists, please explain why none exists. This is a crucial question.
  • #268
I agree that the percentage of photons yielding R2 for y, for which x would have yielded R1, is different from the percentage of photons measured at x, for which x yielded R1. But I also believe that the percentage of photons measured at y, for which x would have yielded R1, is the SAME as the percentage of photons measured at x, for which x yielded R1. Do you agree or disagree with this second statement?
I think I understand my argument, but I don't know what your counterargument is. At least so far as I can tell, you haven't told me whether my 2 questions always have the same answer. In post #262, you responded to that post by giving the example of Bernoulli's urn, which was about probabilities. But my two questions have absolutely nothing to do with probabilities.
First of all, we have some ambiguity as to what x and y mean. The x and y in my two questions are angle settings of a polarizer. The x and y in P(A|x) + P(B|y) are probability spaces, x being the set of photons for which you measure at -30 and 0, and y being the set of photons for which you measure at 0 and 30. To minimize confusion, in future why don't we use θ1 and θ2 to refer to angle settings, and continue to use x, y, z, and w to refer to probability spaces?
Instead of arguing about what's been "given" or not, why don't you simply tell me whether you agree or disagree that the following two fractions are equal?
1. (Number of photons pairs which yielded different results when measured at -30 and 0)/((Number of photon pairs which were measured at -30 and 0).
2. (Number of photon pairs which were measured at 0 and 30 but would have yielded different results at -30 and 0)/(Number of photon pairs which were measured at 0 and 30)
Your example of Bernoulli's urn dealt with different probabilities than the ones I'm dealing with. I wrote the probabilities that I'm dealing with in fraction form above.
  • #269
If you'r only claim is that P(A|w)=P(A|x) is wrong for some reason, that's one thing that we can discuss. But you also seem to claim that "it is the mixing of "w", with "x,y,z" that results in the violation". What is the reason why equations involving x, y, z, and w are not allowed, or physically meaningless, or whatever your contention is?
I have no idea what this sentence means. Can you explain it different words?
Again, I don't quite understand what you're saying here, and I don't know why you're associating T_a + T_b with putting on shoes then socks, rather than just the time to put on shoes plus the time to put on socks. Can you use a different example to illustrate your point, whatever it is?
T_b is just a fixed number, just like 5. Whether you put it on its own in a statement (with physical significance or not), or whether you put it in a statement (with physical significance or not) which also has T_a in it, doesn't it still retain its value?
I definitely don't disagree with going from P(C|w)= P(A|w)+P(B|w)-2P(AB|w) to P(C|z)= P(A|x)+P(B|y)-2P(AB|w). What do you see wrong with that step?
This is a rather strange statement. What does it mean for three statements to be true, versus three statement being true simultaneously? Are you operating in some non-classical logic or something?
There aren't any useful equations of that form which involve just x, y, and z. There's lots of useless and unimportant equations of that form, but they're of zero relevance to what we're talking about. (For instance P(C|z) = P(A|x) + P(B|y) - (1 - P(not A|x) - P(not B|y) + P(not C|z)) or something silly like that.) Anyway, the point is, why do we need to express the Bell inequality in terms of an equation that only involves x, y, and z? What is wrong with an equation that involves x, y, z, and w? And why can't we derive physical inferences from such an equation?
And also, why can't we just sidestep this whole issue, like I did in post #249, and just directly get to .75 = .25 + .25 - 2P(A & B|w) from P(C|w)= P(A|w)+P(B|w)-2P(AB|w), P(A|w)=P(A|x)=.25, P(B|w)=P(B|y)=.25, and P(C|w)=P(C|z)=.75?
  • #270
Because the expression is incorrect to start with. It is incorrect because you have assumed that terms are equal, which are not. The fact that a genuine expression exists for w, and none exists for xyz, confirms that. In other words, due to the physical situation "w", there is a single joint probability distribution p(ABC|w) from which you can extract P(A|w), P(B|w), and P(C|w) but there is no joint probability distribution p(ABC|xyz) in the physical situation "xyz" from which you can extract P(A|x),P(B|y), and P(C|z). Because of the physical situation, "w" the probabilities P(A|w), P(B|w), and P(C|w) are mutually dependent having originated from the same system, but the physical situation "xyz" mandates that the probabilities P(A|x), P(B|y), and P(C|z) are independent, having originated from three separate systems.
After substituting the probabilities from the physical situation "xyz" into an expression derived for the physical situation "w", the violation you obtain tells you clearly that the probabilities were not the same as you naively assumed. And the impossibility of deriving a similar expression directly in physical situation "xyz" without first going through "w" is a big hint that your assumptions are wrong.
To summarize:
1) There are two scenarios/physical sittuations involved in this discussion:
Scenario "xyz", involving the three probabilities:
P(A|x) = what we would get if we measure system "x" at angles (a,b)
P(B|y) = what we would get if we measure system "y" at angles (b,c)
P(C|z) = what we would get if we measure system "z" at angles (a,c)​
Scenario "w", involving the three probabilities:
P(A|w) = what we would get if we measure system "w" at angles (a,b)
P(B|w) = what we would have gotten had we measured system "w" at angles (b,c) instead of (a,b)
P(C|w) = what we would have gotten had we measured system "w" at angles (a,c) instead of (a,b)​
2) Scenario "xyz" is different from Scenario "w". The three probabilities in "w" are not equal to the three probabilities from "xyz".
3) Bell's inequalities are derived for scenario "w" ONLY. A similar inequality cannot be derived for scenario "xyz".
4) The predictions of QM are for scenario "xyz" only, not "w"
5) Experimental results are for scenario "xyz" only
6) Using probabilities from "xyz" in an expression derived for "w", amounts to introducing an assumption that the probabilities are all equal. It is this assumption that should be rejected when a violation results.
So what part of this argument don't you understand, or do understand but disagree with and why?
  • #271
Because to calculate the time required to put on shoes and then socks, I have to add the time required to put on shoes to the time required to put on socks.
No. T_b is just a fixed number like 5 in the physical situation in which you are only putting on socks. T_b is just a fixed number like 8, in the physical situation in which we are putting on shoes and then socks. T_b in in the first physical situation, is not the same value as T_b in the second physical situation, even though in both cases T_b is still the time it takes to put on socks.
What I have been explaining all this while, that the probabilities from the "xyz" scenario are not the same as those in the "w" scenario, so it is not correct to substitute them.
Nothing strange there at all if you understand degrees of freedom, and probability theory. Like I explained to you using the Bernouli's urn example, the probability of Red on the first draw when considered alone, has a different value from the probability of red on the first draw when considered together with the probability of red on the second draw, already given.
Because it is assumed that you want to make sound, consistent and valid arguments rather than just sneaking in paradoxes behind the back door.
  • #272
George Boole's ‘Conditions of Possible Experience’ and the Quantum Puzzle
ITAMAR PITOWSKY, Br J Philos Sci (1994) 45 (1): 95-125. doi: 10.1093/bjps/45.1.95
Abstract:
In the mid-nineteenth century George Boole formulated his ‘conditions of possible experience’. These are equations and ineqaulities that the relative frequencies of (logically connected) events must satisfy. Some of Boole's conditions have been rediscovered in more recent years by physicists, including Bell inequalities, Clauser Horne inequalities, and many others ...
On page 100:
George Boole is best known as one of the fathers of modern logic. Somewhat less known in his work on the theory of probability, most of it published in his classical book, Boole [1854]. ... Boole's problem is simple: we are given rational numbers which indicate the relative frequencies of certain events. If no logical relations obtain among the events, then the only constraints imposed on these numbers are that they each be non-negative and less than one. If however, the events are logically interconnected, there are further equalities or inequalities that obtain among the numbers. The problem thus is to determine the numerical relations among frequencies, in terms of equalities and inequalities, which are induced by a set of logical relations among the events. The equalities and inequalities are called 'conditions of possible experience'.
  • #273
On page 105 it says:
One thing should be clear at the outset: none of Boole's conditions of possible experience can ever be violated when all the relative frequencies involved have been measured in a single sample. The reason is that such a violation entails a logical contradiction. For example, suppose that we sample at random a hundred balls from an urn. Suppose, moreover that 60 of the balls sampled are red, 75 are wooden and 32 are both red and wooden. We have p1=0.6, p2= 0.75, p12 = 0.32. But then p1+p2-p12 > 1. This clearly represents a logical impossibility, for there must be a ball in the sample (in fact three balls) which is 'red', is 'wooden', but not 'red and wooden'; absurd.
Similar logical absurdities can be derived if we assume a violation of any of the relevant conditions, no matter how complex they appear to be. This is the reason for the title 'conditions of possible experience'. In case we deal with relative frequencies in a single sample, a violation of any of the relevant Boole's conditions is a logical impossibility.
But sometimes, for various reasons, we may choose or be forced to measure the relative frequencies of (logically connected) events, in several distinct samples. In this case a violation of Boole's conditions may occur.
So, No, I'm not using any alternate logic. I'm reasoning the situation as prescribed by one of the fathers of logic, and explaining to you that you are not reasoning logically about the situation.
see for example, https://www.physicsforums.com/showpost.php?p=3856772&postcount=125
  • #274
billschnieder said:
To summarize:
Bill, I think you’re lost in the ‘Bayesian jungle’... can’t see the forest for the trees...
You and lugita could probably continue this discussion for 100 years without agreement, because you are discussing two different things.
I have some simple Yes/No -questions that will hopefully reveal the root of bafflement:
  1. Do you understand that Bell's theorem is mainly about correlations (not probabilities)? Yes/No:
  2. Do you understand that for a single entangled photon, the measurement probability outcome according to QM is always 100% random (50/50 +1/-1) no matter what you do or what angle you set? Yes/No:
  3. Do you realize that when you write P(A|x) you are talking about statistical correlations for the relative angle (a - b), for hundreds or thousands of entangled pairs? Yes/No:
  4. Do you realize that above is also always true for any other settings, i.e. P(B|y), P(C|z), etc? Yes/No:
  5. Do you understand that it’s completely meaningless to talk about probabilities/correlations for a single photon/pair (except when perfectly aligned)? Yes/No:
  6. Do you understand that P(A|x) says absolutely nothing about the properties of a single photon before measurement? Yes/No:
  7. Do you accept the experimental outcome/statistics of EPR-Bell test experiments? Yes/No:
  8. Do you admit that to set an upper limit for ‘classical’ Local Realism, we must operate according to these ‘classical’ rules only, i.e. not according to the rules of QM? Yes/No:
  9. Do you acknowledge that that the definite property of LHV in Local Realism unconditionally leads to Counterfactual definiteness (CFD)? Yes/No:
  10. Do you acknowledge that LHV & CFD must naturally be included in the test of Local Realism, in from of Bell's inequality? Yes/No:
  11. Do you acknowledge that classical propositional logic do not work satisfactory in QM systems before measurement and the transition to [macroscopic] statistics? Yes/No:
  12. Are you aware of that your “Bayesian/logical investigation” on QM states before measurement is erroneous and that Quantum Logic is still ‘under development’? Yes/No:
  13. Do you understand that to use Bayesian probability theory in QM, you are forced to deal with measurements and [macroscopic] statistics, and that any “pre-measurement probability/states” is [yet] out of the question? Yes/No:
  14. Do you admit that if QM violates Bell's inequality – it violates Bell's inequality – no matter if it’s “Little Green Men” running an “intergalactic-non-local-signaling-system” or what, it is violated, okay? Yes/No:
Appreciate if you could answer these 14 simple questions with Yes/No – it will save us a lot of time.
Thanks
DA
  • #275
Somehow I doubt it. :biggrin:
[*]Do you understand that Bell's theorem is mainly about correlations (not probabilities)? Yes/No
Have you stopped beating your wife? Yes/No. I understand that that Bell's theorem can be about both. In the other thread which was closed, we discussed correlations, in this thread, we are discussing about probabilities. Do you understand that?
[*]Do you understand that for a single entangled photon, the measurement probability outcome according to QM is always 100% random (50/50 +1/-1) no matter what you do or what angle you set?
huh? That is a nonsensical statement. As I have explained to you 100 times previously, each specific single photon, when measured, gives a definite outcome. QM says absolutely nothing and can say absolutely nothing about this single outcome. What appears random is the SERIES of outcomeS from a SERIES of similarly prepared photons. It is for this SERIES that QM makes predictions. Obviously you do not understand this.
[*]Do you realize that when you write P(A|x) you are talking about statistical correlations for the relative angle (a - b), for hundreds or thousands of entangled pairs?
P(A|x) is a probability of mismatch when the set of photon pairs "x" is measured at the angle pair (a,b). P(A|x) is NOT a correlation.
etc ...
etc ...
I encourage you to go back and re-read this thread from page 15, carefully, because you obviously have not, as your "yes/no" wife-beater-type questions indicate. I'm not willing to attempt to correct all your misconceptions here, especially those that have already been corrected in excruciating detail in this very thread since page 15.
Rather it would save us time if you could state clearly what part of the argument in post #270 (which you quoted) you disagree with and why exactly.
  • #276
In the other thread, when I asked the questions:
billschnieder said:
1) Do you agree that there are two scenarios involved in this discussion:
Scenario X, involving the three correlations:
C(a,b) = correlation for what we would get if we measure (a,b)
C(b,c) = correlation for what we would get if we measure (b,c)
C(a,c) = correlation for what we would get if we measure (a,c)
Scenario Y, involving the three correlations:
C(a,c) = correlation for what we would have gotten had we measured (a,c) instead of (a,b)
C(b,c) = correlation for what we would have gotten had we measured (b,c) instead of (a,b)
2) Do you agree that Scenario X is different from Scenario Y?
3) Do you agree that the correlations in Bell's inequalities correspond to Scenario Y NOT Scenario X?
4) Do you agree that correlations calculated from QM correspond to Scenario X not Scenario Y?
5) Do you agree that correlations measured in experiments correspond to Scenario X not Scenario Y?
Your answers there were
1) Yes, of course
2) Yes, of course
3) Yes, of course
4) Yes, of course
5) Yes, of course
DA said:
Scenario X => QM theory => EPR-Bell experiments => what actually works
Scenario Y => assumptions of Local Realism => definite values all the time => CFD => not working
For clarity we exchange Scenario X = QM theory and Scenario Y = Local Realism, and then it’s easy to see where it goes wrong.
Yes of course, it’s big difference between QM theory and Local Realism.
Yes of course, Bell's inequalities sets the upper limit for what any model of Local Realism can achieve.
Yes of course, calculated correlations of QM theory naturally will correspond to QM theory.
Yes of course, when we perform QM experiments in form of EPR-Bell test experiments, it will naturally correspond to QM theory.
  • #277
I will let Bell answer this in his own words:
Page 449 in his 1966 Paper "On the problem of Hidden variables in Quantum mechanics", Reviews of Modern Physics, Vol 38 (3), 1966.
John S Bell said:
The essential assumption can be criticized as follows. At first sight the required additivity of expectation values seems very reasonable, and it is rather the non-additivity of allowed values (eigenvalues) which requires explanation. Of course the explanation is well known: A measurement of a sum of noncommuting observables cannot be made by combining trivially the results of separate observations on the two terms.
On page 451 of the same article Bell says
John S Bell said:
The danger in fact was not in the explicit but in the implicit assumptions. It was tacitly assumed that measurement of an observable must yield the same value independently of what other measurements may be made simultaneously. Thus as well as P(Φ3) say, one might measure either P(Φ2) or P(ψ2), here Φ2 and ψ2 are orthogonal to Φ3 but not to one another. These different possibilities require different experimental arrangements; there is no a priori reason to believe that the results for P(Φ3) should be the same.
  • #278
Okay, then you don’t understand Bell's theorem.
[my bolding]
Okay, now you’re refuting that most fundamental property of the most successful scientific theory ever, the very same theory that makes your computer compute and your internet connection connect. Grave...
Sorry Bill, you do not understand the basics in Bell's theorem:
Test angles:
a = 45°
b = 22.5°
RELATIVE angle (a - b) => (45° - 22.5°) => (22.5°)
Correlation STATISTICS for HUNDREDS of entangled pairs at RELATIVE angle 22.5°:
cos^2(22.5°) = 85%
And of course, the type of Bell state (Type I or Type II) decides if we are talking match or mismatch. Period.
Oh... did I mention that in the “Bayesian probability system”, built just for this occasion, there was also included Yes/No/Absent? According to the “system estimation” – you have written hundreds of posts, including thousands of words, on this subject – and now you refuse to type 14 simple Yes/No...
I think anybody with normal intelligence can see what the probabilities for this suggest.
Thanks Bill, you’ve just saved us a lot of time, and I will of course bookmark this post, and link as soon as you bring up this terribly erroneous logic on PF, for anyone to inspect! :biggrin:
End of story.
Take care! :-p
  • #279
OK, then that's what we need to focus on. Again, I still want to know whether you agree or disagree with the answers to my two questions are always the same. Because if they are always the same, then I can show that P(A|x) must always equal P(A|w).
Let me repeat the basic logic. Consider a photon before it is measured. By counterfactual definiteness, for every angle setting θ1, there exists a definite, predetermined answer to the question "What result would you get if the photon were measured at angle θ1?". Now if the experimenter can freely choose his measurement decision, then the predetermined answer to this question cannot depend on what he is going to do, so it cannot depend on the angle θ2 he is going to measure at, whether θ1=θ2 or θ1≠θ2. Do you agree or disagree with that? (And please answer this question without discussing probabilities, because it has nothing to do with probabilities.)
If you agree, then I can easily show that for any given photon pair, the truth value of A is independent of the angle settings of the two polarizers. And then from there, I can easily show that P(A|w) = P(A|x).
I'm not sure what you're talking about here. I never use P(A & B & C|w) or P(A & B & C|x,y,z) in my proof at all.
If we use a bunch of different assumptions to derive a contradiction, then at least one of them is wrong. You think that what's wrong is my equating of terms. But I gave an argument for why I'm equating terms at the beginning of this post, so the question becomes, where do I go wrong in that argument?
Or a hint that counterfactual definiteness is an essential assumption of Bell's theorem.
To summarize:
Scenarios "xyz" and "w" are just (b) and (c) in the notation you were using earlier, right?
Of course this is the part I disagree with. See my argument at the top of this post for why.
Part 2 is where we part ways.
  • #280
Are you a real person!? Have you read anything I've written in this thread, at all. Do you understand any of it?
I have already shown you that they must not always be equal. I have used several examples, with quotes from Bell himself to explain to you that they are not equal in the two scenarios. Yet you ask me again if I agree that they are always equal.
  • Quantum Interpretations and Foundations
12K
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
