- #36
DrChinese
- 1,921
rede96 said:How to calculate the percentage match that would be observed in experiments.
As I understood from your post #19, to calculate the % match for anti-correlated particles, for each angle it would be Match%= 1 - (cos^2(theta/2))
So for angles 0, 120 and 240 that would be:
0 is 1 - (cos^2(0 degrees/2)) = 0
120 is 1 - (cos^2(120 degrees/2) = 0.75
240 is 1 - (cos^2(240 degrees/2)) = 0.75
So the average of those is 0.5 So how does the total match prediction = 0.75? With photons it was (cos^2(angle A - angle B)) So is that not the case here?
This is the one bit I'd really like to understand. How to calculate the total match percentage for any set of 3 angles for both correlated and anti-correlated particles.
Also I am assuming that the total match prediction is a percentage of the total number of tests - any tests where the angles where the same.
As zonde already mentioned, and I think you now understand: Theta is the relative angular difference between 2 angles. 1 - (cos^2(Theta/2)) is the same as sin^2(Theta/2)).
The reason I use theta angles that are the same is because it generates an average that is the same as the individual components. That is not really a requirement, just makes everything pretty simple and easy to see. Again, what I am recommending is that you write down a series of hand generated outcomes (for 3 different measurement settings A/B/C) and then calculate the average of Matches. You will quickly see that there are no value sets that give the quantum mechanical expectation values. For anti-correlated electrons, that would be .75 for the Matches. Photons can be correlated or anti-correlated depending on the setup.
